Question about Dishwashers
I have about a 3 yr old Maytag Dishwasher MOD#MDB6601AWW. There are 2 manifold bracket clips that keep coming off which hold the large U shaped plastic piece with the spinner blade attached. The each clip is all metal being about 1/2"x3". I see where one of the clips on but not the other. Any help would be greatly appreciated. Al Perry
  • 1 more comment
  • alperry130 Sep 02, 2010
    Not even close to the parts I'm talking about. These are the brackets that hold the upper spinner blade.
    To send a diagram of the guts beneath the dishwasher has absolutely nothing to do with my issue inside the main washing cube of the unit. There are two mounting brackets that attach to the u-shaped plastic washing assembly inside the large cube of the dishwasher. These brackets look like slender metal clips that somehow attached to the u-shaped plastic assemble and the rear of the cube. The plastic assembly has the spinning blade on top. I hope this is more clear.
  • alperry130 Sep 03, 2010
    As I stated before in my last message. You are so far away from the location I'm describing it's not funny. Anybody can get a PDF on the motor guts which has nothing to do with what I described, which is the washer arm inside the tub of the unit. No thanks to your ineffective service.
  • 11,896 Answers
This may help you a bit:
Posted on Sep 02, 2010
  • Nate Stansfield
    Nate Stansfield Sep 02, 2010
    Maby this will help you better:
    http://www.partselect.com/AdvancedModelS...
    I do know what part you are talking about. I have had to put them on a few times when I've rebuilt the maytag machines. Most of them slide on or clip on in place.
Top water outlet doesn't spin
Not sure of the vintage of your Maytag dishwasher, but this may work for yours.
1. Remove the upper rack by releasing the stop clips on the ends of the rack rail; push the ends of the clips towards center of machine - this may require the help of a small screwdriver.
2. The upper spray arm assembly is mounted to the ceiling of the wash chamber by large (2" diameter) fluted nut that butts right against the ceiling sheet metal. Simply remove that nut by hand, and the whole assembly will come out.
3. Looking into the top of center feed hole, you'll see 4 plastic clip ends holding the 3 pieces together. Use a 1/4# socket or nutdriver to press all 4 clips inward until they come free.
4. The spray arm halves are welded together, so you'll have to clean out any clogs using a pointy tool and some water flushing.
5. Reassembly is the reverse order.
- Mike
Apr 17, 2014 | Maytag Dishwashers
How do I remove the motor housing on a C2002 compressor to make room to spin and remove the manifold
The housing has slots for the four legs on the tank to hold on to. At one (sometimes two) of those legs there is a small screw that keeps the housing from freely falling off the tank. If you remove the screw(s) the housing will slide easily to one side and come off the tank. Don't bend the four tabs as they could break off when you bend them back and will weaken the tank where they are attached to it.
Jun 25, 2012 | Porter Cable C2002 150 Psi 6 Gal...
The bar things inside the dryer drum (there are three of them) one has come almost all the way off. and one is loose. looks like its screwed from the other side.. cant figure out how to get inside. it...
Unplug the dryer. Open the door and remove a total of 4 screws, 2 on each side of the door opening. Two screws each hold a clip in place and the other two hold the dorr hinges. When you remove the screws on the door hinge, it shouldn't fall off, but be prepared for it to do just that. The door should come off by lifting the hinges upward and pulling the door away. The remaining part of the front panel is held on by 2 clips located toward the top sides of the u-shaped front panel. Pull the panel forward to release the clips and lift the panel upward to clear the two tabs and slots on the bottom. On each side of the cabinet, there is a blackish colored metal bracket that holds the top in place. Remove the fasteners that holds these brackets and remove the brackets by sliding them upward and away. The top should now lift up. You now have access to the fasteners that hold the baffles onto the drum. If , for some reason, you should want to remove the baffles, carefully note the different sizes of the baffles and what order they came off.
Here is the parts list for the drum of your dryer:
http://www.repairclinic.com/Maytag-Model-MDE3500AYW-ID-508609-Drum-Or-Tub-And-Related-Parts
Good luck from Detroit, MI.
Jul 18, 2011 | Maytag Dryers
My speed don't work
Speed Sensors REMOVAL & INSTALLATION Front Fig. 1: The speed sensor sits directly over the exciter ring in the front knuckle 89609p51.jpg
Fig. 2: Detach the speed sensor connector in the engine compartment 89609p55.jpg
Fig. 3: Remove the speed sensor harness from the routing clips 89609p53.jpg
Fig. 4: A special E6 Torx® socket is required to remove the speed sensor retaining bolt 89609p52.jpg
  1. Disconnect the negative battery cable.
  2. From inside engine compartment, detach sensor assembly 2-pin connector from the wiring harness.
  3. Remove the steel routing clip attaching the sensor wire to the tube bundle on the left sensor or remove the plastic routing clip attaching the sensor wire to the frame on the right sensor.
  4. Remove the rubber coated spring steel clip holding the sensor wire to the frame.
  5. Remove the sensor wire from the steel routing clip on the frame and from the dust shield.
  6. Remove the sensor attaching bolt from the front spindle and slide the sensor out of the mounting hole. To install:
  7. Install the sensor into the mounting hole in the front spindle and attach with the mounting bolt. Tighten to 40–60 inch lbs. (4.5–6.8 Nm).
