Question about Makita 10" Dual Slide Compound Miter Saw with Light LS1013F
Macallister slide mitre saw the blade is loose ? tighten/change /relocte blade
  • 5603 Answers
SOURCE: ryobi 18v circular saw owners manual - blade is loose!
Usually there is a button to press that locks the shaft arbor and then you use a wrench to tighten OFTEN is a left hand thread!
Check for lock button behind the blade guard toward the motor.
Posted on Sep 28, 2009
Testimonial: "Thanks; that's the advice I got when I tracked down the number to call Ryobi. However, it doesn't seem to be working. Now sure what is wrong :("
SOURCE: how do I change the blade on mastercraft compound mitre saw
I have the same question.
Posted on Apr 17, 2011
efs_perpends
  • 1996 Answers
SOURCE: I took the guard off the 10" Makita Mitre saw (spring loaded)!
Oh, you got it off. I bet you can put it back on again.
It's much easier if you take the blade off first. Then you'll be able to reach inside when you need to. Be patient, don't force it, and make sure when you get the spring reconnected properly that the guard moves freely out of the way when you chop, and returns when you raise the saw back up.
It's a bit of a trick, but I bet you can manage it..It's been awhile, but it seems to me there's a way to get the bolt started before you engage the tension on the spring...I'd have to have it in my hands to say exactly.
Here's a link to the exploded parts view at the Makita site, just in case. And it might help to have an extra pair of hands, or a piece of duct tape to hold the guard in place when you go to put the blade back on.
Posted on Apr 10, 2009
agent91
  • 2100 Answers
SOURCE: Is there a safety or
Yeah, there is a latch type keeper on the back there that holds the motor down for transport. Should be easy to find. Hope this helps.
Posted on Sep 22, 2010
rowdy45176
  • 2176 Answers
SOURCE: Got my sliding mitre saw
if this is a Makita, there should be a large black knob that you need to loosen to allow it to slide, Let me know if you need more help and if you do please furnish the brand and model number
Posted on Oct 03, 2010
Tip
How to change a mitre saw blade
When changing the blade on your mitre saw the first step is to unplug the tool for safety reasons. DO NOT disassembly the safety cover, there is a bolt on the housing that when loosened allows the cover to be moved away from the blade to expose the spindle bolt. After moving the ASSEMBLY away from the blade turn the blade by hand slowly while pushing on the spindle lock to stop rotation. Loosen the blade bolt (usually left hand thread) and place the parts in the order removed, e.g. blade bolt outer flange, blade spacer if used. Reinstall blade noting the rotation of the teeth and replace parts in reverse order. After installation check for rotation by carefully turning the blade by hand and replace safety cover to its original position and tighten bolt.
on Jul 04, 2011 | Saws
Macallister mitre saw sparking
I would plug it into another outlet first. The small arcing that you see might be normal especially on stopping because of the brake. If another outlet doesn't work then I would take it back. Upon startup this saw will draw more than the rated running amps.
Feb 26, 2012 | Saws
I bought a ls1016 coupond mitre saw this week. I was cutting cedar 2x6 's today and had a few kick backs. I am building my deck and do not feel safe using the saw after the kick backs. Why as this...
Sounds as if the blade is dull. Or perhaps bent. A dull or bent blade blade will 'grab' the wood, rather than cut it, resulting in binding, or kickbacks.
Solution; replace the blade with a fine-toothed, good quality blade. If the blade is new, then check that the blade is bolted tight on the arbor. If the blade is loose, it can result in kickbacks.
Also, check that all the bolts/fasteners/locking mechanisms on the saw are tight, and in good working order. Sometimes a tool new out-of-the-box will have loose screws/nuts/bolts that need to be tightened up.
Also, when cutting, use a smooth, slow, motion, being sure to give the saw the time it needs to make the cut.
Jun 19, 2011 | Makita LS1016LX 10inch DualSlide Miter Saw...
Changing the blade on a power mitre saw
dont know about a manual, usually a button to push, maybe underneath, or a hole to put a dowel through?
Oct 23, 2009 | Saws
Mitre saw won't cut square
You will have to use a regular square to check out the crafstsman and find out where it is wrong.
Jan 16, 2009 | Bosch 12" Dual - Bevel Compound Miter Saw...
Makita 10" Dual Slide Compound Miter Saw with Light LS1013F Logo
611 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
