Question about Electric Intermatic Inc Wh40 Water Heater Timer Single
Have wh40 model. I switched out motor, but when put back together a piece fell out and not the on/off switch is loose. I do not think switch is working unless I can get the u shaped piece back in.
The WH40 on-off switch is a manual override. Using the switch, you can turn power on when timer has power turned off. However the manual override is also the piece that the timer pins contact to mechanically click power on-and-off.
So if the on-off switch is broken, the timer will not work. Looking at the Wh40 sitting in my office, I cannot see the exact part you mention, but it looks like the on-off-switch is not a repairable part. And it would not be easy to work on, since the yellow timer dial does not come off.
You can buy a new WH40 and then swap out the insides. Keep the same box and just snap in the new timer. However the new WH40 on-off switch sticks out so you may have to leave door open on the old box.
Here is a photo comparing old and new WH40:
http://waterheatertimer.org/images/WH-40-2-450.jpg
Posted on Sep 04, 2010
Need help with the lid latch
Yeah, I would say that your lid switch came apart. Seems to be a common problem with lid switches made out of plastic. I think that it comes from people placing heavy things on top of the washer. Like themselves during the spin cycle. And it puts too much pressure on the switch making it come apart.
I go to repairclinic.com a lot with model numbers to find manufacturer part numbers. Then take that number and plug it into ebay. For this model I found W10059230 to be the part number. Found a lot of listing on ebay for really good prices. Amazon is another good source for parts for low prices.
As for putting the switch back together there is no way to do so and it work correctly. It will need to be replaced.
Youtube videos is another good source on how to do things. People have been nice enough to post hands on videos of a lot of different things. Great learning source.
Mar 20, 2014 | Whirlpool Cabrio WTW6600SBT Top Load...
How to put motor and blade sections back together?
There are two phillip head screws holding the blender end together where it came apart. They are hidden under plugs on either side of the imprinted information. Simply drill a hole in each plug and remove them by putting something in the hole (small screwdriver) and pulling them out. Loosen the screws, enough to pull the body apart far enough to insert the blender end back in. Tighten the screws back up and your good to go. I left the plugs out, they don,t serve any purpose.
May 16, 2013 | Cuisinart CSB-33 Quick Prep Handheld...
The TechDrive Pedal on my Kirby G6 fell out of the back of my vacuum cleaner. I removed the screws from the metal plate one the bottom to try to see if something had come a loose. Can you send me a diagram...
This requires removal of the transmission assembly and replacement of the pedal assembly - it cannot be repaired. The handle and upper motor shell must be remove to access the transmission assemby. There are two screws in front, and two under the plastic switch plate.
Jan 18, 2011 | Kirby G6 Bagged Upright Vacuum
Agitator will not spin
check the lid switch first,lift the lid a couple of inches and close it down,if it clicks the lid switch is good and you most likely broke the motor coupling.remove the twoscrews that hold down the top console,lift it up and with a screw driver pop the metal clips and disconnect the lid switch wires in the middle,it's a white platic connector,now remove the whole cover of the washer,down the bottom you'll see the pump.with a screw driver pop the two metal clips and remove the pump,next remove the tow screws and clips holding the motor in place and pull out the motor,on the back you'll find the coupling,there should be two pieces of white plastic with three arms on each piece and a black piece of rubber that goes in between the two white pieces,remove the old coupling and tap on the new pieces one on the motor shaft and the other on the tranny shaft,slide the rubber piece on the tranny part of coupling and then line up the other piece that's on the motor shaft slide it together and put everything back,it's easier than it sounds,let me know how you make out,if you sent the model number i could of gave you the part number,i think it's PL337
Aug 13, 2010 | Kenmore 22422 Top Load Washer
When checking out the lid switch on my roper washer as jsrock suggested in another post, i heard a screw drop from the inside of that area which caused the lid switch to become unmounted completely. also,...
Top lid pull up. Look in seam between top and front cover. On each side you will see where top clips to front cover. Put a screwdriver in there and lightly pry up till clip releases. Front cover will now pull up and be removed, so you could get what fell in.
Jul 26, 2009 | Roper RAS8445KQ Top Load Washer
Garmin Charger fell apart
Yes. Call Garmin up and tell them the pieces came off they will send you free pieces (covered under warranty) just tell them that you know how to put it back together and you can see images online of how it should loo kafter it's put back
Jul 14, 2009 | Garmin nuvi 205 GPS Receiver
Idler pulley came loose and I need schematic so I can put it tog
the idler pulley fell out of its slot or it broke into pieces
if it just fell out of the slot you should take out the drum and just kind of play with it  depending on the dryer if you gave me your model i can take a look  and i dont know what kind of idler pulley you have so i am not much help AT ALL without it i;m sorry
Jun 08, 2009 | Kenmore 62622 Electric Dryer
Windows and sunroof won't go down and lights won't turn on
that swiths is broken don't weist your time, like you said you can install part your self just buy a new swiths
Mar 17, 2009 | 2000 Volkswagen Jetta TDI
2000 Jetta windows and sunroof won't go down
Are you referring to your headlamp switch?
Apr 22, 2017 | 2001 Volkswagen Jetta TDI
Electric Intermatic Inc Wh40  Water Heater Timer Single Logo
56 people viewed this question
Top Electric Hardware & Accessories Experts
Brandon Berry
Brandon Berry
ray gallant
Are you an Electric Hardware and Accessory Expert? Answer questions, earn points and help others
