Question about LG KU990 Viewty
LG viewty 4 gb memeory card..I accidently formated ths on phone! how do i unformat it?
Hi I just got the lg viewty and placed a 4 gb memory card into phone...then i made the mistake of formatting this....then after digging aorund online...i read somewhere that if hadn't formatted the memory card my computer would recognise 4gb....now that its formated the comp only recognise 2gb....how do i unformat the memory card ? help? thanks
  • Anonymous Jan 24, 2009
    do 4gb memory cards even work on the lg viewty, i am getting the phone and have been told that only a 2gb memory card will work ont 4gb?
Hi, I also had this issue.
The solution is on http://communities.sandisk.com/sandisk/board/message?board.id=mobile&message.id=209
You need to google for an app from HP called SP27608.exe.
This will read the card as 4gb and let you reformat it.
Posted on Nov 25, 2008
    Problem Solver:
  • 11 Answers
There is no way of UNformatting a mem card.
You can try to reformat if again. and this time be sure to set the proper settings..
If it is still 2GB. then tray formatting it on a different PC. using a card reader (assuming you previously used your phone to format the card,, if not. try it as well)
Posted on May 15, 2008
Where can I find software to link my LG vu 920 to my computer
u dont need software to do this- just an LG data cable. plug the cord into the phone, the other end into an available usb on ur pc, and ur good to go.jusat make sure that u are using a suitable memory card- up to 4 GB, and the primary storage is set to memeory card. then just drag and drop ur files to the card.
Jul 20, 2009 | LG Vu CU920 Cellular Phone
Lg viewty phone keeps freezing when i click on my
hi
my hunch is that the my files is located on the Memory card and the memory card is faulty try removing your memory card and accessing your 'My Files' if this works then you may have to replace your memory card
cheers
pls rate if this works
Jul 13, 2009 | LG KU990 Viewty
Looking for software/driver to transfer photos from LG VU to laptop.
You dont need any software to do this- just a LG data cable attached to your phone and to the computer. The LG software is useless for the VU. Your pc will recognize the phones memory card as a mass storage device, and you simply drag and drop files to and from the phone. You do need to have a memeory card installed of up to 4 GB.
Jun 30, 2009 | Cell Phones
Cannot copy anything to Memory card in LG Viewty
reformat your card through your pc. don't go for quick format. if it doesn't works after that also then get a software 4 low level formatting. if then also it doesn't works ask me again.
kindly rate my solution.
Jun 25, 2009 | LG KU990 Viewty
I had a memory card in my LG Viewty KU990 but I leant it to a friend and now it won't let me put it on `data storage' when I connect it into the LG PC Suite.
hi there,
do re-format the the memory card on your unit, it seems that data data structure of the card has been changed and needed to format the card to make it work again on your phone.
just let me know for further assistance,
Apr 28, 2009 | LG KU990 Viewty
Please help, i cant activate use of my memory card on the lg viewty
If its a new card, have you formatted it in the phone? (go to Menu, Settings, Phone Settings, Memory Manager, External Memory then click on the Format button).
To activate its use, go to Menu, Settings, Phone Settings, Memory Manager, Primary Storage Setting and select External Memory.
Apr 16, 2009 | LG KU990 Viewty
No sd card found in the phone
Have you tried using another memory card, or maybe using that same memory card on another phone and see if it works, because it could be either one othe them that could be malfuncioning, hopfully it is the memory card and not your phone.
But just in case if you find out it was the phone, try to reset settings to reset it back to factory settings and hopefully that will help, also check if the memory card slot is clean..Good luck
Dec 11, 2008 | LG KU990 Viewty
Need to reformat micro-sd card in up stage phone
max memory card the KU990 can handle upto 2Gb
Jul 21, 2008 | LG KU990 Viewty
Lg prada memory card
Indeed I do have a 4GB card. Tried a 1GB card and all is now ok... Many Thanks!!!
Mar 10, 2008 | LG Prada KE850 Cellular Phone
LG KU990 Viewty Logo
1,242 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
