Question about Kodak EASYSHARE M340 Digital Camera
I mistakenly seat on my camera, after which i had problem with my lens, when i put it on i cant see to take a picture, and if i want to put it off and want to put it on i cant.
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel after sitting on it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Sep 03, 2010
I mistakenly dropped my digital camera a few inches when the lens was out.When i tried putting it off to know if the lens would go back in,it didnt move so i forcefully pushed it back inside.Now, when i...
You've likely jammed the zoom motor in the lens. You're correct in thinking that the camera can't work without the lens out. With it being physical damage repairs wouldn't be covered under warranty so you either need to pay to have it repaired (if that's even possible, it varies camera to camera) or buy a new camera unfortunately.
May 11, 2011 | Cameras
Aperture cant be changed on manual mode
Maybe a lens problem. Try to re-seat the lens and play with the Aperture test button on the right side of the camera (near your right finger)
NOTE: Please rate our help to keep this free service online
May 02, 2009 | Nikon D80 Digital Camera with 18-55mm Lens
Focus error message camera wontwork
I found this site to solve this problem. I got as far as tapping the lens, while turning it off. That worked but I still could not take pictures, so, I got the idea to put slight pressure on the lens when turning the camera on and was delighted to see that the error message was gone. Then, reluctantly, I snapped a picture...It worked. Hope this helps u 2..
Mar 29, 2009 | Fuji FinePix A500 Digital Camera
Nikon D80 error msg "F--" and "r02"
Remove the lens, clean the contacts, reattach the lens, and jiggle the lens to seat the contacts. If that doesn't fix it, either the camera or the lens may require service.
Feb 19, 2009 | Nikon D80 Digital Camera with 18-135mm...
Cant put pictures on computer no soft ware
Please see the following post, as it outlines a much easier, faster, and less error prone alternative way to download your photos:
http://camerarepair.blogspot.com/2009/01/how-do-i-download-photos-or-pictures.html
Jan 26, 2009 | Canon Digital Rebel / EOS-300D Digital...
E 18 problem
Lens errors (E18 errors on Canons) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 10, 2009 | Canon Powershot SD450 / IXUS 55 Digital...
Sanyo s650
put duracell batteries in it it will work mine did the same thing when i first got it
Jul 19, 2008 | Sanyo Xacti VPC-S60 Digital Camera
Lens error
ok,i had this problem & couldnt find solution anywhere,so i took the back off the camera to reveal the lense unit.Now there is 2 screws in the middle of the back of the lense you need to remove together with ribbon cable.Underneath this is a small square rubber seal which was not seated properly.All i done was to seat it back in the right place,put all back together & hey presto,turned camera on & all was good.
This might not be the same problem you all have but it worked for me.
Good luck !!!
Jun 08, 2008 | Nikon COOLPIX S200 Digital Camera
Camera
the auto focus is bad can it be put into manual mode? might need a new lens.
Nov 08, 2007 | JVC GR-D70EK Mini DV Digital Camcorder
Kodak EASYSHARE M340 Digital Camera Logo
18 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
