Question about Brother HL 5250DN Laser Printer
I have a Brother HL-5150DN. When printing envelopes from manual tray, the printer takes the envelope partially in, and then stops.
  • 526 Answers
If you have done a lot of enevelopes, most likely the pickup roller got paper fibers on the roller and does not have as much traction. try cleaning the roller with isopropal alcohol if that does not help, the roller will be probably need replacing.
Posted on Sep 02, 2010
How to load evelopes HL 2140
Brother Hl 2140 Printing on thick paper, labels and envelopes 2
When the back output tray is pulled down, the printer has a straight paper path from the manual feed slot through to the back of the printer. Use this paper feed and output method when you want to print on thick paper, labels or envelopes.
Open the back cover
Open the manual feed slot cover.
Using both hands, slide the manual feed slot paper guides to the width of the paper that you are going to use.
Using both hands, put one piece of paper or one envelope in the manual feed slot until the front edge of the paper or envelope touches the paper feed roller. When you feel the machine pull in the paper, let go.
• Put the paper into the manual feed slot with the side to be printed face up.
• Make sure that the paper or envelope is straight and in the proper position on the manual feed slot. If it is not, the paper or the envelope may not be fed properly, resulting in a skewed printout or a paper jam.
• Do not put more than one piece of paper in the manual feed slot at any one time, as it may cause a jam.
• If you put any Media (paper, envelope and so on) in the manual feed slot before the printer is in the Ready state, the media may be ejected without being printed on.
Jul 18, 2011 | Brother HL 2140 Laser Printer
Load and print envelopes
Generally NO. The reason is they have a manual slot and rear exit that keeps the path nearly straight for things like envelopes, labels, cardstock etc so they dont have to make the turn from the tray and from the fuser to the fact down exit tray. If you need to do a mailmerge with numerous envelopes you could 1) print a sheet of labels and stick those to blank envelopes or 2) go to a more advanced machine that has envelope feeder capability. Even a used machine such as a Laserjet 4000 - you can find envelope feeders that just attach on easily for almost nothing on ebay.
Jun 21, 2010 | Brother HL-2070N Laser Printer
Printer HL 5370 DW is wrinkling all envelopes. Is
If it's not wrinkling regular plain paper, then you need to tell the printer you're printing envelopes. Envelopes are thicker than letter paper. When you tell it to print, make sure you click on "Properties" and set the job for "Envelopes". Also, make sure the guides are set to fit the envelopes snugly.
Apr 25, 2010 | Brother HL-5370DWT Laser Printer
It won't print - says manual feed - load paper tray. Its a brand new printer (Brother HL-4040CDN) and the paper tray is full
The printer has an "alternate" feed, i.e., for envelopes and/or for special paper.
Open the door to access that "manual" tray, take some paper from the "normal" tray, and insert the paper into the "manual" tray.
Or, on the printer's controls, set the "standard" feed, rather than the "manual" feed, and press PRINT.
Nov 11, 2009 | Brother HL 1440 Laser Printer
Bends envelopes in printing
Most laser printers have an "S" paper path. They cannot help bending paper. I would suggest you print lables instead of envelopes if you send several letters. If you only send 1, hand address the envelope. Not elegant ut it works.
May 28, 2009 | Brother HL-2040 Laser Printer
Printing envelopes
Open a MS Word Document, select 'Tools' then 'Letters and mailings' then 'Envelopes and labels...'
Envelopes and Lables dialogue box opens - ensure you are on the 'envelopes' tab
Then type your recipient address in the larger white box
for standard letter envelope (DL 220m x 110mm) - Insert envelope into Brother HL-2030 manual feed, with print side up, gummed flaps down and to the left side (bring gray plastic guides in close to secure).
Then select print.
I have found that during the feed, one end of the envelope gets a little bit crumpled but overall it's still a little bit more professional looking than my handwriting.
Jan 12, 2009 | Brother HL-2030 Laser Printer
Can i print envelopes addresses on brother HL 2140 laser printers
The manual by-pass slot just below the brother name on the front allows a user to load envelopes just put the envelope in the slot and adjust the size.by closing the two grey tabs
Nov 25, 2008 | Brother HL 2140 Laser Printer
Can't print from the MP tray?
When you print labels or envelopes you need to select the correct tray from the print menu. (File print or ctrl P) or the printer will think the normal paper tray is being used.
You can force the printer to change the tray after the print has been sent by pressing the continue button on the printer, just make sure that the normal tray has no paper in it.
May 11, 2008 | Brother HL 5250DN Laser Printer
No longer prints envelopes from manual paper feed
you need to change driver configuration
very easy
elvis
Apr 01, 2008 | Brother HL-5240 Laser Printer
Brother HL 5250DN Laser Printer Logo
224 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
