Question about Whirlpool Dryers
I have model no# LE/GQ8000H I have heat but it does not tumble yes its an old unit but works fantastic until this problem
  • Whirlpool Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 12, 2010
Frigidaire Galaxy Dryer tumbles but heats to dry seldomly
What is the model number of the unit?
Nov 13, 2012 | Dryers
Drum turns on a 19 year old Maytag but no heat just cool air tumble.Help, cannot afford repair or new dryer currently.
It is most likely the heating element or thermostat, and since it is 19 years old, you might want to change both. You can go to www.searspartsdirect.com and plug in your model number and then find the heating element and thermostat in the parts layout.
It is not difficult to change either part - JUST MAKE SURE TO UNPLUG THE UNIT!
Jun 23, 2011 | Dryers
The dryer tumbles but does not heat. There is no
If you dry a lot, you may need heating coils. Heavy loads such as jeans and towels will put a premature stress on those coils.
Jun 21, 2010 | KitchenAid KEYS750LQ Electric Dryer
Dryer not blowing hot air- timer not working
im assuming your on the automatic cycle. on this cycle the timer will not advance without heat. check you house circuit breaker/fuse. if one goes the unit will run but will not heat.
Feb 08, 2010 | Dryers
My kenmore dryer modle # 9758920 tumbles but won't
ther is heat fuse on the fan unit and the heat unit check them and then you good :)...take power off first!!!
Dec 31, 2009 | Whirlpool LER5636P Electric Dryer
Whirlpool model LER7648PQ1 won't heat up
There are a few possibilities- I'll take you through them:
1) Most probable: your heating element has gone bad- actually they usually break when they go bad/burn out. This will likely require some skill and some instructions for you to repair- plan on replacing the heating coil and the door seal for good measure, especially if the unit is more than 5 years old.
2) Less probable but possible: are you sure your drum is tumbling? if not, your clothes won't dry and you'll lose the element in short order.
3) yes less probable but still possible- the contacts on the switch dedicated to heat settings or the thermostat have gone bad, denying current to the heating element.
Good luck!!
Dec 14, 2009 | Dryers
TUMBLES, MAKES ALL THE RIGHT NOISES BUT THERE IS NO HEAT.
1) Most probable: your heating element has gone bad- actually they usually break when they go bad/burn out. This will likely require some skill and some instructions for you to repair- plan on replacing the heating coil and the door seal for good measure, especially if the unit is more than 10 years old.
Good luck!!
I have a maytag model 747g dryer. I dryer tumbles
The heating element is burnt out. Unplug the dryer. Follow the wires from the control panel. They will go to the heating element. The element is probably held in by anywhere from 2 to 6 screws. Remove the screws and you should be able to pull out the element. The element is coiled wire that heats up when power is applied. If you look closely you can probably see a break in it. To get a replacement you will need the model number which will be on a metal plate either on the back of the dryer or inside the dryer door. Take the old part with you so you can do a comparison and make sure you get the right part.
Jul 17, 2009 | Dryers
I have a Kenmore Elite dishwasher, model number: 665.17263. The clean green light is blinking and unit work work. I had this problem before and the service guy showed me how to press the buttons in a...
All I had to do was to press the heatdry and normal wash buttons until all the lights went on. This happened before...Gingko was fantastic!!
Dec 03, 2008 | Dishwashers
Dryers Logo
52 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
