Question about Maytag Neptune MAH5500B Front Load Washer
The cold cycle on my Maytag Neptune front load washer is not working. It works fine with hot water.
  • Maytag Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Posted on Sep 03, 2010
No hot water
The replacement valves could be defective or installed incorrectly.
Nov 15, 2013 | Maytag Neptune MAH5500B Front Load Washer
Washer does not allow hot water to enter machine when you press the heavy duty button. Regular warm cycle or hot works fine. Replaced the water valves, main control panel.
This is a common question we face daily. Certain washing machines allow hot water to enter only during certain cycles. Others allow hot and cold to enter intermittently. Consult your owner's manual to be absolutely sure about this. If you're sure the machine isn't working the way it used to--or should--try these tests:
Is the hot water turned on? If not, turn it on.
Is the washer getting cold water but no hot water? If so, check to see if the control panel
settings are correct.
Thanks for writing to Fixya.com and I am Aparajita. I will be assisting you today.
Mar 22, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Front Load Washer Model MAH4000AWW low last spin
two problems here,
your shaft seal is running on its last leg
the sound is unmistakeable and always described the same...
the water issue, you probably have a trickle leak through the cold water valve
the mixing valve is quite an easy repair, but I would have to say with all honesty, it probably time for a new machine
the hub seal is a tub replacment call
2 hrs of labor if hes good
and the tub runs around 500.00 dollars
sory for the bad news
Oct 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag washer stopped working at the rinse cycle
do you have the machine set for cold water rinse? if so, the solenoid that allows the cold water to come into the machine may be malfunctioning. try to see if it will fill in the rinse cycle with hot water? if so, you need to change the water inlet valve.
Oct 07, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune front loader
check the following
power cord plugged into a grounded 3 prong outlet
the inicator on the cycle conrol knob proprely lined up with a cycle? turn the knob to the right slightly then pull the knob
are you using a extention cord if so dont
washer overloaded
Jul 19, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Cold water valve won't turn on to fill washer
either the valve has failed or the water line screen is blocked.
Aug 31, 2017 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune rinse cycle doesn't start.
cold water valve screen plugged or bad valve, just check it!
Aug 06, 2008 | Maytag Neptune MAH6500A Front Load Washer
Maytag neptune
Change the water valve again ,you most likely got a bad one.The odds of there being no cold water after a new valve is almost impossible.You can test the valve to make sure its working before you go to buy another one.
Apr 29, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH7500AWW will not fill from hot water side
check out the hot water tap is on then check out the hot water valve for continuity (poss 27 ohms) then check for blockages in the small inline filter at the valve.
Jan 20, 2008 | Maytag Neptune MAH7500A Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
200 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
