Question about Hotpoint NVL333EY Electric Dryer
Need help putting drum back in place
Can not get drum back in place, I think it has came loose from the plate behind the drum , Please help
    Genius:
  • 1,073 Answers
The tub rear shaft goes into a rear bearing inside the middle of the heater housing it has to be just right aligned to go in to the hole be patient and you can get it to align
you do have to remove the frount panel to get it to line up
Posted on May 11, 2008
Where does the spacer go that fell out from behind air filter back plate when I removed bolts
If the spacer is like a small tube and the bolt will slide into it, it will probably need to be placed between the the back plate and the place that the bolt threads into. If you look at the back plate you may be able to see the outline of where it was. Sometimes reassembly is easier if you can put the bolt and spacer in place in the back plate and then put it into place.
Mar 06, 2015 | Cars & Trucks
I HAVE A SMALL WAER LEAK COMING FROM ABOVE KICK PLATE ON FRONT LOAD WASHER MODEL NUMBER WFS1071AW. ITS NOT THE FILTER OR DOOR THAT ITS LEAKING FROM BUT SOMEWHERE ELSE
The penny trap sits behind this plate and may have worked loose.retighten it and also check the tiny tube plug to the side which is a drain to empty drum before transporting from one place to another.
Jan 13, 2015 | Washing Machines
How do i access the fill pipe on a hoover WMH148DF
the fill pipe goes thru the soap tray to the fill to the drum
so remove the soap tray drawer
usualy behind the drawer is the screws to release the inlet matrix
you may find you need only re- attach the pipe with little sruggle
i use some evostic glue let it go tacky place the tube back then tease the clip over with plyers
this forms a good seal
i think perhaps a drum suspension piston isnt so hot
if its throwing pipes off...!!
Nov 23, 2014 | Hoover Washing Machines
How to remove drum from shoes. very worn
On the back side "backing plate" behind drum, there's a small opening in the bottom (sometimes they have a black rubber oval plug) remove plug (if equipped) insert straight blade screw driver and try turning adjuster
Jan 18, 2011 | 2005 Chevrolet Silverado
How do I get a frozen drum to break loose? I have a 1998 Dodge Ram 1500.
These can be tough to get off. as they like to sieze around the axle flange. I use an air hammer with a flat bit and rattle around the center hub on the drum which usually will shake them loose but if you don't have that tool then I would spray penetrating oil around where the axle hub protrudes through the drum and around each wheel stud as the oil will creep down behind the drum and help loosen the rusty grip it has on the axle. It can take quite a while for the oil to creep in there [an hour or so] Once you have the drum loose it often will catch next on the brake shoes [due to a lip that wears on the outer edge of the drum] as you try to slide it off. If that happens you have to manually loosen up the brake shoes a bit through the inspection plug on the backside of the brake backing plate. The bad news is that sometimes the adjuster is stuck and won't move or there isn't even an inspection hole to start with which makes it very difficult to work the drum off over the shoes.
Jun 16, 2010 | Cars & Trucks
Need to replace rear brake rotors on 2003 Exp Sport Trac. can't get rotor off. see 4 nut behind assembly, believe they need to come off. once brakes off, how will that effect the e-brake/drum brake system,...
The rotor is not bolted on , the lugnuts from the wheel / tire holds the rotor in place. Once the caliper is removed , you will need to free the rotor from the wheel bearing/hub assembly . A large hammer will be required if rusted to the hub, then you may need to back off the e-brake shoes through the slot in the back of the backing plate, you must use a brake spoon and a pick to back off the adjuster to allow the rotor/drum to clear the ebrake shoes. please rate my answer, this helps me out , Thankyou have a great weekend. RJ
May 30, 2010 | 2003 Ford Explorer Sport Trac
Rear brake drums won't come off
Try penetrating oil around center hole and 8mm holes if rust is present. Then, pound hard on the radius edge between face of drum and top/bottom braking surface.
If no luck, you might need to back off the shoe adjustment rod located behind an oblong hole on the bottom of the backing plate.
Youll see small teeth if you view through the oblong hole(might have a rubber plug in it)
Put a screwdriver in the hole and try to ratchet the teeth in one direction or another (it will only go in one direction) once you see which way it moves, usually with a corresponding "click", Stop........you need to turn it the other way.
To do this, you must take a small thin screwdriver or ice pick and poke it in past the small toothed gear until it hits a surface. Put more pressure and you should feel it move.
This is the ratcheting arm that kept you from moving the gear in the other direction.
Now you should be able to turn the toothed wheel in the opposite direction to loosen the brake shoes from the braking surface of the drum.
The 8mm bolt holes are there to help pull the drum, but, if the shoes have worn into the drum a lot, it leaves an edge on the inner edge of the drum which wont let the drum slide past the shoes, which is why you need to back off the adjustment rod to pull the shoes away from the drum to allow it to be removed.
If all else fails, the shoes are held against the backing plate by two pins, held in place by small coil springs and keeper plates.
If you look at the backing plate, you should see two small circular discs at the roughly 3 oclock and 9 oclock positions. These are the heads of the keeper pins which hold the shoes on to the backing plate. Take a small and preferably sharp chisel, and shear these small discs off the backing plate. Now, you should be able to pry off the drum and survey the damage. You will need to replace these parts. Ask your parts dealer for a "spring kit" for the rear drum brakes of your particular vehicle.
Hope this helps
Aug 17, 2009 | 2001 Suzuki Swift
How to remove the drum
before you take the drum out please do one simple check to see if the bearing have worn out.open the door and lift the silver drum inside up an down now if you ear a knocking noise or feel a knocking vibration then it definately the bearrings have gone.
Jul 06, 2009 | Washing Machines
Need to know how to reattach the dryer drum
ouch budddie...happy new year ...looking in the dryer are you taking about those there center mass,,,if that attactes the back bearing surport to the drum...,,if that the two parts which i think your talking about ..you have to take the drum all the way out,,because those three screws are shape like a piece of pizza....it will never line up with drum in...
Jan 01, 2009 | Frigidaire Dryers
Wont spin out
I had a similar problem, but the precursor to this was a loud squeal when the machine came to a stop at the end of spin cycle. This squeal lasted for a couple of months (since I was afraid to take it apart). The one day there was a leak during the drain cycle, so I looked behind it and found the flex hose that goes between the drum and the pump. I replaced the hose after about a week, and when I tried to use the washer, it did not spin anymore. So I turned the washer upside down, pulled the drum out, and found a big 'caution' tag on the plate, but don't be worried. Out of the 6 screws that hold the plate on, I took out three opposing ones and bought 3 of the same pitch but only that they are 2" long. Then I put a nut on each one, and put them into three opposing holes in the plate. Run the 3 nuts down to the plate, then take the three remaining short screws out. Slowly back off the three nuts equally, and within 1.5" the plate is safely off. Then I lifted the spring out along with the brake drum. The drum had rusted itself in place. This was because of the water hose leak. So I sanded the brake drum lining lightly to remove the glaze, and sanded the place where it was rusted to. Then I put it all back together, and it works like new!
Nov 01, 2008 | Maytag PAV2300 Top Load Washer
Hotpoint NVL333EY Electric Dryer Logo
167 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
