Question about Hayward Pool & Spa
How do I lock the motor shaft so I can remove the impeller?
  • 106 Answers
Remove back cover. Shaft has a flat on it which an be held with a half inch open end wrench.
Posted on Sep 02, 2010
How do you remove the impeller on a mission magnum centrifugal pump?
Open up the pump housing, by separating it into 2. Reveal the impeller. If there is a center screw in the middle of the opening of the impeller, it will normally be backwards threads. Remove that.
know if the impeller should unscrew off of the motors shaft, that will be normal threads. But, to do that, you will have to lock the shaft from spinning. Remove opposite side Cap on the motor, to reveal the shaft. Either use a wrench or flat blade screwdriver to lock the shaft. Now unthread the impeller from the motors shaft.
Apr 06, 2015 | Pool & Spa
Pentair 011523 pump shaft seal is leaking. How do you remove the impeller and motor?
Separate the plumbing portion of the pump from the seal plate which is attached to the motor. The bolts will be a 9/16 inch hex head, that are visible facing the motor. Remove those bolts. That will then allow you to pull the motor and the seal plate away from the plumbing portion of the pump. Remove the diffuser which is covering the impeller, and then the impeller will need to be unthreaded off of the motors shaft. The motors shaft, will need to be locked. You can do this by removing the Cap on the backside of the motor and you can use whatever tool required to keep the shaft from spinning. Once you are able to lock the shaft, you can read the impeller... Note* some styles will have a screw in the middle of the impeller securing it to the motors shaft? This screw is Backwards thread, not normal thread. If your pump has this screw, need to remove it first, then you will be able to unthread the impeller off of the motors shaft.
once the impeller is removed, you can then remove the two halves of the shaft seal. Very carefully reinsert the new shaft seal into the proper places, just the way they were prior to you removing them.
Reassemble in backwards order as you disassembled everything.
good luck
Sep 04, 2013 | Pentair 011523 WhisperFlo High Performance...
How do I lock the shaft so that I can remove the impeller?
remove the cap at the rear of the motor. you'll see the shaft under the thermal overload. Take a 7/16 or 1/12 wrench depending on shaft size, turn the impeller until you see the slot for the wrench. you may have to remove the starting compassitor to make some more room. Hold your wrench with one hand and remove the impeller. ***some impellers have a lock screw in the middle of them, if you have one it is left handed threads, this must be removed before the impeller can be removed.
Aug 27, 2013 | U.S. Motors Emerson EB848
Hi, I have a waterway executive 48 spa pump and need to replace the seal on the pump shaft. How do I get the impeller off the shaft to access the seal.
Thank you for posting your question here on Fixya.com.
Removing the impeller requires you lock the shaft as you turn the impeller off counter-clockwise. You will also need to check for an impeller screw in the center of the impeller inlet. If a screw is present they are usually left hand thread. Back out the screw first, then proceed to remove the impeller.
To lock the impeller you will have to remove the motor end cover or a cap covering the shaft end depending on which version your particular motor has. Look at the end opposite the pump and imagine a shaft from one end to the other right in the center.
Once you remove the cover you will see a slot for a screwdriver, a flat for a wrench, a hex hole for a hex key or some combination of these. Lock the shaft and spin off the impeller. Some are so tight you will end up breaking them in the process. Simply replace it and the seal. Be sure the motor shaft is in good enough condition to allow the new seal to work properly. If too much shaft material has rotted away the new seal will leak soon after it is installed; you would need a new motor at that point.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
John
Jun 13, 2011 | Pool & Spa
How do you remove the impeller to replace the seal?
John
May 07, 2011 | Hayward 1 12 Hp Super Swimming Pool Pump...
How to remover the impeler in a 2hp Pinnacle?
John
Apr 10, 2011 | Pentair Pinnacle 2 - Hp In Ground Pool...
How to remove the impeler from my home hardware1/3 hp jet pump
Removing the impeller requires you lock the shaft as you turn the impeller off counter-clockwise. To lock the impeller you will have to remove the motor end cover or a cap covering the shaft end depending on which version your particular motor has. Look at the end opposite the pump and imagine a shaft from one end to the other right in the center.
John
Mar 01, 2011 | Homelite Plumbing
How do you remove the impeller to replace the seal kit?
John
Dec 29, 2010 | Waterway Above Ground Hi Flo Pump
Remove 1hp Impeller, Max E Glas to replace motor on purex-triton pump
John
Dec 14, 2010 | Pentair Plumbing
Need to replace pump Impeller on A.O. Smith Century Centurion Pool & Spa Duty Switchless Pump
To get to the Impeller you need to remove a series of bolts, or a large clamp, that holds the two halves of the pump together. Once you do that, if their is a diffuser (housing that goes over the impeller), remove it. To remove the impeller, you need to lock the motor shaft. You can do this a couple different ways depending on the motor. There will either be a small cap that grants access to the motor shaft on the back of the motor, or you remove a larger housing that grants access to the wiring and other components in the back of the motor. If it's the small cap, then you can hold the shaft with a wrench. If it's the larger housing, then you can slip a wrench (probably 7/16") under the thermal overload switch and onto the shaft to lock it in place. Now you can unscrew the impeller. Check to see if the impeller has a screw in the center. If so remove this first. It will be reverse thread. The impeller should spin off counter clockwise. If the impeller is very tight, be careful not to damage it. If you don't have an impeller wrench, I strap wrench, or very large locking pliers with a rag around the impeller works well. Hope this helps. If you need further assistance post a reply in the comments, and don't hesitate to leave a good thumb rating if you found this helpful. Thanks, and good Luck!
Oct 11, 2010 | AO Smith Pool Pump Motor Hayward Swimming...
Pool & Spa Logo
162 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
