Question about Sylvania 6720FDD 20 in. TV/VCR/DVD Combo
I have a sylvania 110 voltage and was used in a 220 voltge extension wire. Can it be repaired?
  • 11,896 Answers
Either you got lucky and just the few blew inside. Or worst case is the power inverter blew and will have to be replaced. You can test the inverter with a voltmeter. You can look at the glass bus fuse itself to see if it is bad or not.
Posted on Sep 02, 2010
What spect of voltage conventer transfer to convent the Voltage 110 to the 220-240 V printer??
110 volt to 220 power converter 220 volt to 110 voltage ...
www.dvdoverseas.com/voltage_converters.htm
110-220 volt voltage converter power transformer 220 volt voltage converters 240 ...run on 120 volt 60 cycles (60hz) and most of the worlds run on 220/240 volt ...
Oct 07, 2015 | Canon F151300 LBP 3100 Mono Laser Printer...
Can it run on either 110 or 220?
There should be a label on the motor that explains the capability.
A very advanced table saw may have a motor that can be wired for either 110 or 220. The table saw I can afford would have a either a 220 or 110 motor.
Apr 28, 2015 | Saws
Wire 110 to 220
If you have a 110 volt appliance, all switches , wiring and components are made especially to handle that voltage. If you feed 220 to 240 volts into it, most certainly the machine will be unsafe and likely fail in a very short time. Purchase a step down transformer to reduce your supply voltage to 110. Most good electrical parts stores should be able to supply this.
Jun 26, 2014 | Craftsman Air Tools & Compressors
I have a electric dryer Model WED5810SW0 THAT I WAS TOLD I COULD CONVERT TO 120V from 240v is this true and if so how do i do this?
If you consider doing this the first thing is SHUT THE MAIN BREAKER OFF. Use an auxiliary light source to see when working in a dead panel. Always keep in mind an ARC FLASH ACROSS HOT MAINS HAS ENOUGH HEAT TO PEAL THE SKIN OFF OF YOU. Before an explanation of how to do it you should keep in mind that this is for a single receptacle only. If any other receptacles are on the same circuit they will also be changed to 240 volt receptacles and if you plug any 120 volt device into them, the 120 volt device will be destroyed. That said OK, any 120 volt outlet can be changed to 240 volt by removing the 120 volt circuits neutral, re identifying the white wire with red or black phase tape and connecting it to a new 2 pole 15 amp breaker. The maximum that this circuit will now load up to is, on #14 wire at 80% = 12 amps at 240 volts. The 120V receptacle must be changed to a 15A - 240V receptacle so that 120 volt devices can not be plugged into it. Never use 2 single pole breakers together because code requires that on a fault trip both legs of the 240V circuit must be disconnected simultaneously. OR USED A Quick 220 Voltage Converting Power Supply
Voltage converter buying guide. Voltage Transformer Buying guide.Voltage converters also known as voltage transformers are devices that convert foreign electricity to power devices from different parts of the world. A step down voltage converter is a 220 to 110 volts converter. A step up converter is a 110 volts to 220 volts converter. Our 2-way converters are voltage transformers that convert power from both 220 to 110 volts and 110 to 220 volts. They also work with 100 volts, 110 volts, 120 volts, 220 volts and 240 volts. This model is a 2 way voltage converter / voltage transformer available in many different sizes including 100 watts, 200 watts, 300 watts, 500 watts, 750 watts, 1000 watts, 1500 watts, 2000 watts, 3000 watts and 5000 watts.
Sep 07, 2011 | Whirlpool Dryers
Need wiring diagram for 1081 motor,1.5hp.I want to change from 220 to 110.
What is the reason you want to change? 220 is not only stronger ... it is cheaper to run. If wiring is a problem, (this pump should be on its own circuit) simply replace the single pole breaker with a double pole and take the existing white wire and turn it into a "red" wire for your 220, (put the white (red) wire on the second pole of the new breaker.)
If you will remove the cover on the back of the motor, you will probably find a plug that you move from the 220 position to the 110 position. Change the plug from 220 / 20 amp to 110 / 20 (or what ever the motor will require) Normally, when you change the voltage in this direction (down) you send the amps up by 2 times. What I mean is if the motor uses 7.5 amps at 220, you will be using 15 amps at 110. Make sure you have at least #12 wire for a little extra safety.
Thanks for your interest in FixYa.com
Aug 09, 2010 | Century Pool & Spa
Does it matter if use 220 or 115... looks like i have 25 amp in the box with gfi.. need connect the wire to back of the motor.. outside i have the big circular 3 pronged connection to the outlet... do i...
220 VAC is more efficient ... so there is some cost savings in the money department. Volts X amp = watts generally ... there is still a savings because you will actually consume fewer watts at 220 (watts is what you are purchasing form the power company)
Wiring depends ...you going to use 110 or 220? if 110 ... black is hot and goes to L1 ... white is nutral and goes to L1.
If 220 ... black is hot and goes to L1 - white is hot and goes to L2.
Your owner manual has a good picture and description of this.
In the plug ... 110 - neutral should go to the left slot.
Is your breaker 110 or 220 (single pole or double pole - one slot or two slots)
These voltages are not compatable!
I suggest you use this pump at 220.
Jun 04, 2010 | Hayward 1.5hp Pool Pump Motor Motor A O...
110 to 220 conversion
a converter plug should be fine
Jun 01, 2009 | Sony SLV-N750 VHS/S-VHS playback VCR
Sylvania GNET28001SO Meso 8.9" Netbook PC (1.6 GHz Intel Atom
If you are attempting to connect your laptop between 110 and 220 volt power outlets, you may be able to do so already, take a look at your power cord's transformer (brick) and read the input voltage. If you only can use 110 volt AC Input Voltage should read 115VAC. If you can do both, then it should read 110-225VAC.
If your power brick supports 220, then all you will likely need is a plug adaptor, found at many electronics store. If not, you wil need to stop in at a computer store or an import store and get an international transformer, which are set up to convert many different country plugs and many common voltages.
Good Luck!
May 06, 2009 | Sylvania Meso GNET28001SO Notebook
I have bard central unit model# a/c ph11361 blower not running
220 is just putting two 110 volt circuits together. You should read only 110 volts from each leg to ground. But you should read 220 between both legs. Measuring between two legs that are supposed to be 220 and you read nothing than you are not measuring the differences. This means you are only getting 110 volts. Check your units data plate and make sure you need 220. Usually the condenser fan on a split system is 110 volts and the condenser fan is 220 volts. Which motor are you checking?
Apr 02, 2009 | Heating & Cooling
Converting from 220 to 110 volts
Most brands of air comperssors are built to work on either 220 or 110 v. I believe that 220 v compressors are more efficient and draw less current and run cooler.
The more expensive compressors have a switch allowing for voltage selection. Still others will have a wiring diagram printed on the motor allowing voltage change by changing jumpers. Most all of the sears compressors that I have repaired were of single voltage with no other way to change except change motor. Do not worry however, you have the better motor. It is easier to convert the outlet plug to 220 by isolating the circuit and installing a 220 v breaker. enjoy
Nov 15, 2008 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Sylvania 6720FDD 20 in. TV/VCR/DVD Combo Logo
37 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
