Dasfoss thermostat used for Neslab chiller Model HX 150,ttemp wprking 20 deg. centigrade
2 Suggested Answers
  • 51 Answers
SOURCE: i've an alram in my carrier chiller model 30XA1202
TURN OFF THE BREAKER TO THE UNIT AND UNPLUG IF
POSSIBLE...WAIT 10 OR 15 MIN. AND TURN THE BREAKER
ON THEN PLUG THE UNIT IN....IF THIS DOESN'T WORK YOU MAY HAVE TO REPLACE THE BREAKER OR TRY A DIFFERENT
OUTLET AND WHILE POWER IS OFF CHECK ALL WIRE CASINGS
AND CONNECTIONS FOR GROUNDS OR SHORTS.
Posted on Apr 13, 2010
Help I tried to lower the temp for the air conditioner and now it won't turn off because it's set at 20.5. How do i reset it to 68?
I believe it is set to show Centigrade at the moment. 20.5 deg C is actually 68.9 deg F. So no worries as to the temp being wrong.
Now if you are asking how to set the display to Fahrenheit degrees instead, we will need to know the make and model.
Jun 24, 2016 | Heating & Cooling
The freezer is running but will not switch off we have replaced the thermostat
loose clamp on,thermostat sensing bulb (c and s)
check position and tighten.
Chiller tray out of position(s) check and reposition
God bless you
Oct 30, 2013 | Frigidaire 20 cu. ft. / 566 liter Upright...
Freezer 20 deg --fridge 55 deg fridge not cooling
Check compressor working and also with correct pressure. Keep arm in condenser coil. If you feel warm, check freezer to hear slight whistling sound. If not short of gas or gas leak. If warm and no whistling sound means, system chocked. Release all gas and flush out system. Vacuum and do gas charging. Thermostat setting must be 3 to 5 degree Centigrade.(37*F to 41*F). Thanks.
Feb 04, 2011 | Refrigerators
How to you change ferenheit to celcius?
Tc = (5/9) x (Tf-32); Tc = temperature in degrees Celsius, Tf = temperature in degreesFahrenheit.
Example: 40 deg. F minus 32 = 8, 8 x 5 = 40, 40 divided by 9 = 4.44 deg. Centigrade.
To go the other way:
Tf = [(9/5) x Tc]+32; Tc = temperature in degrees Celsius, Tf = temperature in degrees Fahrenheit
Example: -10 deg. C x 9/5 = -18; -18 + 32 = 14 deg. F
See also: http://www.csgnetwork.com/tempconvjava.html
Jan 29, 2011 | White Rodgers White-Rodgers 1F85RF-275...
Where is the thermostat located on golf v1 1999 1.6,car been standing 6 months worked fine now water not circulating!!!!!!
Heed of antifreeze coolant temperature!!!
First time you might check the thermostat operating.
The thermostat location for VW Golf 1.6 is inside of coolant thermostat housing placed on back side of the cylinder head. See pictures below.
Thermostat checking:
1. Cold engine. Start up the engine and watch of the water temp indicator. After first value 60 Celsius Degree you still warm up the engine until the lifter (pointer) reach 80 C deg. (second mark after 60 C deg.). At this time you let engine running at idle speed and check with your hand the thermostat plastic housing and hose temperature in bottom left side of the engine. Heed of alternator driving belt and ventilator fan !!!
2. If the thermostat is good the hose must be cold until the water temp indicator reach almost 90 C deg.
3. The thermostat opening temperature is 87 C deg.
4. If the hose is already warm the thermostat is out of order.
Thermostat location, Part number: 032121110B, in german - "Kuehlregle" (Price around $20):
Important note: Always replace the thermostat round seal, position 6 in the above picture.
Please do rate my response. Thanks!
Jan 29, 2011 | 2001 Volkswagen Golf
How much celcius is 32 fahrenheit?
32 Deg F. = 0 deg. C.
The following formulas apply in general:
Jan 16, 2011 | Home Security
My 2004 A4 1.8 Audi's water temperature does not go above 150 degrees F. What can be the problem
Check the engine thermostat!
1. Cold engine. Start up the engine and watch of the water temp indicator. After first value 140 degrees F you still warm up the engine until the lifter (pointer) reach 175 deg. F (second mark after 140 deg. F). At this time you let engine running at idle speed and check with your hand the thermostat plastic housing and hose temperature in bottom left side of the engine. Heed of alternator driving belt and ventilator fan !!!
2. If the thermostat is good the hose must be cold until the water temp indicator reach almost 195 deg. F.
3. The thermostat opening temperature is 188 deg. F.
Replace the thermostat if necessary!
Jan 11, 2011 | 2004 Audi A4
Solid state water chiller thermotek T252P-4 , how do I adjust cooling rate per minute
That's the gradient setting. Press the output temp key until gradient appears, then use the up and down keys to change the setting. The change rate is in degs C per hour.
May 11, 2010 | Computers & Internet
Chiller wiring diagram
Contact the manufacturer through the tech support line located in your owner's manual.
Jan 29, 2010 | Heating & Cooling
Heating & Cooling Logo
60 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
