Question about Refrigerators
Samsung fridge freezer model RL33SB - the base of freezer underneath the drawers collects a layer of ice which comes from water running down the back and i cant find where it is coming from
SOURCE: leaking fridge
Its probably the defrost circuit either the heater or the timer
Posted on Oct 30, 2007
fixitallguy
  • 11 Answers
SOURCE: layer of ice forming on bottom inside of freezer - Samsung fridge freezer
might have the temperature too high .. buy a freezer thermometer and place in freezer
Posted on Jan 25, 2008
philiptory
SOURCE: FFA 90 ICE BUILD UNDERNEATH THE BOTTOM TRAY
Symptoms:
Ice forms at the bottom of the Hotpoint FFA90 Freezer compartment, below the bottom drawer.
Cause:
The drain hole at the back of the freezer compartment is blocked with ice and sludge.
Solution:
This take about 20 minutes to complete.
1. Tools required:
- 7mm socket spinner.
- Phillips screwdriver.
- Clean damp cloth.
- Electric fan heater (optional, but it makes the job much quicker).
- A length of plastic tubing approx 3 ft (1 metre) long with 5mm bore (optional).
- A few inches of fairly stiff but flexible, insulated wire. I used a piece of yellow/green earth wire.
- A torch or inspection lamp.
2. Switch off the fridge and pull out the mains plug.
3. Remove all the freezer drawers. If there is food in them, wrap them in a duvet or something cosy to reduce thawing.
4. Place a shallow tray under the front of the freezer compartment to catch dripping water.
5. Switch the fan heater on to low heat, and let it blow into the freezer compartment from a distance. DO NOT get it too close - a gentle heat is all you need.
6. After a few minutes, use a blunt knife to prise the sheet of ice away from the bottom of the freezer compartment. I managed to lift mine out in one piece! - but it will probably crack into smaller pieces. Mop up as you go.
7. Using the 7mm spinner, remove the 8 self-tapping, hexagonal head screws that fix the back panel inside the freezer compartment. With all the screws removed, ease the panel out gently, pulling from the bottom first. It may stick a bit where ice has stuck to foam rubber inside, so don't pull to fast.
8. Put the panel on your draining board and allow it to thaw out. There will probably be lots of ice stuck to the foam rubber backing. Don't pull the ice off by hand - you may damage the foam.
9. At the back of the freezer compartment, below the chiller tubes, there is a drain hole about 15mm diameter, and this will probably be blocked with ice. Allow the fan heater to continue to thaw the ice in here, mopping up from time to time. Gently ease off any bits of ice with the blunt knife. As the ice thaws, the drain hole will gradually clear.
10. Insert one end of the plastic tube into the drain hole, and blow long and steady through the other. The warmth of your breath will help to thaw the ice in the drainage tube. Keep going until you have cleared about 5cm down.
11. Now use the piece of wire to poke down the hole and clear any further blockage. This should go down about 8-10 cm or so.
OK, that's cleared the drain hole and the drain pipe. Now you have to clear a messy brown sludge from the evaporation tray underneath, at the back.
12. Switch off the fan heater, and pull the fridge freezer away from the wall, so that you have clear access to the back.
13. Vacuum the dust and cobwebs out of the way - you need to see what you're doing!
14. Above the motor is the evaporation tray. Remove the two Phillips screws that fix it to the back of the fridge.
15. You'll need the torch for the next bit. Look between the top of the evaporation tray and the underneath of the freezer compartment. You will see a black, soft plastic tube about 18mm diameter that links the drainage hole with the tray. Use the screwdriver to prise the tube gently upwards and out of the tray. This could be messy with brown sludge.
16. Taking care not to damage or bend the metal pipes, gently remove the evaporation tray. This will probably have a messy brown sludge in parts.
17. Wash the tray clean; it will need a jet of water and a small washing up brush to get this clean.
18. Wipe the black plastic tube clean.
19. Replace the tray. The fiddly bit is getting the black tube back into the corresponding tubular hole in the tray. I had to remove the screw from the bottom left corner of the coolant pipework in order to get my hand in. Bend the black tube double so that the fold is towards you, and ease the end into the tubular hole in the tray; then push the tube down into place.
20. Re-fix the tray and fixing screw for the coolant pipes; then move the fridge freezer back into place.
21. The inner panel should have thawed somewhat. Gently remove any remaining ice and mop it dry. Press the aluminium foil and foam back into place. Wipe both sides clean.
22. Inside the freezer compartment, mop the coolant tubing gently. Mop the circular foam seal around the fan, and press it back into place.
23. Replace the inner panel. DO NOT over tighten the screws, as they are self-tapping into the plastic walls of the freezer compartment, and you might strip the thread.
24. Replace the freezer drawers, and switch on.
You should now be up and running.
I hope this is easy to understand! Good luck.
www.authorgraphic.co.uk
Posted on Nov 12, 2008
david04928
  • 102 Answers
SOURCE: Build up of ice on bottom of LG fridge freezer
Is it supposed to be self defrost? If so then either underneath the freezer needs to be cleaned. coils if dirty will cause freezer not to work well. I that doesn't help you might have a freon leak which would make it under charged and would ice up like that.
