Question about Epson LQ-2090 Matrix Printer
My epson LQ-300 II is having paper jam while printing
5 Suggested Answers
Riztech
  • 731 Answers
SOURCE: Sending Reverse Line feed to Epson LX-300+II USB printer
Hi Shery,
I went through the manual of LX300 printer series.I believe that if u read that manual, you can Fix the problem as it has all instruction about the Reverse feed and pull tractor mechanism.
Download Manual
http://ftp.epson.com/pdf/lx300p/lx300ppg.pdf.Any issue contact me.
Thank you
Riz (zyrixdown3@gmail.com)
Posted on Feb 11, 2008
printech
  • 159 Answers
SOURCE: Epson LX-300+II, the font problem
yes you can change the font tray to print the printer internal setting tray that press and hold any key by tarn the printer off then on after you tarn the printer on release the key
Posted on Sep 06, 2008
SOURCE: EPSON LQ - 2180 paper settings
I HAVE CUSTOME SIZE OF PAPER WHICH IS NOT AVILABLE IN THE PRINTER LIST .WHEN I DEEL WITH WINDOS XP
BUT WHEN DEEL WIHTH WINDOS 98 ITS OK
NO I DONT HAVE WINDOS 98 . MY QUESTION HOW I CAN ADJUST PAPER TO CUSTOM SIZE
Posted on Nov 24, 2008
dana_eng
  • 41 Answers
SOURCE: my printer EPSON LQ-2180 send me an error code "paper out"
Hi Soulen , This link is very interest and useful for your type of printer : http://files.support.epson.com/pdf/lq2180/lq2180pg.pdf
and also for driver open this link : http://www.driverstock.com/Epson-LQ-2180-driver-download/23-26-3157-53410/index.html
Posted on Jan 22, 2009
Lq 300+ii paper size setting
It works well with WINDOWS XP but how can i make it work with WINDOWS SERVER 2003
Jan 11, 2013 | Epson Dot Matrix LQ-300+II Printer
LQ 300 +2 auto pause during printing
This is a feature provided by the manufacture to protect the print head overheat for small dot matrix printers. Here giving printer head connection diagram, the last two row have temperature sensing (thermister) connection pin 1 to 1. If the thermister is faulty in the print head the printer will auto pause abnormally. Check the printer with compatible / EPSON recommended print head. These kind of small printer only for POS printing not for continues printing. 2_17_2012_8_31_04_am.jpg
Feb 16, 2012 | Epson Dot Matrix LQ-300+II Printer
CANNOT INSTALL THE EPSON LQ 300+DOT MATRIX PRINTER ON THE WINDOWS 7 NEW PC
Epson LQ 300 does not have Win7 latest driver. Please use your old PC (xp or visita) to continue with the Epson.
Aug 28, 2011 | Epson Dot Matrix LQ-300+II Printer
I want printer driver for Epson lq-300+ for windows xp sevice Pack 3
windows xp already has driver for that
go to start, setting-printer and faxes- click add a printer
add wizard printer box will apear
click next
set yo local printer uncheck automativaly detect
click next the use following port lpt1
next again
then search epson and the printer model
then click next and next set print test page then next and finnish..
the driver will install..
Aug 22, 2011 | Epson Dot Matrix LQ-300+ Printer
Hi, One of our client using epson lq-300+II dot matrix printer to print their invoices in custom defined paper (using crystal report). It was working fine when they were using windows xp. Now they...
Hello, Please, if you can change back to the former operating, is either the printer type is not compactable with the new windows(Windows7). But first you have to check the net to see if you can try upgrading the software of the printer. Please if you've done this let me know what happened next.
Mar 26, 2011 | Epson LQ 300+ Matrix Printer
How do I get the macaddress of the Epson LQ-300+II?
If the dot matrix printer does not have a built-in network card then it will not have a MAC address. Dot matrix printers are very old printers and I have not come accros any with built-in network card or print servers.
The dot matrix can be connected to a network print server and this will have a MAC address and a configurable IP address.
Oct 22, 2009 | Epson Dot Matrix LQ-300+II Printer
Epson print LQ-590 always paper jammed at roller when printing continuous 5 sheet of paper. May I know how to fix this?
the paper you are using may be moisten. pls try another paper sheets . purchase new papers.
if the problem continue clean the paper feeder assembly roller with moist cotton using cleaning liquid eg petrol or spirit etc.
Aug 21, 2009 | Epson LQ-590 Matrix Printer
My Epson LQ-590/LQ-2090 keeps having paper jams located just beyond the tractor feed.. help
When a paper jam occurs during printing for some reason, the printer beeps, displaying the message <PAPER JAM> in the display. When a paper jam occurs, remove the jammed paper using the following procedure, and then resume the job. If the message that indicates the paper jam does not disappear even after removing the jammed paper following the procedure, there is a possibility that torn pieces of paper are still left inside the printer. Inspect each part of the printer again, and completely remove all pieces of jammed paper.
Jun 23, 2009 | Epson LQ-2090 Matrix Printer
have you check the white cable? (from the printer head to the
mainboard) .If the white cable is ok and you confirm that the
printer head is fine, then the problem is at the mainboard.
most problems like this that i had encountered is at the transistor
at the mainboard. Try to check it out using a multitester.
Sep 06, 2008 | Epson LX-300+ II Matrix Printer
Epson LQ-2090 Matrix Printer Logo
291 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
