Micro Advantage 64 MB Quick Drive
Somehow my drive now will not let me write to it. It tells me that is "READ ONLY" and I haven't, knowingly done anything to cause that. Any suggestions on how to fix this?
  • ned1410
    ned1410 Aug 25, 2012
    Formating from the command prompt does not work in Xp, Vista or Windows 7
  • 37 Answers
Try formatting it from the command prompt.
the command line is 'format drive' . drive is the corresponding drive letter.
Posted on May 13, 2008
How do I switch/upgrade my motherboard from a 32bit to a 64bit please
Having a 32-bit or 64-bit operating system mainly depends upon the operating system that is loaded on your primary hard drive (generally drive C:). However, your motherboard's components, i.e., processor and amount of system RAM, will be a major factor in determining whether you can only run a 32-bit operating system, or upgrade to a 64-bit system.
Sep 22, 2014 | Computers & Internet
ASUS M3A78-EM stopped seeing second drive
update your drivers and check the cables out as well
Jan 01, 2013 | ASUS M3A78-EM Motherboard
Micro advantage 64 mb qiuickdrive is write protected
You have to be the computers administrator to change any values on any hard drive on your computer
click start control panel user accounts on the users tab click the name of the computer administrator you must have full control
click start click to open on my computer you should see your usb drive could be E: or something right click select properties there will be an array of options
select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box
then click permissions make sure you have all 3 boxes ticked full control changes and read in windows 7
click start control panel user accounts click on the administrators account if you have made one or you will have to create one in windows XP
click start right click on my computer select open
Right click the icon of your usb drive (It should be E:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
if you need more help with this post a reply
then you might restore it to its default status
Right click on usb drive select properties you will have an array of options
Select the hardware option then select your drive properties policies
restore defaults
In XP
Right click on your drive select properties then on customize restore Default in W 7
If you need more help with this post a reply
hope this helps
Aug 25, 2012 | Computers & Internet
I would like to install a second HD on my HP Pabilion a1540n desktop. What are the specs so I can buy it.
HP Pavilion Media Center a1540n Desktop PC Product Specifications
Hardware Base processor Athlon 64 X2 (W) 4200+ 2.0 GHz
  • 2000 MT/s (mega transfers/second)
  • Socket AM2
Chipset GeForce 6150 LE Motherboard
  • Manufacturer: Asus
  • Motherboard Name: A8M2N-LA
  • HP/Compaq motherboard name: NodusM-GL8E
Memory Component Attributes Memory Installed 2 GB Maximum allowed 4 GB* (4 x 1 GB)
*Actual available memory may be less Speed supported PC2-4200 MB/sec Type 240 pin, DDR2 SDRAM Hard drive
  • 250 GB SATA
  • 7200 rpm
16X DVD(+/-)R/RW (+/-)R DL LightScribe drive
  • Must use Double-Layer media discs in order to take advantage of the DL technology
  • Must use LightScribe-enabled media discs and supporting software in order to take advantage of the LightScribe technology
Sep 04, 2011 | HP Pavilion a1540n PC Desktop
I recently bought a Scosche Digital FM Transmitter Model FMTD8/FMTD8R. I loaded my 8GB San-disk flash drive with music but the transmitter won't read it.. doesn't even detect the flash drive being...
wma files won't be read, only mp3 files, in my experience. My 512 mb SD card works, but it won't read my 8 gb SDHC card. I suspect it can't manage SDHC (high capacity) cards. I haven't tested yet, because as it turns out, neither can my computer... I think I'll fall back to a flash drive.
Jun 11, 2011 | GPS
4GB drive has only 1.1 MB available after removing items from drive.
I have NO IDEA why it would do that, but plug it in, go to my computer, find the disk, right click, and select format. do a quick format. that should fix it.
Jan 13, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
The flash drive no longer works
Broken flash drive huh! Sorry to hear that.
Check out this blog: http://www.flashdrivepros.com/_blog/USB_Flash_Drive_Data_Recovery_Blog/post/Help!_Windows_No_Longer_Recognizes_My_Flash_Drive!/
These guys do flash drive data recovery as well, if this thing doesn't work. Best of luck to yah!
Mar 03, 2010 | Micro Advantage 128MB Quick Drive. Price...
Where is the RAM SIMM Slots in a NEC Versa LX?
Hi
The SO DIMMs (RAM) slot is located below the keyboard on these.
Just a quick note:
Installed Size: 64 MB / 256 MB (max)
Technology: SDRAM
Form Factor: SO DIMM 144-PIN
More info - http://www.nec-computers.co.uk/support/pib.asp?mode=default&platform=platform_a2
Mike
Mar 27, 2008 | NEC Versa LX Notebook
Cruzer 2 GB
Right-click on the Sandisk in My Computer and select Format... Click start and wait a little, once it's done you should have access to the entire drive.
Jan 10, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Computers & Internet Logo
157 people viewed this question
David Payne
David Payne