Posted on Mar 15, 2009
my maytag had cloged defrost drain cleaned drain all ok
Posted on Jul 03, 2009
Water is collecting in the drawers
Freezer /fridge water/ice in fridge and or freezer
Usually due to CONDENSATION due to bad door seals or a plugged evaporator drain line? Can use a soft flexable tubing and very hot water to clean it out. Bad door seals usually need replacement, but u can use a blow dryer and something to pry it closer to the door wall while blowing hot air on to it. To create a seal, to test for bad door seals place a dollar bill in between the door and wall of fridge where it closes. Then slide out the dollar bill with door closed. It should offer some resistance and not be easy to pull out.
Most all fridges have a drain. Look inside your fridge for a "V" shaped channel with a small hole. This hole leads to a tube and a small pan which sits on top of your refrigerator's compressor. The defrost cycle causes water to run into the channel, down the tube, and then it generally evaporates with the heat of the hot condenser/compressor.
However, if that tube is clogged with food crumbs, particles , debris etc, you will have to clear it to get back to a normal mode of operation. A toothpick, pipecleaner, straw or a cotton bud can often do the trick.
Even a frost free freezer will still ice up at times in the areas away from the heated defrost area and the drain line can freeze. This icing causes the pipe work to the compressor to ice over or sweat and cause a puddle. Or if the drainage has frozen over, it will need to be de-iced. ( usually the line is under the freezer bottom plate covering. Towards the back of the unit) And there is another inside the fridge area also.
Give the freezer a good overnight defrost until it's totally clear of ice in addition to making sure the drain is clear to the pan at the back and then restart the freezer.
May 27, 2014 | Samsung RB215LASH
On my LG top freezer model, it collects water in the bottom of the refrigerator, under the pull-out crisper drawers. there is no visual sign of were it is coming from. it does have an ice maker i8n the...
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Sep 17, 2011 | LG Refrigerators
Fridge is collecting water under the crisper drawer of my Samsung RF217 fridge, has french doors and bottom freezer. How do I get to the drain hose to thaw/flush it?
Leo Ponder
imufo2
Aug 16, 2011 | Samsung Refrigerators
Fridge and freezer are working just fine. But, I keep getting pools of water inside my fridge. These pools stay to the back of the fridge on all levels and they sometimes turn to ice. I notice ice layer...
Your defrost drain is most likely blocked with ice or sludge. Now when your refrigerator goes into defrost it pours into base of freezer or just anywhere it can to pool up. Click Here=> Leaking Refigerators, just what may be happening Click here also=> Leaking Refrigerator's? Please let me know if you still have questions, Thanks, Sea Breeze
Mar 19, 2011 | Whirlpool Refrigerators
Model CTX18GAZBRWW - (Hotpoint) no-frost - freezer on top Water collects under the vegetable drawers and must be removed every day.
Something to try....on the back wall of the fridge nearer to the top is a little cup like part sticking out. There is water in it but it usually runs down an attached tube inside back wall and ends up under the fridge and gets evaporated. If that tube or the little cup thing is plugged then it will drip in the fridge and collect on the inside bottom of the fridge. So the trick is to clean them out. Check it out ...may solve the problem.
Sep 07, 2010 | GE 18.2 Cu. Ft. Frost-Free Top-Mount...
Cold water collects in the bottom space below the drawers
this is just condensation as the fridge is not frost free.try placing a sheet of tissue in the bottom of the salad drawer and one under it, take out about once a week to keep dry
Mar 08, 2010 | Frigidaire FRT21H8 Top Freezer...
Fridgefreezer top fridge section has stopped
see if the back panel inside the refr comes off if it does and u have a fan back there make sure it is working if not make sure its gettin power to it and if it is and not running then replace it and see if this corrects the problem if this fails see if u have a duct going from the freezer to the refr if u do take it apart and see if somethings blocking the airflow or if it has a door thats stuck shut and not letting air go thru
Mar 01, 2010 | Refrigerators
Water pooling underneath bottom drawers
Find the drain line from the freezer to the evaporation pan near the motor. Often the line is visible on the back of the fridge. That line is plugged either with food residue or the collection point in the freezer is solid ice. The self defrost feature melts the frost and drains it to the evap pan. If you remove the floor from the freezer area, you will see the collection point. When the line gets plugged with food, no water drains and then freezes to block the line even worse. So, if there is ice at the collection point, remove it somehow, maybe a hair dryer, and then clear the line by blowing compressed air from the bottom of the drain hose through to the collection point.
May 28, 2009 | Frigidaire 20.6 cu. ft. Top Freezer...
Samsung RFG297AA Thin Film of Ice Forming Under Deli Drawer
My be an air leak,wipe/check all seals on doors and make sure doors are closing tight on seals.
Jul 24, 2017 | Samsung RF265AA Bottom Freezer French Door...
Refrigerators Logo
130 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
