Question about Dell Computers & Internet
My old harddrive is xp and my new hard drive is preloaded with windows 7 how do i get my drivers across
  • Dell Master
  • 27,725 Answers
I dont think you can windows7 have different drivers to xp
hope this helps
Posted on Sep 02, 2010
I AM NOW WITH WINDOWS SEVEN AND CAN'T OPEN MY HARDDRIVE TO VIEW WHATS ON IT, HOW CAN I ACCESS MY PICS AND FILES, IT WORKED FINE WITH MY OLD COMPUTER WINDOWS XP
Do you have access to your old XP machine, the easiest way for you would be instead of tinkering around with drivers, filesystems, recovery programs. Boot up your XP machine, map a shared drive to your new windows 7 computer and copy the files over. If you do not have access to the old computer, let me know.
Jan 25, 2015 | Computers & Internet
Hard disk gb maximum
Hello here is the homepage:
http://www.gigabyte.com/products/product-page.aspx?pid=3505#dl
The mainboard does not have a limit for the harddrive size.
But the windows system sometimes have a limit especially windows xp.
A new sata driver or a bios upgrade is sometimes needed when you add a big harddrive.
Note: take care not to flash the bios with a wrong one if needed.
And also the new drive must be formatted ( in NTFS format ) before you can use it.
If you still run windows xp, try to make more partitions, so windows can see the new drives.
Other system like windows 7, does not have this limit.
Good luck
Jul 31, 2013 | Gigabyte GA-G41M-Combo Motherboard
INSTALL A NEW HARDDRIVE TO MY HP PAVILION A1220N ERROR MESSAGE COMES UP BOOT MGR IS MISSING
You need to install an operating system like windows XP, Vista, Windows 7 or Linux OS. Your hard drive is blank now and needs programming. If you have a friend that can clone your old drive then they will be able to copy everything from your old drive as it was to your new one. Might need to contact a local computer technician to re-install windows for you if not sure. Also you need to consider the price of windows XP, Vista or 7 if you don't have a copy!! Good luck!!
Sep 28, 2012 | HP Pavilion a1220n (A1220NED904AA) PC...
Is my Iomega hard drive compatible with Windows 7
Yes window 7 is the problem there is no updated driver for it to work, go to www.Iomega.com contact customer support and the technical department to see if they can offer a updated driver.
May 04, 2012 | Iomega Computers & Internet
Problem loading Windows XP
You need to start windows in the safe mode, press F8 at boot up.
Remove al the drivers that you've installed on you previous computer system, usualy this is is a conflict between wrong drivers and your hardware.
If you can't remove the old drivers, reinstall Windows XP, do a clean install
by booting your computer up with the Windows xp cdrom, from the Windows XP cdrom you're also able to repartionate your hard drive.
First remove the old partition(s) en make a new one, the setup does then format your harddrive, after that you're ready to install windows xp on the new partition.
Jan 19, 2010 | Microsoft Windows XP Professional
Why my acer e500 cannot install 64 bit window 7 it say no driver when need to choose hard disk to install
you need to install Uli sata drivers in order for your motherboard to recognize the harddrive and cd drive.
download the drivers here: http://www.soft32.com/download_184082.html
and put them on a cd or memory card, when the system prompts you that you have no harddrive, you can load the drivers from a memory card or cd however if you use a cd you will face other issues. then you will be able to install windows 7 ;)
I did it on my acer e500 and it runs good.
I didn't install the 64 bits version though but the 32 bits.
for all the people saying that his pc is too old: if the pc can run under vista, it runs better under windows 7
Nov 05, 2009 | Acer Aspire E500 PC Desktop
Hard drive crash, not usable at all; downloaded xp drivers and computer drivers but cannot get them installed. Hard drive not recognized.
When you install a new harddrive, it has no Operating System on it.
Windows XP and Windows Vista, are examples of an Operating System.
Each laptop manufacturer, has their own system of changing a laptop harddrive. Some allow you to press a key or two, to put the laptop in a state where it will save the basic Operating System files, and when you install the new harddrive, it will transfer them over to it.
Some laptop manufacturers do have this option.
You either have to take the harddrive out, install it into an external enclosure for a harddrive, (Uses a USB cable) Then attach the external enclosure via the USB cable, to another computer, and use a 'mirror' imaging program to save the Operating System to that computer.
Then the new harddrive is installed in that external enclosure, and the Operating System is 'mirrored' over to it.
Just information for you, as you cannot do this now with a crashed harddrive.
Your option now, is to buy a genuine copy of the Operating System you had on the laptop, and install it.
Not what you wanted to hear, huh?
You need to buy whatever version of Windows XP it had, (WinXP Home or WinXP Pro), or Windows Vista.
If it was Windows Vista, I suggest getting at least the Windows Vista Home Premium version.
I personally prefer Xp over Vista.
Tigerdirect.com, and Newegg.com, have these.
Look for Software>Operating Systems.
OR, you can simply put Ubuntu Linux on it for free.
Apr 16, 2009 | Toshiba Satellite P25-S5263 Notebook
Installation of windows xp on a preloaded windows vista laptop
See this , you have to download the SATA driver , as you have a SATA hard disk , then slipstream it into the xp installation package.
Alternatively , put the driver on a floppy and press F2 when prompted during the setup when its loading all the files (It says Press F2 if you want t o install a SATA Driver"
Then it will detect your drive and install as normal :D
http://news.softpedia.com/news/Install-Windows-XP-On-SATA-Without-a-Floppy-F6-47807.shtml
Jan 07, 2009 | Toshiba Satellite A100-S8111TD Notebook
Windows XP driver?
i have a Transend Storejet 2.5 which goes off whn it gets detected. plz can some1 giv me a solution for this.
Jul 17, 2008 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
Computers & Internet Logo
63 people viewed this question
Alun Cox
