Question about Linksys SD208 8-Port Ethernet Switch (SD208KIT)
Linksys SD208 8-port switch
I need to open the case and get to the PCB... i need to do some testing and fix the unit. i need to know how to open the case please...
    Problem Solver:
  • 9 Answers
You have to lay it on his back and pull a screwdriver under the dark front plastic and click it off by turning and then the above metal part.
Posted on Aug 31, 2010
    Scholar:
  • 139 Answers
Look around the back u see some waranty label take it of then u should find the srew thats holding it. but i dont think theres any servisable parts inside for a beginner to handle.
Posted on May 24, 2008
Reset linksys SLM224G4S switch
1-With the unit on, place a paper clip into the hole on the back of the unit labeled Reset.
2-Hold paper clip down for 10 seconds and release.
3-The unit will reboot on its own. Once the WLAN light stops blinking, the unit is reset.
Resetting the router does not reset the firmware to an earlier version. It will change all settings back to factory defaults
Jul 04, 2013 | Linksys (SLM224G4S) 24-Port Ethernet...
How to resolve e00002-0000
E002
The main thermistor (TH1) has poor contact or an open circuit. The thermal
switch has an open circuit (TP1). The fixing heater has an open circuit. The
AC driver PCB is faulty. The DC controller PCB is faulty. The door switch
is faulty.
E002
0000 The temperature of the fixing film is as follows:
1. has exceeded 100°C, but does not reach 115°C within 1 sec thereafter.
2. has exceeded 140°C, but does not reach 150°C within 1 sec thereafter.
3. has exceeded 160°C, but does not reach 165°C within 1 sec thereafter.
Main cause: The fixing film unit is faulty (i.e., the main thermistor TH1 has poor contact,
or the fixing heater is faulty). The main power supply PCB is faulty.
Caution: To clear the error, execute the following in service mode:
COPIER>FUNCTION>FCLEAR>ERR.
Action See the description for E003.
E003
Action
1. State
Turn on the power switch, and clear E002/E003. Thereafter, turn off and
then on the power switch. Does the fixing heater operate?
NO: See "The fixing heater fails to operate."
2. Wiring
Is the wiring from the DC controller PCB to the fixing film unit normal?
NO: Correct the wiring.
3. Fixing film unit, DC controller PCB
Try replacing the fixing film unit. Is the problem corrected?
YES: End.
NO: Replace the DC controller PCB.
Feb 12, 2011 | Canon imageRUNNER 3300 All-In-One Laser...
Cannon-3300 Copier Error code E000-0000 rectify the problem
E000 0000
The reading of the main thermistor does not reach 30°C 1 sec after the main
power switch is turned on. Or, it does not reach 70°C 2 sec thereafter.
Main cause:
The fixing film unit is faulty. The main thermistor has an open circuit. The
fixing heater has an open circuit. The main power supply PCB is faulty. The
Caution:
To reset the error, execute the following in service mode:
COPIER>FUNCTION>CLEAR>ERR.
Action:
1. Connector
Is the connector of the fixing assembly connected?
a. main power supply PCB (J8) <-> relay connector <-> heater
b. DC controller PCB (J320) <-> relay connector <-> thermistor
NO: Connect the connector.
2. Fixing film unit (thermistor)
Check the interval between pin 1 and pin 2 and between pin 3 and pin 4 of
the connectosr (4-pin) of the thermistor for electrical continuity. Is it ¥W
(open)?
YES: The heater has an open circuit, or the thermal switch is open. Replace
4. Main power supply PCB, DC controller PCB.
Press the Start key. Is the drive voltage of the heater supplied by the connector
J8 of the main power supply PCB?
Main heater: between J8-1 (FSR1) and J8-5 (FSR COM)
Sub heater: between J8-3 (FSR2) and J8-5 (FSR COM)
YES: The heater drive power supply is faulty. Replace the main power
supply PCB.
NO: The thermistor control mechanism is faulty. Replace the DC controller
PCB.
