Question about Neff Dryers
I hope you can help. The catch on my dryer door has broken. I have managed to obtain a replacement from Neff but wonder how to get into the door to replace the catch. My product number is:- E - Nr R4380XOEU/04 FD 7904 00242 Thank you.
COXY
  • 76 Answers
SOURCE: how to reassemble door catch of indesit tumble drier
Very difficult to explain with out pictures, the pin should go through the spring it really is a matter of fiddling until you get it right or go back to where you bought it from and ask them how it goes.
Posted on Dec 01, 2007
SOURCE: How to open the dryer and replace the belt
all dryers open from the top so open the dryer door and look inside the top edge you will see two screws . remove the screws and lift the top panel . the front panel has two screws on the top one on the left and one on the right remove them both and lift up the front panel to remove it. the only way you can install the new belt is removeing the front panel because the belt goes around the drum from the front. once you remove the old belt out put the new one in . the belt goes around the drum from the front and then to the motor and idle roller . you can reach the idle roller from the front left corner or from the back of the dyer? i like to install them from the back cause its more easy. in the back of the dyer where the hose goes connected to the blower is the top with four screws remove the hose from the blower tube and remove the four screws. after you remove everything you should be able to see the dryer motor and idle rooler put the belt over the motor first then over the idle rooler .always make sure when you do this the dyer is unpluged and after your done plug it back and turn it on to make sure it runs correctly . if it runs ok put everything back together again.
Posted on Jan 11, 2008
  • 35 Answers
SOURCE: Hi. The dryer drum belt
2cb8663.gif This picture may help it shows the position of the belt tensioning pulley (#53) . The bottom of the spring goes into a slot in the bottom of the dryer cabinet and spring tension against the belt holds it in place. Thus the reason why it was probably just laying there when you opened the cabinet.
Posted on Nov 21, 2008
onthejob5130
  • 640 Answers
SOURCE: broken door switch
on the corners of unit console ,,are plastic end caps,,pull them of with your hand ,,grasp it and tug hard,,now you see 2 a scew under each cap..remove screws ,,than flip the console back...now under the console theres three screws holding lid dowb,,remove them slide lid forward ,,,but screw for door switch are on the bottom of front door panel..always unplug first...onthejob
Posted on Jan 18, 2009
  • 351 Answers
SOURCE: Need replacement part for front dryer door sensor - broken
i sell parts online you can visit whirlpoolpartssurplus.com and get the phone number off there and i can order it for you
Posted on Jun 26, 2009
Door lock broken
Most online appliance stores will have replacement part, and usually helpful for how to replace.
If in warranty go that route because your DYI will invalidate warranty!
Mar 08, 2015 | Neff R4381 Electric Dryer
Neff H7871 oven door does not stay closed. Catches do not appear to be working
The door latch is either cracked or broken.The door when gets closed the door latches clicks.But if the door latch is loose or cracked it will not click and door will not close.The door needs to be disassembled and the door latch has to be replaced, if the latch is cracked.Also to check the latch from inside the door needs to be removed.-------- This will help.thanks.Helpmech.
Jun 29, 2011 | Neff Microwave Ovens
Hi the door catch for my Creda T522VA Simplicity dryer has broken - where can I get a replacement?
http://www.espares.co.uk/parts/tumble-dryers/doors/creda/t522vw/p/1580/720/0/423760
hope it helps
Jul 05, 2010 | Dryers
My outer glass on door has shatter by its self can it be replace
You should be able to obtain a replacement door glas, they are usually supplied as a seperate item.
Try the following.
WWW.ESPARES.CO.UK/NEFF
WWW.NEFF.CO.UK/CONTACT.HTML
Mar 07, 2010 | Neff B1421 Electric Single Oven
Hotpoint tdc 30 door catch will not push into door switch when I close door, have taken switch out and it fits into catch manually but not when it is installed so door will not close to activate drying
I would say that the problem is due to the door handle spring being weak or broken.
Purchase a door handle kit, and it should solve the problem, if it does not, then you need a new door switch.
Hope this helps with your problem.
Dec 09, 2009 | Hotpoint NVL333EY Electric Dryer
Zanussi Tumble Dryer - TD 4112 -Door Catch Assembly/Repair The plastic catch broke and I have bought a replacement however I can't work out how to put the pin, spring and catch back together. Any help...
Jason, I have the same problem... the catch on my Zanussi dryer has broken. I've ordered a spare part... and remembered how I took the thing apart.
I'd have to show you... it can't be put into words. LOL
Hopefully by now you've figured it out. (Just seen the date you posted this).
~ Franka ~
Aug 31, 2009 | Zanussi TD4112W Electric Dryer
Neff dishwasher door catch not corking, door does not close ?
look carefully at the catch and the latch as almost all can be adjusted with just a screw driver.
May 31, 2009 | Neff 24 in. S4456 Built-in Dishwasher
Belling SGE12X broken door handlw
it's not an easy job to replace a door handle, but to release it for the door to open, turn off the machine at the outlet and unplug. Take the top of the machine off and slide your hand down to the door catch. Depending which type of catch it is, you should either be able to push down a small lever on top or push up a small lever on the bottom or the door catch.
I hope this helps
Oct 25, 2008 | Belling SGE12X Front Load Washer / Dryer
The top hinge of my Neff integrated fridge freezer has broken so the door won't open and shut properly. Neff are sending replacement hinges but as a temporary repair I intend to swop the hinges around...
The top hinge of my Neff integrated fridge freezer has broken so the door won't open and shut properly. As a temporary repair I intend to swop the hinges around -replacing the top hinge with the middle one but can't see how to remove the hinges. Can anyone help?
May 02, 2008 | Refrigerators
Dryers Logo
Top Neff Dryers Experts
Dan Webster
Dan Webster
Are you a Neff Dryer Expert? Answer questions, earn points and help others
