Question about Dell Dimension 4600 PC Desktop
Error on windows load
Hello!
When loading, before initial Windows XP window is shown, the following message is quickly displayed:
File BOOT.INI is invalid
Loading C:\ windows
Thanks in advance,
Sergio.
It worked!
Thanks a lot for your attention and help.
Regards,
Sergio.
Posted on May 12, 2008
Problem solved!
Regards,
Sergio.
    Sergeant:
    Champion:
  • 326 Answers
[boot loader]
timeout=30
default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
[operating systems]
multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /fastdetect /NoExecute=OptIn
This is what the boot.ini file should look like. Use U'r recovery disk to create or edit the ini file as above. U cannot use DOS 6.22 to create this file if U'r system is formated in NTFS.
If U don't have a recovery disk, make one from someone else's XP computer (DOS 7.xx).
Posted on May 11, 2008
How to fix my acer extensa 4630z? Its boot manager is missing or corrupted.
First you need:
To enter Recovery Console in Windows XP, you will need to boot from the Windows XP CD.
Watch for a Press any key to boot from CD... message similar to the one shown above.
Press a key to force the computer to boot from the Windows CD. If you do not press a key, your PC will continue to boot to the Windows XP installation that's currently installed on your hard drive. If this happens, just restart and try to boot to the Windows XP CD again.
  1. Enter Windows XP Recovery Console. The Recovery Console is an advanced diagnostic mode of Windows XP with special tools that will allow you to restore the boot.ini file.
When you reach the command line (detailed in Step 6 in the link above), type the following command and then press Enter.
bootcfg /rebuild
The bootcfg utility will scan your hard drives for any Windows XP installations and then display the results. Follow the remaining steps to add your Windows XP installation to the boot.ini file.
The first prompt asks Add installation to boot list? (Yes/No/All).
Type Y in response to this question and press Enter.
The next prompt asks you to Enter Load Identifier:.
This is the name of the operating system. For example, type Windows XP Professional or Windows XP Home Edition and press Enter.
The final prompt asks you to Enter OS Load options:.
Type /Fastdetect here and press Enter.
Take out the Windows XP CD, type exit and then press Enter to restart your PC.
Assuming that a missing or corrupt boot.ini file was your only issue, Windows XP should now start normally.
Apr 01, 2015 | Acer Extensa 4630z
Windows\system32\hal.dll. corrupt
Method 1
Edit the Boot.ini file to restore or correct the Default entry and to ensure that the other entries in the [Operating Systems] section of the Boot.ini file point to the appropriate directories.
For more information about how to edit the Boot.ini file, click the following article number to view the article in the Microsoft Knowledge Base: 289022 (http://support.microsoft.com/kb/289022/ ) How to edit the Boot.ini file in Windows XP
Method 2
Use the Bootcfg utility in the Recovery Console to correct the Boot.ini file:
  1. Use the Windows XP CD-ROM to start your computer.
  2. When you receive the message to press R to repair Windows by using the Recovery Console, press the R key.
  3. Select the Windows installation that you want, and then type the administrator password when prompted.
  4. Type bootcfg /rebuild, and then press ENTER.
  5. When the Windows installation is located, the following instructions are displayed:Add installation to boot list? (Yes/No/All)
    [Type Y in response to this message.]
    [This is the name of the operating system. Type Windows XP Professional or Windows XP Home Edition.]
    [Leave this field blank, and then press ENTER]. After you perform the preceding steps, restart the computer, and then select the first item on the boot menu. This should allow Windows XP to start normally.
    After Windows XP has successfully loaded, the Boot.ini can be modified to remove the incorrect entry.
Method 3
  1. Start the computer by using your Windows XP CD-ROM. Press any key to boot from the CD.
  2. After the setup files are finished loading press R to repair using Recovery Console.
  3. When you are in the recovery console, select the installation to log on to (usually number 1), and then press ENTER.
  4. Login to the Administrator account by typing the password for this account, and then press ENTER.
  5. At the recovery console command prompt, type the following command, and then press ENTER:
    For Uni-Processor systems: expand <cd-drive>:\i386\ntoskrnl.ex_ <hd-drive>:\Windows\system32\ntoskrnl.exeFor Multi-Processor systems: expand <cd-drive>:\i386\ntkrnlmp.ex_ <hd-drive>:\Windows\system32\ntoskrnl.exe Note In these two commands, the <cd-drive> placeholder represents the drive letter of your CD drive, and the <hd-drive> placeholder represents the drive letter of the hard disk on which windows is installed.
  6. If you receive a prompt to overwrite the file, press Y.
  7. Type exit, and press ENTER at the command prompt.
Method 4
Start the computer by using the Recovery Console, and then run theCHKDSK /rcommand.
Note You do not have to include the /p switch in the Chkdsk command-line because the /r switch causes the Chkdsk utility to locate bad sectors and recover readable information. This command implies the /p switch..
Jan 19, 2013 | HP OmniBook XE3 Notebook
Dell computor message on a black screen windows root \system 32\hal.dill what do I do
  5. When the Windows installation is located, the following instructions are displayed: Add installation to boot list? (Yes/No/All)
May 16, 2011 | Dell Microsoft Windows XP Home Edition
My netbook will not start because is says that the following file is missing or corrupt. &lt;Windows root&gt;`system32`ntoskrnl.exe . It says to reinstall a copy of the file but i do not know what...
hi
perapre yourself with your Winodws OS disk
then carefully read and follow these isntructions.. patience is required to sucessfully resolve this issue.
To resolve this issue, use either of the following methods.
Method 1 loadTOCNode(2, 'resolution'); Edit the Boot.ini file to restore or correct the Default entry and to ensure that the other entries in the [Operating Systems] section of the Boot.ini file point to the appropriate directories.
