Question about HP Photosmart R707 Digital Camera
I dropped my R707 on the floor now charged it will not turn on.
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Sep 03, 2010
No power after dropping it accidentally...
try pushing the reset button by the battery slot, use a paper clip and hold for 5 seconds without the battery in it. good luck
May 10, 2009 | HP Photosmart R707 Digital Camera
I have an hp r707 it wont charge or turn on at all it light red where the record button is but thats it what can it be
Try to connect it to the charger. If it works while connected to charger, you need to replace the battery.
Jan 02, 2009 | HP Photosmart R707 Digital Camera
Hp r707 wont turn on
Connect the charger. If the camera works while connected to the charger, you need a new battery.
HP R707
get the adapter plug it in,, in the camera that little hole next to the usb,,, just like u will charge the battery, then turn the camera on,, just your camera lens will be back to normal,, hope i helped ya out.
Sep 11, 2008 | HP Photosmart R707 Digital Camera
R707 Fails diagnostic test 10 (strobe)
I found my answer to this on another board. Remove the battery and SD card. Use a paperclip to press in the small siver dot above the + sign for about 10 seconds. This resets the firmware.  It worked for me, hopefully it will work for you too.
Jul 13, 2008 | HP Photosmart R707 Digital Camera
HP R707 camera
My HP R707 5.1 camera lens is stuckout and will not go back in or out when powered on. It only makes a beep sound and turns off automatically
Jun 20, 2008 | HP Photosmart R707 Digital Camera
HP photosmart R707 camera does not turn on and charge
if you want to turn it on do a firmware reset:
To do a firmware reset, open the battery bay, remove the battery and the SD card, and then insert a paper clip into the tiny hole in front of the little "+ -" sticker on the battery door. Hold it for 6 seconds, and remove. After this reinsert the battery, and the turned it on this should allow you to do the update
Nov 08, 2007 | HP Photosmart R707 Digital Camera
Flash problem HP R707
I've just spent 30 minutes on the phone (premium rate) to HP re this problem. The solution was as follows: switch the camera off take the battery and any memory cards out press the end of a paperclip into a small hole (which you can see with the battery compartment open) remove the paperclip after 10 seconds put the battery and memory card back in and the problem should be sorted. HP also suggest upgrading the camera firmware (which you can do via their website)
Aug 10, 2006 | HP Photosmart R707 Digital Camera
HP Photosmart R707 Digital Camera Logo
115 people viewed this question
Top HP Cameras Experts
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
