Question about Brother EM-530 Typewriter
Correction bar not working. When I type in a word and hit correct, instead of lifting the lettter off the paper it types the letter I typed in bold. Is there a button I can push to correct this from happening? Brother EM-530 CM-1000 Electronic Typewriter
  • Brother Master
  • 3,594 Answers
The correction tape may be installed wrong, or it may be a tacky L/o that will stick nand not raise up..
You can find a manual at BROTHER.COM, click on support.
DickyO
Posted on Sep 03, 2010
Changing correction ribbon
First this is old school after hitting the correction you must press the letter you are trying to correct. if you knew this and the correction tape is properly installed and lifts up you may have old supplies, If you want to talk yuo can call me.
DickyO
216-269-3918
Dec 05, 2014 | IBM Correcting Selectric Iii Typewriter...
I installed the correction tape and it does not correct
Sounds like you have diagnosed the problem. Remove the correct tape and make sure that it's not the "sticky" type. (it will be hard to unwind if it is). Next try to manually lift the part that's supposed to move to see if it does. If it's sluggish (hard to move) put rags around it to prevent over spray and carefully clean all the moving parts with WD40. Make very sure that the WD40 does not get on any electronic parts! It will also mess up the platen. So, the more rags around the moving parts, the better. I used to work on IBM typewriters, and WD40 sometimes works wonders.
Jan 02, 2014 | Brother ML-300 Typewriter
How do we use the correction on a smith corona sl 470
Provided that you have a fresh correctable ribbon and lift off and they are properly installed type a letter, press correction key the correction should take place.
DickyO
May 21, 2012 | Smith Corona Typewriter SL470 Refurbished...
Hi
Many brother type writers have two cam assemblies under ribbon holder. One operates the print hammer and the other operates the correction ribbon lift. sometimes they gets stuck or lock themselves up. turning on and off a few times will take care of it, but sometimes it needs to be worked on by a tech. If you look when you type a character, most likely the print hammer is not firing or it is striking the correction ribbon instead of the black ribbon.
Let us know if you want to know something more else please accept the suggestion.
Thanks for contacting Fixya.com
Apr 08, 2010 | Brother EM-530 Typewriter
IBM Wheelwriter 6-Letters striking paper above
Put in a multi part form and type if the carbons come out OK the the ribbon isn't lifting, Wiggle the big black gear on the R. side of the carrier back and forth. They do get tooth for tooth when they get old. If the print on the copies id bad or not there you need a print solenoid cap. We sell them for 20,00 including instructiond and shipping.
DickyO
Cleveland Business Machines
216-241-0027
Feb 18, 2010 | IBM Office Equipment & Supplies
My typewriter doesn't type..won't display letters, but keys work.
alot of the brother t/w's have 2 cam assemblies under ribbon holder. 1 operates the print hammer and 1 operates the correction ribbon lift. sometimes these will hang or lockup. sometimes turning on and off a few times will take care of it, but sometimes it needs to be worked on by a t/w tech. if you look when you type a character, most likely the print hammer is not firing or it is striking the correction ribbon instead of the black ribbon.
hth,
razors
Feb 27, 2009 | Brother Office Equipment & Supplies
No Characters Typing
could be the ribbon is not lifting, do you see an image on the ribbon, also may be twisted inside the cartridge the shiny side has to be facing the keyboard.
Jul 09, 2008 | Brother EM-630 Typewriter
Correcting IBM Selectric II Typewritter correcton ribbon won't engage
Selectric I and II type elements are identical (88 char) where Selectric III uses a different element (96 char). The 88 character element will have white lettering and the 96 character element will have yellow. Directly underneath the lift-up tab to remove the element will be a 3-digit number. That's the last 3 digits of the element's part number, which will be preceeded by 1167 for 88 character, or 1352 or 96 character. For example, if you have a '052" stamped on the element, and it's an 88 character style, the P/N will be 1167052.
The correcting mechanism is an intricate additional function of the backspace function. To test it/adjust it/or repair it requires the machine be hand-cycled using a hand cycle wheel which is screwed into the right hand side operational shaft. It's unlikely that an un-trained party would be successful repairing this..
May 15, 2008 | IBM Wheelwriter 30 Typewriter
Correction Tape
Check the way the correct tape is installed. I have seen people twist them around the guide backwards and the correction material is facing away from the paper. Also can you see the correction tape lifting up?
Aug 13, 2007 | Brother GX-6750 Typewriter
Brother EM-530 Typewriter Logo
137 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
