Is the fridge getting warmer at the same time? How cold/warm do you have the adjustment set? Have you removed the far rear panel of the freezer? Behind the far panel you will see the defroster unit. Make sure it is not frozen up or that could be the defrost heater or timer may be bad. There is also a vent that goes from freezer to fridge, ice can build up in there and cause the majority of the air to stay in the feezer, you should clean out the blockage. I use coat hangers and screwdrivers myself to break all the ice free.
