Question about Indesit W 123 Front Load Washer
A few weeks ago the machine (IWDC 6125 S) started to flash against all the options at the top. I had turned it on an off and it was working OK. Just yesterday the door was shut, but the machine would not register that it was closed. Come to check on it today. Nothing is happening at all. I have checked the water connections and the power, though the indicator lights are all working, changed the cycles... still nothing. What can I do?
  • 86 Answers
The only quick suggestion I have is to unplug it for several minutes and see if it resets. If not, without any other indicator, the only thing I can think of is the door switch, which should be a fairly easy fix.
Posted on Jul 04, 2017
  • 66 Answers
SOURCE: indesit wil 103red door light ordinary flashing.load the machine normally but nothing will light continues to flash on its own slowly.
would try changing the interlock unplug first regards jason
Posted on Jun 15, 2008
SOURCE: Flashing lights
Turne off at the wall Hold the power on button then turne it on at the wall that should reset the system
Posted on Jan 11, 2009
  • 56 Answers
SOURCE: WIDL 126s Wahing machine fault
could be mains filter . unplug from wall and remove top look at where the cable goes into machine are any of theses wire's burned . keep a note of were they go .
Posted on Feb 12, 2010
SOURCE: I am looking for an online manual for an Indesit
Right. Go to the Indesit website. Find the model. There is an option on this screen to download the manual.
Posted on Mar 01, 2011
  • 4 Answers
SOURCE: my indesit moon washing machine
Could be a jammed pump, or bad connections to the main motor brushes
Posted on Oct 06, 2011
My washer/dryer model iwdc 6125 will not dry clothes properly they come out hot steaming and wet its only a year old
Check the vent hose for lint build up. If it goes into a wall, be sure there is no obstruction. The dryer has a flow sensor that detects a reduction in airflow out the vent hose. It will shut off the heat to prevent a vent fire.
Oct 24, 2016 | Washing Machines
Hoover hnl7146 wont empty
program board possible failed
call a technician to have a proper diagnosis done to save guess money
May 07, 2017 | Washing Machines
This is a known problem with this model. Call 800-847-9083 and give them the model and serial number to see if your unit is covered by a recall on the control board. I called a few weeks ago and they sent the part and a tech to install it for free on my 3 year old machine.
Apr 29, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
For the past few years the small fuse in the washing machine blew about once a year. A few months ago it seemed to blow every week. Then it was fine again. Now I replace the fuse and as soon as I turn on...
One says the lid switchs are not working in tandem with each other. Another says the circuit board is bad. I say it is because it is a Maytag and built with an obsolete ethical plan for generating profit.
Dec 29, 2009 | Maytag LSE7806A Top Load Stacked...
Dell inspiron 6400 notebook wont turn on
try this with battery removed first..
plug in ac power, no battery,
then when turning on machine, press F8 to go to safe mode(pick the top option)
see how that works forya
Jun 14, 2008 | Dell Inspiron 6400 Notebook
Please help
it is the timer or, it may be a short of some kind
Apr 19, 2008 | GE WDSR2080D Top Load Washer
Dishwasher flashes on Fast Wash
I am hoping I have just fixed mine with same problem. Couple weeks ago started stopping at start of cycle with fast button flashing. Check filters so one on top of unside machine and one on tap if you have one on there. Mine were blocked but still wouldnt work. I pulled out machine to find a kink in the water pipe. I have straightened this out and up to now its working. Fast button flashing refers to water inlet problem.
Feb 27, 2008 | Dishwashers
HP Media center 1170m
did you checked the ram just clean and fix it again. bye
Oct 01, 2007 | HP Media Center m1170n Photosmart PC...
Sound, but no picture. Standby light blinking 5 times
A few weeks ago my set started flashing to a black screen. Now a couple of weeks later, i have no picture, but the set turns on and i have sound. The standby light is flashing. I purchased the set in 2000 so it is seven years old. This is the first problem. Could it be all three of the bulbs? Could it be all three of the bulbs? no as you say that sound is ok that means your power supply &high voltage section is ok. please check chroma ic luminance section or system control section stand by ckt ihanks
Sep 11, 2007 | Sony KP-53HS10 TV
Indesit W 123 Front Load Washer Logo
155 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
