Question about Hoshizaki KM-630M Crescent Cuber Ice Maker
Km-630mae/where does the L-shaped metal bracket fit inside the float switch. It fell out
  • Hoshizaki Master
  • 1,250 Answers
Small bracket does not go inside, but outside the float switch. It goes behind where the float switch mounts. A screw goes thru the float, the bracket, and then into the machine. It holds the float level to it's adjustment.
Posted on Oct 12, 2010
Le Crueset 1.8-Qt. Enamel on steel whistling teakettle u-shaped metal piece fell out
There are two parts to the whistle - the hinged whistle bit and the black base that is attached to the spout. They are joined by a pin that passes through the base and through a bracket that is fixed above the spout, and through the bottom of the arm on the hinged whistle. Remove the pin - it is a push fit - so you need a rod of the same diameter. It will then all come to pieces. The U shaped metal spring sits in the bracket on the spout - the open end and the slope on the spring to the top. Then put the bits back together and replace the pin! This is tricky but do-able as all the holes have to line up. You need to have plenty of light to see what is going on. Once aligned the pin goes back in okay but don't try to force it. If it doesn't go in your alignment isn't right.
Mar 22, 2013 | Le Creuset 1.8-qt. Enamel on Steel...
In the top grill of a neff u142nogb built in oven the heated element and back plate have dropped down and a small self tapping screw and L shaped bracket have fell down bot the self tapper has no suitable...
We have a video how to replace the grill element and a part of the video shows how the element is support with bracket and it might help you
Sep 11, 2011 | Neff Ovens
In the water collection tank area a arm with awheel attached fell off i dont know where it came from
Ken, that is the float valve, that sits inside the (I believe) the top right side of the bucket. It shuts the unit OFF automatically, when the bucket is full. Hopefully, it just fell off and didn't break off. The wheel end, fits inside the bucket and the shorter part of the 'U" shaped arm fits over the back of the bucket, so that it makes contact with bucket removal safety switch. If it broke off, it will have to be replaced. In some cases, the whole bucket assembly has to me replaced. Since your model has been discontinued, it would be best to contact Danby's Consumer help line: 800-263-2629 to obtain the necessary part(s)
In case you have misplaced your Owners Manual I have included a link to it, that you can download and print for future reference.
http://www.danby.ca/cms/uploads/products/en_manual/DDR2509%2C_3009%2C_4009EE_EFOM.pdf
Jul 15, 2011 | Danby DDR2509EE Dehumidifier
The rear seat comes loose, it has metal loops on the seat that fit down into a metal bracket on the floor of the car but there is nothing to hold them in there. i just bought the car so there is not clips...
The brackets on the floor should have a U shaped hook to them, the metal loops on the seat fit into the brackets and the pressure od the seat holds them in place.
Mar 16, 2011 | Oldsmobile Cutlass Cars & Trucks
Kyocera KM-2530 printer displays "Attach Finisher." It was working until we moved it recently. Checked all cords and rebooted several times to no avail. Couldn't see any push rods or buttons that need...
on the copier metal bracket that finisher attaches far end or front ull see a metal pin that sticks out.
That pin goes in to the finisher white plastic hole.Inside that hole there is a switch that tells the copier the finisher is attached.
Oct 07, 2010 | Kyocera RI-3530 Black and White Copier
Re-assembly of 99 Blazer mirror to windshield
This is a relatively easy task, the bulk of the work has been for you. The rear view mirror assembly simply slides onto that metal block that was glued to your windshield. Your mirror mount (the part that slides onto the metal bracket) may be cut differently or shaped different from the rest of that part. you simply need to line that up with the metal mount on your windshield. slide the mirror on and tighten down the set screw if you have one. I've listed the steps below
1. find the base mount for your mirror (this is the bottom of the mirror that sits on the windshield)
2. look for a cut out or flat part of the mirror base.
3. line the flat part of the mirror base with the metal mount bracket on the windshield.
4. slide the mirror onto the metal bracket (this may require you to wiggle while you slide the mirror onto the metal bracket).
5. tighten the set screw on the mirror base ( this is important because your mirror will vibrate off the bracket if you don't.
Note some mirrors slide from the bottom of metal mount bracket and some slide from the top. it sort of depends on the manufacturer and/or the way the bracket was installed.
Hope this helps
Aug 04, 2009 | 1998 GMC Jimmy
Fridge doorhandle bracket
Possible the source of the trouble you are having is the bracket might not be available or available separately.
Most parts lists have an exploded drawing showing all the parts and these are an invaluable aid to obtaining the correct spare parts.
I suggest you ask the service department to fax or email a drawing to you.
Mar 28, 2017 | Amana AFD2535DES French Door Refrigerator
Trying to locate componants for the 3 beeps
float switch at front of module to the left of the water pump white plastic with black rubber push on seal
inlet valve at top middle of machine inside small metal holder screwed to top of machine
Jul 12, 2008 | Hoshizaki Commercial Freezer KM-500MAH
Kenmore toaster oven handle fell off
try magic putty. it works on everything
Jul 11, 2008 | Toaster Ovens
Hoshizaki KM-630M Crescent Cuber Ice Maker Logo
132 people viewed this question
Top Hoshizaki Refrigerators Experts
Tom Donaldson
Level 1 Expert
J Rosado
Marat Brikov
Are you a Hoshizaki Refrigerator Expert? Answer questions, earn points and help others
