Question about Sewing Machines
When i am sewing a buttonhole on the bernette 92c it will complete one side and keep sewing in one spot when it completes the first row of stitching. what am i doing wrong. i have the button in the holder
  • 161 Answers
Maybe you are raising it too soon so that it thinks it is finished? If it goes back to the home position it can't move any more. i suggest you practise on some scrap that is a few layers think so that everything has a good grip, and just let it run without moving too much
Posted on Sep 11, 2010
How do I make a large buttonhole ..( 1 3/8 inch).. the button doesnt fit on the buttonholer.
You do it using narrow rows of side by side zig zag stitches and bar tacking the ends of the rows. Make a line where you want the hole to be. Set the zig zag stitch width very narrow, whatever is closest to what suits the fabric. Coarse or loose weaves need a wider width, finer ones a narrower width. Experiment on some scraps to get it right. Number of stitches per inch, or stitch length, should be very fine, at least 20 per inch, but not 0. Try a few more experiments on scraps to make sure it looks right. Make a test hole to be sure it is the right size for your buttons.
Stitch a straight line of zig zags down one side of your line, with the edge of the stitching not quite touching your line. Stitch a second row directly on top of the first one.
Repeat on the other side of the line. Ideally you should still be able to just see the line you drew when the rows are done, but not see any bare fabric on either side of the line.
Then move to one end of your rows. Leave the stitch length the same, but change the width to match the width of your two side by side rows. Stitch a bar tack, about the same length as your two rows are wide. If your two rows are 1/8 inch wide, your bar tack should be 1/8 inch long. Do the same at the other end. Make sure the bar tack covers the very end stitches in the rows as it is the anchor that will prevent unravelling. This is exactly what machine buttonhole makers do, but they do it all for you.
Carefully slit between the rows to open the hole. I like to put a drop of Fray Check or something similar on my buttonholes after I cut them open. It makes them much stronger and they will never come out.
Oct 09, 2014 | Sewing Machines
Is there a way to do a manual buttonhole on a Bernette 65 since I so not have an automatic buttonhole foot
all sewing machines can make manual buttonholes. when the machine is adjustable stitch length, stitch width and needle position.
stitch length should be short.
stitch width to be set en route between 2 and 5 at the ends.
needle position must also be set on the way
you have to try and make some test before you get it right
good Luck ;)
Apr 27, 2014 | Sewing Machines
Where can I find an online user manual for Bernina Bernette 46
Hi Sheila,
I have this manual for you that might help your question. Hope it helps.
Bernina Bernette 46 Manuals
Apr 25, 2014 | Bernina Sewing Machines
My pfaff 2029 sewing machine is not completing buttonholes, one side is longer than the other
This is not uncommon. It's the stitch length balance. It is an adjustment that affects the balance between the forward and reverse
stitch. Some models have an setting that you can make to compensate. This is something that your local repair person should be able to take care of on it's own or as part of a routine service visit.
Apr 07, 2014 | Sewing Machines
I have a old Elna machine. The air electronic SU 390 B. I have lost the manual and am trying to do buttonholes on a dress. I have forgotten the sequence of nob adjustments to complete the process.
Is this the duplex model with the base that fits into a sewing cabinet?
My Elna booklet lists a SP "air electronic" duplex (CL.39), if so, then it would be same stitches as the 38, yellow front panel, 7 built in stitches and automatic knob with blue markings for buttonholing.
Here is the SU manual images for buttonholing, should be exactly the same for the SP.
tally_girl_4.jpg Instructions are:
use buttonhole foot. turn the 3 dials to buttonhole marked in blue (stitch selection, width and length).
Mark length of buttonhol on the material. Place work under foot with the mark in the middile fo the foot, the start being directly below the needle. sew the first side, raise the needle. Turn stitch width dial to 2, blue. Sew a few stitches for bartack. Raise the needle.
Turn stitch width dial to 3 blue. sew the second side. stop just short of the first side. Raise the needle.
turn the stitch width dial to 4 blue. sew a few stitches for bartack. Raise the needle.
Turn stitch width dial to "fastening off stitch" blue dot. Sew a few stitches, holding back the material by hand. Raise needle, lift pressure foot and remove work, triming off threads.
Open the buttonhole with your seam ripper (put a pin across the end to avoid any nasties).
Aug 26, 2010 | Elna 2007 Mechanical Sewing Machine
Machine will not complete a buttonhole, keeps showing error code 6L. No error code listed in manual. Machine will only do first half of buttonhole and then shows code and stops.
I've been looking too and I found here http://sewing.patternreview.com/cgi-bin/sewingclasses/board.pl?t=18328that you need to put the bar behind the needle threader down. I think they call it a button hole stop? I don't know, but it worked. I didn't even know it existed. But it solved my problem. On my Kenmore it looks like a black lever and you pull it down. It tells the button-holer that you are at the end of the hole and it needs to backup. nifty, kind of.
Apr 16, 2009 | Sewing Machines
Buttonholes
First be sure to follow the steps described in the manual for attaching the buttonholer.
Second, check that the buttonhole lever is pushed because it returns to it's unpushed state after a buttonhole is completed and therefore it will stitch in the same spot.
Also, try adjusting the stitch length. I've found that I can't make buttonholes while on the satin stich setting ( that little rectangle) but if I move it just a bit towards 1 it will manage to make the right stitches.
Feb 11, 2009 | Brother XL-5700 Mechanical Sewing Machine
Buttonhole
I'm afraid that you are unable to correct this glitch on your own. Any sewing machine service center/shop will do...call around and look for the shop with the lowest 'minimum' charge. It is such a simple fix. However, although simple, the adjustment is so incrementally precise that without thorough understanding, your stich patterns could be rendered unuseable. I have no idea of the current value of your sewing machine, but if you deem the repair costs prohibitive, there is a workaround so you can complete your buttonhole. Complete your buttonhole setup as normal. I assume that you run tests first to adjust your stitch length/density of the buttonhole using the Step 1 setting. When you find the the length/density that you want, using an ink marker/crayon...whatever...being as precise as possible, mark a linear line from the edge of your length selector dial, continuing to the body of your machine. Now, select Buttonhole Setting #3, and increase the stitch length until you see the length/density that you want. Find a clear spot on your length dial and repeat the marking procedure. When you are ready to make a buttonhole, align the markings for Buttonhole Step 1 on your stitch length dial and proceed, complete your tack of step 2, stop, manually raise your needle out of the fabric using the balance (hand) wheel on the right, adjust your stitch length dial accordingly for Step 3, then on to your final tack #4. If it's only your buttonholer that is giving you trouble, take the extra 15 minutes or so, and use the workaround and mark your machine. It doesn't have to be ink, it can be pinstriping tape...whatever, and spend the money you saved on fabrics and notions instead.....good luck my friend.
Jul 27, 2007 | Singer 2732 Mechanical Sewing Machine
Sewing Machines Logo
108 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
