Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
Hi, I've got several HD harddrives and for some reason one of them (which I use as an archive and so has been idle for a few months) is suddenly unrecognized by my iMac. It makes a clicking sound, but does not mount. The Mac is a 2.4 GHz Intel Core 2 duo and I'm on OS X v.10.5.8. Any idea how I can recover my data?
  • 3,940 Answers
If the drive is making the "Click of Death" then most likely the only way to recover the data is to send the drive to a data recovery specialist (DriveSavers, On-Track et al) recovery of data can be pricy.
It is possible the drive enclosure itself is bad, you could try moving the drive to another enclosure and see if it works there, but that is a stretch
Posted on Sep 02, 2010
Testimonial: "not what i wanted to hear ;) but i appreciate the prompt reply... i will hold out hope that the drive enclosure is at fault. thanks!"
My external hd (fantom titanium) doesn't regularly open on my mac suddenly
fouad,
Inside the case of that Fantom is a regular harddrive.
Also inside that outer case is a small circuit board, that either the harddrive plugs directly into it; or there is an interface block the harddrive plugs into, and there are wires from it, that connect to the small circuit board.
(The USB cable is connected to the small circuit board)
It is this small circuit board that usually goes bad.
My suggestion is to remove the harddrive inside, purchase an economical external enclosure, and install the harddrive in it.
Have your harddrive back, and be able to use it as an external harddrive again also.
The Harddrive Inside:
Harddrives are measured by their Width.
A laptop harddrive is 2.5 inches across in width. (2-1/2 inches)
A desktop harddrive is 3.5 inches.
The Fantom Titanium II 500GB's harddrive inside, is 3.5 inches,
http://www.newegg.com/Product/Product.aspx?Item=N82E16822204034
Details > Physical Spec > Form Factor > 3.5
What I can't tell you is whether it is an IDE (PATA) harddrive, or a SATA harddrive.
However this external enclosure for 3.5 inch harddrives, is for both IDE, (PATA), and SATA harddrives,
http://www.newegg.com/Product/Product.aspx?Item=N82E16817388014R
[ You can also look at the label on the harddrive, and look up it's model number online, to see if it is IDE or SATA. Just type the model number in your search bar ]
Just want to include information on IDE (PATA), and SATA, in case you are interested,
IDE: http://en.wikipedia.org/wiki/Parallel_ATA
SATA: http://en.wikipedia.org/wiki/Serial_ATA
Regards,
joecoolvette
Jul 27, 2012 | Fantom Titanium II (TFD500C16) 500 GB USB...
I need a harddrive ribbon cable for Getac A770. I have caddy.
Try e Bay, I've found several unique computer cables I needed there, including SATA & PATA cables that were too expensive locally.
I also used that same resource to stock up on extra cables for PC expansions & repairs. They take a while, but they are priced low.
I've experienced very few issues with products purchased new from overseas.
Mar 22, 2012 | Getac Computers & Internet
Dual handset ge 21008ge2-a handset needs registration suddenly came up for no reason. we've had the set for several years
Follow the registration instructions on page 15 of the manual at
http://www.home-electronics.net/USER-GUIDES/21008_DOM_ES_CL_IB.pdf
Aug 18, 2011 | GE 21008GE2 Dual-Handset Cordless...
Laptop becomes idle after 10 mintues
problem is either motherboard or harddrive
Jun 28, 2009 | Dell Latitude D600 Notebook
Toshiba satellite A105,My wife dropped laptop now when you try to start I get error message operating system not found, try to boot to bios and get several quick beeps
Harddrive has probably crashed or the connection have become loose. Flip the laptop over and look for the Harddrive assembly. Usually has 1 screw holding it in place. If you feel comfortable enough - remove the screw and pull the HD out and slide it back into place. See if the connections are simply loose.. If that does not work you probably need to replace the HD.
Jun 17, 2009 | Toshiba Satellite A105 Notebook
Operation of LaCie d2 Quadra 320 GB Professional Hard drive
So the problem is that you cant put your mail archives from Outlook Express on the HD?
You can create mail archives in Outlook, and I suppose you are then able to save them on that harddisk. If you cannot, I suggest you create the archive on your internal harddisk and then copy-paste it to the external harddrive.
I hope this is what you were looking for,
Yannick
Feb 15, 2009 | D-Link Computers & Internet
Simple tech 500gb usb hard drive
Youve damadged the harddrive, is the harddrive spinning or making any noise?
Jun 16, 2008 | SimpleTech SimpleDrive Pininfarina 500GB...
Audio problem... channel with no sound
make sure your S.A.P feature is turned off. S.A.P. stands for separate audio program.
Apr 25, 2008 | Toshiba 56HM66 56" Projection HDTV
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
283 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