  8. Insert the sensor routing grommets into the dust shield and steel bracket on the frame. Route the wire into the engine compartment.
  9. Install the rubber coated steel clip that holds the sensor wire to the frame into the hole in the frame.
  10. Install the steel clip that holds sensor wire to tube bundle on left side or plastic clip that holds sensor to frame on right side.
  11. Reconnect the 2-pin connector to wire harness. Connect the negative battery cable.
Rear Fig. 5: Detach the speed sensor connector in the luggage compartment 89609p04.jpg
Fig. 6: Grasp the harness and . . . 89609p37.jpg
Fig. 7: . . . remove it from the routing brackets 89609p36.jpg
Fig. 8: The rear speed sensor is mounted on the back of the hub assembly 89609p32.jpg
Fig. 9: Remove the sensor retaining bolt and remove the sensor from the hub 89609p34.jpg
  2. From inside luggage compartment, detach 2-pin sensor connector from wiring harness and push sensor wire through hole in floor.
  3. From below vehicle, remove sensor wire from routing bracket located on top of rear axle carrier housing and remove steel clip holding sensor wire and brake tube against axle housing.
  4. Remove screw from clip holding sensor wire and brake tube to bracket on axle.
  5. Remove sensor to rear adapter retaining bolt and remove sensor. To install:
  6. Insert sensor adapter and install retaining bolt. Tighten to 40–60 inch lbs. (4.5–6.8 Nm).
  7. Attach the clip holding the sensor and brake tube to the bracket on the axle housing and secure with the retaining screw. Tighten the screw to 40–60 inch lbs. (4.5–6.8 Nm).
  8. Install steel clip around axle tube that holds sensor wire and brake tube against axle tube and push spool-shaped grommet into clip located on top of axle carrier housing.
  9. Push sensor wire connector up through hole in floor and seat large round grommet into hole.
  10. Reconnect sensor 2-pin connector to wiring harness inside luggage compartment.
Aug 03, 2010 | 1992 Ford Crown Victoria
Have old Maytag dryer that does not get as hot as it used to. Takes a long time to dry. Burner does come on. Have determined that vent is clear.
How old is this one? If it is a real old model with 2 belts, it could be the blower belt is slipping.
Jan 06, 2010 | Maytag Dryers
I have a Kenmore Ultra Wash Dishwasher and the 3rd level spinner broke off. I have a new one and now need to know how to replace it.
the manifold in the back of the dishwasher needs to come out. you can either pop it all the way out it only undo it halfway if your arm is small enough.. there are either 2 tension clips or 2 screws holding it to the top and back. if you undo the top of the manifold and pull it down you should be able to slide the new part in place. the plastic push pin goes on top of the manifold and the spinner goes on the other side. it may be a little difficlt to push the 2 together..
Mar 06, 2009 | Dishwashers
REPLACING BELT
Hello, This is somewhat involved and time consuming, but if you are handy, it can be done. First unplug the dryer then start with the two screws in the hinges of the door and then the door lifts out. Two screws on the opposite side holding plastic spacers. Once these four screws are out the front panel tilts right out. The front panel will come off then 4 more holding on the front tumbler support and air duct. Removed wires from light and dryness sensor and clips holding wires to panels. Pull out the tumbler and removed belt. If your dryer gets a lot of use, then you might want to keep going and replace some more wear items while you have it apart. Remove the two drum support rollers and shafts by removing a nut on the back side of each shaft. Remove snap ring off each old shaft, install new rollers and fiber washers onto new shafts, reinstall snap ring and replaced on brackets with the old nut. Remove tension spring off idler pulley bracket and one screw holding on the bracket. Install new pulley and fiber washers on new bracket and reinstall bracket and spring. Placed new belt on tumbler and reinstalled tumbler. Used drill and bit to drill out pop rivits holding on the two front glides that are attached on the front tumbler support and installed new glides and pop riveted in. Reinstall front support and air duct checking that felt tumbler seal front and rear are in place. Placed new belt on motor pulley and idler pulley. Reinstall front panel.
Dec 01, 2008 | Maytag Neptune MDE5500AY Electric Dryer
I have a Maytag Dishwasher MDB6601AWW. It went through a normal wash and we loaded it and it now will not start. It flashes 1H, 2H, up to 9H. It has flashed 81. What do these codes mean?
Peace Friend,
ngafm At your service!
You said,you have a Maytag Dishwasher MDB6601AWW. It went through a normal wash and you loaded it and it now will not start. It flashes 1H, 2H, up to 9H. It has flashed 81.
With an error code the only way to find and to repair this is,
First unplug the washer and wait a few minutes then restart it like rebooting your computer when its acting strange!
If it corrects the problem, GREAT!
If not only a trained laundry tech can make the electronic diagnoses.
Like we used to be able to fix my own cars, but not today they need diagnostic equipment!
How old is the washer?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
You will be fine
Bless You ngafm
PLEASE GIVE ME A GOOD RATING HERE AT FIXYA.COM BEFORE YOU SIGN OFF.
Sep 10, 2008 | Maytag Dishwashers
Dishwashers Logo
107 people viewed this question
Top Dishwashers Experts
