Question about Whirlpool AWZ410 Front Load Washer/Dryer
FITTING NEW DOOR SEAL ON WHIRLPOOL AWM5125
Please can you tell me how to fit a new door seal on washing machine whirlpool AWM5125 Many thanks
Need to replace rubber door seal due to tear, do i need to take machine apart or will it come out working from doorway
  • Anonymous Mar 16, 2014
    Having to repair my AWM8143 for the third time now. Basically its leaking water and this has stuffed the 6306 main bearing. Bad design by Whirlpool as any leakage from the V-40 V-Ring goes into the standard metal shielded bearing when it should ahve been a 2RS bearing with rubber shields to keep out any water. The whole area is a mess and getting the V-Ring seal out is a pain due to the hole in the back of the drum being too small and it could have been at least 6mm bigger in diameter.Getting a new 40mm Viton V-Ring and a 6306 2RS C4 bearing.
    Genius:
  • 1,073 Answers
This is a complex repair and the machine complet frount has to be removed
Posted on May 11, 2008
How do you fit a door seal to a AEG LAVAMAT 66600
Thank you for contacting fixya.com.
Please check this video along with the tutorial to install the door seal in your washing machine:-
http://www.apart4u.co.uk/video-tutorials/washing-machine-repair-videos/how-to-fit-door-seals-gaskets/aeg-how-to-change-or-fit-a-washing-machine-door-seal-or-gasket.html
Please get back to us if you have further query else please accept the suggestion.
Jun 01, 2011 | AEG Washing Machines
Whirlpool Front Loading Duet Washing Machine Plastic at drum front shredding
i think your talking about the rubber door seal????
you can change this yourself,,,under the seal on the case is a wire spring unhook it and the door seal will fold inside the washer,,,on the inner drum you will find the other wire spring undo this as well and pull the old door seal out through the hole in the door,,,the new seal is fitted to the iner drun first so you need to turn the new seal inside out to fit it,,,push the seal into the washer and fit the inner wire first then unfold the seal and fit it over the outer door so you can fit the wire spring,,,
easy after you have fitted a fuw 100?
Aug 21, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
Leaking at each wash cycle
this sounds like the door seal has split,,,there not very pricy but a pain to fit,,,so here go's,,,
open the door,,look at the door seal pull it off the back of the door and you should fine a spring wire holding it there,,,undo this wire,,,now fold the seal into the washer over the inner drum,,,,there you will find the inner wire,,undo that wire and pull the seal out the washer door,,,,
to fit the new seal,,,turn the seal inside out and push it through the hole in the door then fit the inner wire on the inner drum first,,,unfold the seal and pull it through the door,,,now fit the outer wire,,,,not put the kettel on,,have a cup of tea take the pain killers for the head ache you just got,,, and think about how much money you just saved ????
now was it realy worth the trouble,,,i wonder? am i good or what?
Jul 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Fit a new door on a washing machine
You need to remove the wire clamp that holds the door seal on to the front of the cabinet, then pull seal off.
This will give you access to the door hinge assy, then you can replace the door complete.
Please rate my solution.
Thankyou.
Jan 27, 2010 | Hotpoint Washing Machines
Fit a new door hinge
Remove the wire clamp securing rubber seal to front of washer, pull seal of front of washer, this will give you clear access to tjhe door hinge, ondo the 2 screws securing the door hinge, remove door ,and seperate the 2 door halves by removing the screws securing it together
Replace with new hinge, fit back in reverse order.
Thanks.
Nov 12, 2009 | Creda W120VW Front Load Washer
Bought new rubber seal for whirlpool but no instructions how to fit.has 2 wire rings front and back of seal so how do you fit them around the new seal. do you work from the back of rubber seal first ie...
this is why we are paid to do the tricky stuff. Ok, remove the lid then open the door. look for the front pring loaded wire then remove. Pull front of seal off ridge then bend it back into the tub so it allows you to work easier. you will now see a second large ring holding the other end of the seat to the tub. remove it then pull the faulty seal out. Follow same proceedure putting it back. careful not to tear boot as it is silicon.
Sep 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Trying to fit new door seal with spring keeper to washing machine
Fit the seal first and then fit the spring,it cannot be done with the spring fitted on the seal first.
Plz rate my solution.
Thanks.
Jan 17, 2009 | Zanussi WJS1265W Front Load Washer/Dryer
Usually it will be just be reversing the procedure of removing the old seal. At any rate, the door will need to be disassembled.
Mar 29, 2008 | Whirlpool AWM5125/1 Front Load Washer
Replace rubber seal on my zanussi washing maching
the only way to fit door rubber to tub on a zanussi is to use washing up liquid it takes two mins
Sep 28, 2007 | Washing Machines
Whirlpool AWZ410 Front Load Washer/Dryer Logo
355 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