Jan 18, 2011 | Canon imageRUNNER 3300 All-In-One Laser...
Hello, I have a Linksys SRW2016 and 2048 switches with one cisco 1800 series router. I have successfully created two vlans on one switch and when i try to connect a trunk port to cisco router it...
Make sure that the frame encapsulation is set on the router to 802.1q on each of the sub-interfaces. You could also try fixing the speed and duplex on both the router and the switch in case there is a problem negotiating the speed and duplex.
Hope that helps!
Oct 04, 2010 | Linksys SRW2016 (745883562435) 16x1000...
I need to know how to open a port on a linksys ezxs55w switch.
I don't believe you can open a port on this switch. You need an actual router to be able to open ports. The switch itself is not routing anything, just acting as a switch. You will probably need to connect a router to be able to open/forward ports.
While the "no configuration required" feature seems nice when purchasing this switch, it unfortunately does not allow you to configure it when you do want to.
Dec 19, 2009 | Linksys EtherFast EZXS55W 5x10/100 Mbps...
LG Electric Dryer DLE2515S - dryer timer is stuck on 6 minutes and continues drying until I manually switch off - sensor dryer does not appear to be working either.
OK, test the dryness sensor for its operational value. if the test confirms sensor function, you will need to replace the main PCB board in this case.
Now, if the sensor test reveals a faulty sensor device, simply replace the sensor. In most cases, this iwll be a fualty PCB main and, replacing it will usually fix this issue.
Jun 01, 2009 | LG DLE2515S Gas Dryer
My wireless XBOX 360 says ''not connected'' when I test XBOX LIVE
hi,
in this case you need to do a port forwarding,which is something like opening the specific ports on router so that xbox will communicate with internet
for that we need to know the ip address of xbox and port numbers for xbox.contact microsoft for knowing the port numbers and their range,so we can do a port forwarding on your router
Dec 29, 2008 | Linksys WRT160N Wireless Router
Well i had just bought a lynksys router from my friend with no software cd so right now i am trying to download the software online so when i switch my cox modem with the linksys modem i want the software...
You should be able to get any software that you need from LinkSys.com but I have a couple of quick questions first:
1. Is the LinkSys unit you just purchased a router or modem?
If the unit is a router, you are still going to need a Cox compatible modem. If the unit is a modem, you will still need a router to complete the network setup unless LinkSys makes a combination cable router/modem, and I haven't been able to research one.
2. If it is a modem, is it a cable modem and, if it is, is it Cox compatible?
According to the Cox Web Site, the only models of LinkSys modems that are currently compatible with the Cox High Speed Cable Internet Service are:
BEFCMU10 v3
BEFCMU10 v4
WCG200
WCG200 v2
CM100
In this particular case, you may need to contact LinkSys and/or your Internet Service Provider. In most cases, they will not only tell you exactly what type of equipment you need, they will also talk you through setting up the network once you have the equipment - usually at no charge.
Graye
Nov 25, 2008 | Computers & Internet
IR 2000
Fuser error probally needs fuser replaced and the reset as below
try this
1. Hit Additional Functions Key
2. Hit # key
3. Arrow to number 7, Printer and hit Set
4. Arrow to number 4, Printer Re-Set and hit Set.
5. Yes, re-set printer (hit minus key - back arrow).
6. Unplug the machine and plug it back in.
or this is explaination of the error and required fix from service manual.
E0000000
Main cause The fixing film unit is faulty. The main thermistor has an open circuit. The
Caution To reset the error, execute the following in service mode:
Action
1. Connector
(open)?
YES: The heater has an open circuit, or the thermal switch is open. Replace the fixing film unit.
Press the Start key. Is the drive voltage of the heater supplied by the connector J8 of the main power supply PCB?
supply PCB.
PCB.
Nov 18, 2007 | Office Equipment & Supplies
Linksys SD208 8-Port Ethernet Switch (SD208KIT) Logo
967 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
