Question about Koss KS3102 System
Surround on my system
Purchased this unit and installed. all worked fine. Now only get sound from speakers when watching tv and not from DVD. Changed nothing on this since first setup.
  • 1 more comment
  • chetcd May 10, 2008
    This is not a DVD/TV combo..It is a Niko TV and a Koss DVD/ Radio Surround system.
  • chetcd Jun 04, 2008
    Tried all the suggestions but not a thing fixed the problem.
    More ideas.
    Get sound from the front two and center but not the surround speakers.
    President:
  • 2,712 Answers
Have you tried what I said and changed the settings in the DVD?
Also, is it a built in DVD player / TV combo, or a separate unit? You can try doing a hard reset..Unplug the TV from the mains, disconnect all cables from tv and wait for 1 hour. Then press the power button on TV and plug in the mains. Same if your DVD player is stand alone.
Try that and let me know..
Posted on May 10, 2008
  • Swilin Sampson
    Swilin Sampson May 10, 2008
    Ensure the digital compression option is ON on your DVD. Also, when you select the av input on the remote,hit the menu button,it
    should give you a few options,select the av input you have your
    connections in (eg DVD) and select analog if its analog.coax if coax.etc. try fiddling with the different settings there and hopefully one should work.
Surround sound for DVDs.
If your DVD disc supports it, you will have to enable surround sound from the DVD, as well as the speakers.
May 10, 2008 | Koss KS3102 System
I have a Jensen DVD media pro 5000 hooked up to a ViewSonic TV in my Camper Trailer. Camper Trailer was purchased with DVD Player and TV in it. At night, due to child sleeping, I would like to be able to...
hi yes you can do this press AUD button near the on/off/volume control momentarily to step through the following audio adjustment options volume, bass,treble, balance (left to right) and fader (front to back). when the desired option appears in the display, rotate the volume control knob to adjust that audio feature. When no adjustments have been made for three seconds, the unit will resume normal operation. so you can fade the speakers to however you want them...hope this helps
Aug 03, 2010 | Audio Players & Recorders
I have a panosonic surround sound system and a toshiba 60" tv and when watching tv speakers have a humming sound , but when watching a dvd speakers are fine and no humming sound.what is the problem? Tv...
it depends on what volume level the tv is on
if the level of volume is low and making the sound then try unpluging or pluging in the sound system to the tv
Sep 13, 2009 | Televison & Video
Dish Network connection and surround sound
HI, connect audio output from tv to system,you may have to turn this on or turn up in tv menu for some sharp tvs,this should get sound for tv and dvd and anything else you hook up to tv.
Hope this helps.
CABLE GUY.
Mar 29, 2009 | Audio Players & Recorders
No Surround Sound in Aux 2 mode
genarally tv output contain two signals.(steereo).it dosent have surrund output.thats y its not hearing surround sound from your system.
Jan 07, 2009 | Samsung HT-WX70 Theater System
Surround sound hookup question?
It looks like all you'll need to do is hook up audio out from DirecTV to audio in on the surround sound system. Sony has an interesting hookup recommendation guide on the product support site:
http://esupport.sony.com/US/perl/model-home.pl?mdl=DAVC700&LOC=3
That should give you the connection options. The short answer, though, is to connect the best audio out from DirecTV to an audio in on the surround sound and then choose that option in the surround sound system when you want to watch TV.
Jul 16, 2008 | Sony DAV-X1 System
1 front speaker and 1 surround speaker won't work on cable selection
theres probably a problem with the right channel cable or plug that connects the tv to the reciever, or the tv is set to mono audio.
May 17, 2008 | Yamaha HTR-6030 Receiver
How do I get surround sound from TV?
see if ur DVD player has a TV/Audio in....you have to set it up so u watch TV threw your DVD player (if you have one of of the Surround Sound in a box systems) if you have SS w/ a receiver then you'd have to run Audio out from your TV/Cable/Satellite to the receiver for it to work
Feb 02, 2008 | Jensen JHT805 System
Home theater system connections
Hi
I have the same tv but my dvd surround is a toshiba, that shouldn't matter though. When I watch a dvd I go to component 2 which is where I have my dvd connected on the input of the tv when I watch tv and want the surround on I go to component 1 which is the tv input then on my dvd player I go to auxillary and I can watch tv in surround. I don't know the LG home theatre system but you should be able to select your inputs like between dvd, tuner, aux. Flip between them and you should get sound. hope this helps.
Oct 15, 2007 | LG 42PC5D Television
Koss KS3102 System Logo
112 people viewed this question
Top Koss Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Steven Wander
Steven Wander
Steve K
Are you a Koss Audio Player and Recorder Expert? Answer questions, earn points and help others
