Question about E-Machines eMachines T3830 PC Desktop
Cooling fan makes loud noise upon starting machine, its not even a year old
    President:
  • 1,851 Answers
Open the side panel of the computer. The inside of your eMachine must be like this:
The only fans in the case are the one inside the power supply and the one over the cpu heatsink. Take a look for something like cable or tire-up to come too close at the cpu fan. In this case take away this cable or tire-up and keep it in a safe distance. Try the results. If the problem is still active try this tip very carefully. Use a drinking straw as brake for the cpu fan. Hear the difference in noise. If the noise is dissapeared your cpu blower needs replacement. KEEP IN MIND THAT YOU MUST NOT RUN THE PC WITHOUT CPU FAN FOR MORE THAN 5 SECONDS. OTHERWISE YOUR CPU WILL BURNED.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on Sep 02, 2010
    Sergeant:
  • 235 Answers
Probably a wire rubbing against it. Open the case the move the wire or connector out of the way. You might have to use a plastic tie to keep it out of the way. If that does not work then replace the fan. They're not that expensive and easy to replace. Good luck!
Why does Miele w2515 makes loud banging noise when it is about to spin?
See if you can level out the unit. Sound like the case is responding to un-even pressures.
May 23, 2014 | Washing Machines
Hp laptop hp 430
Maybe the cpu fan is fubar - check that out.
Mar 18, 2017 | Computers & Internet
New Cooling Fan is Very Loud
might be a fan with a faulty bearing lubricate it by pulling the sticker off and the cover then use some oil NOT WD40 if this doesnt work then get another fan
Dec 08, 2012 | Compaq Presario CQ56110US Laptop
My samsung fridge/freezer is only 3 years old, just started making loud noise, then when the fridge is opened sounds like the fan making a loud noise that goes down and stops. Then not long after that...
Compressors usually make a thrumming/humming noise, so yes, this sounds like the fan. It could be something touching the fan blades, like ice or a wire. If you can unplug the fridge and remove panels near the fan, you may discover the problem.
Jun 06, 2012 | Refrigerators
I have a Dell inspiron 1525...I have found that now, after a year and half the fan has become loud and noise. So noise, I wake up in the middle of the night, hearing my computer cooling b/c the fan is so...
you need to buy a new fan, your fan is about to give up the ghost. if you let the fan die while the pc is running, it might burn out the cpu.
fans are very cheap, like a few dollars, and do not always last forever.
Nov 06, 2010 | Dell (6F858) Cooling Fan
I have a model GE JVM1653BD 001 microwave. Sometimes when it runs it makes a loud growling sound. It appears to be heating normally though. Intermittantly makes this noise.
I have the same model ending in 003, and it has made this noise for most of its life of several years now. Every now and again it runs quietly.
My theory is the cooling fan (not the hood fan) is making noise. The problem began within the first year of operation, and up till now everything is in good working order otherwise. There is no odor of failing parts.
My installation book has no electrical circuit diagrams, and I came upon your question when searching the topic.
Oct 31, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Fridge making loud noises occassionally
the noise can be from the fan next to the compressor or the fan in the freezer.
check them when you hear the noise if they tuch something or they might need to be replace b/c of berring problems...
Jan 06, 2010 | Refrigerators
Hi, my refrigerator is making a loud noise and it stops and starts about every 12 minutes. It is cooling fine. Can you help me? It is a side-by-side model that is only 4 years old. Thanks. This problem...
Good day,
Open the freezer door, and see if you can hear the fan motor, that is located behind the rear panel.
If it's the source of the noise, then you will have to remove the rear panel to access the fan motor.
If not, go to the back bottom of the machine, remove the back cover and see if the cooling fan motor that cools the condenser and compressor s working properly.
If it's alright, then it will probably be a problem with the compressor itself.
STOP !! The compressor has one year left on it's warranty.
Call your selling dealer for warranty service. This is an expensive repair and altering the machine can void the factory warranty.
Thank you for using FixYa
Jan 05, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have the Marvel 70 bottle wine cooler and it is making loud whining noise like if you put a stick in the wheel of spinning bike spokes when it is cooling down sometimes. it does not seem to be the fan...
I believe the 6SBAR has an evaporator fan located behind the evaporator plate ( the cooling plate) inside the unit. They had some issues with the bearings in those fans failing and will sound like a small jet engine sometimes (high pitched whine). When you hear the noise, open the door and if the noise level changes (either gets louder or goes away) then it is the evaporator fan. If your noise is coming from the compressor area and does not change when you open the door, it is most likely the condenser fan blade is loose. The evaporator fan looks like a small computer cooling fan and is located near the bottom center of the evaporator plate (out of site). The factory sells a replacement kit with a much better fan and new power supply. You can reach them at 800-223-3900. Good-luck.
Nov 19, 2009 | Marvel (6SBARBSG) Wine Cooler
Turbo Chef hi speed oven prblem with 2004 model very loud fan
is this a c3 or a tornado oven.there are afew causes for that type of noise but are diffrent for each type,regards les
May 08, 2009 | TurboChef C3 Single Oven
E-Machines eMachines T3830 PC Desktop Logo
130 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