289022 (http://support.microsoft.com/kb/289022/ ) How to edit the Boot.ini file in Windows XP Method 2 loadTOCNode(2, 'resolution'); Use the Bootcfg utility in the Recovery Console to correct the Boot.ini file:
289022 (http://support.microsoft.com/kb/289022/ ) How to edit the Boot.ini file in Windows XP Method 3 loadTOCNode(2, 'resolution');
    For Uni-Processor systems: expand :\i386\ntoskrnl.ex_ :\Windows\system32\ntoskrnl.exeFor Multi-Processor systems: expand :\i386\ntkrnlmp.ex_ :\Windows\system32\ntoskrnl.exe Note In these two commands, the placeholder represents the drive letter of your CD drive, and the placeholder represents the drive letter of the hard disk on which windows is installed.
Method 4 loadTOCNode(2, 'resolution'); Start the computer by using the Recovery Console, and then run theCHKDSK /rcommand.
Jan 09, 2011 | Computers & Internet
How can i repair or replace boot.ini in windows xp
bootcfg /rebuild
Nov 03, 2010 | Computers & Internet
Misssing partmgr file how can I load this thanks
To resolve this issue, start the computer from the Windows XP CD, start the Recovery Console, and then use the Bootcfg.exe tool to rebuild the Boot.ini file. To do this, follow these steps:
  1. Configure the computer to start from the CD-ROM or DVD-ROM drive. For information about how to do this, see your computer documentation, or contact your computer manufacturer.
  2. Insert the Windows XP CD-ROM into your CD-ROM or DVD-ROM drive, and then restart your computer.
  3. When you receive the "Press any key to boot from CD" message, press a key to start your computer from the Windows XP CD-ROM.
  4. When you receive the "Welcome to Setup" message, press R to start the Recovery Console.
  5. If you have a dual-boot or multiple-boot computer, select the installation that you have to use from the Recovery Console.
  6. When you are prompted, type the administrator password, and then press ENTER.
  7. At the command prompt, type bootcfg /list, and then press ENTER. The entries in your current Boot.ini file appear on the screen.
  8. At the command prompt, type bootcfg /rebuild, and then press ENTER. This command scans the hard disks of the computer for Windows XP, Microsoft Windows 2000, or Microsoft Windows NT installations, and then displays the results. Follow the instructions that appear on the screen to add the Windows installations to the Boot.ini file. For example, follow these steps to add a Windows XP installation to the Boot.ini file:
    1. When you receive a message that is similar to the following message, press Y: Total Identified Windows Installs: 1
      [1] C:\Windows
    2. You receive a message that is similar to the following message: Enter Load Identifier This is the name of the operating system. When you receive this message, type the name of your operating system, and then press ENTER. This is either Microsoft Windows XP Professional or Microsoft Windows XP Home Edition.
    3. You receive a message that is similar to the following: Enter OS Load options When you receive this message, type /fastdetect, and then press ENTER.
      Note The instructions that appear on your screen may be different, depending on the configuration of your computer.
  9. Type exit, and then press ENTER to quit Recovery Console. Your computer restarts, and the updated boot list appears when you receive the "Please select the operating system to start" message.
Apr 13, 2010 | Computers & Internet
C:\windows\system32\hauurjab.dll is missing on my
Just google the error msg and you'll find the solution for it. At most times, ppl recommend you to delete this particular registry file that is associated with this dll file. But if I were you, i would better reinstall the operating system. Just google the error and give a try. Best o'luck.
Hope this helps, If so, rate me.. ,thanks - billa
Sep 05, 2009 | Microsoft Windows XP Home Edition
Windows could not start because the following file is missing or corrupt: \system32\ntoskrnl.exe Please re-install a copy of the above file.
Fix the problem
Best Method would be this one, if you have the Windows Disk.
Use the Bootcfg utility in the Recovery Console to correct the Boot.ini file: 1. Use the Windows XP CD-ROM to start your computer. 2. When you receive the message to press R to repair Windows by using the Recovery Console, press the R key. 3. Select the Windows installation that you want, and then type the administrator password when prompted. 4. Type bootcfg /rebuild, and then press ENTER. 5. When the Windows installation is located, the following instructions are displayed: Add installation to boot list? (Yes/No/All)
Nov 11, 2008 | Computers & Internet
Repair start up failure
Well it depends on how severe is your start up problem, if the OS still loads lets say on Windows XP more or less you just have to repair the boot.ini, if you have your Windows XP CD load it to your computer(make sure that on the BIOS setup the intial boot devce must be your CD ROM) When the initialization finished press R to open the command prompt the type the following;
bootcfg /rebuild
Oct 04, 2008 | Computers & Internet
Missing file or corrupt
For more information about how to edit the Boot.ini file, click the following article number to view the article in the Microsoft Knowledge Base: 289022 (http://support.microsoft.com/kb/289022/ ) How to edit the Boot.ini file in Windows XP uparrow.gifBack to the top Method 2 loadTOCNode(2, 'resolution'); Use the Bootcfg utility in the Recovery Console to correct the Boot.ini file:
For more information about how to edit the Boot.ini file, click the following article number to view the article in the Microsoft Knowledge Base: 289022 (http://support.microsoft.com/kb/289022/ ) How to edit the Boot.ini file in Windows XP uparrow.gifBack to the top Method 3 loadTOCNode(2, 'resolution');
uparrow.gifBack to the top Method 4 loadTOCNode(2, 'resolution'); Start the computer by using the Recovery Console, and then run theCHKDSK /rcommand.
Jun 23, 2008 | HP Compaq Presario 2500 HP Pavilion ZE...
Dell Dimension 4600 PC Desktop Logo
193 people viewed this question
Alun Cox
