Hi I have a netgear dg834g wireless router and for the past year it has dropped the connection intermittently with no set pattern as to why. The grren lights just freeze and it stops for approx 30 - 60 seconds, the page on the screen freezes and it is driving me nuts! The isp is BT and this all used to work fine but now it's a real pain. It can happen a dozen times a day, everyday, then other days just once or twice. I'm not ringing BT as the lne seems fine and I can't be bothered to talk to India about something they won't have the answer to. Can you help?
  • 32,281 Answers
The intermitten connection could be one or more problems with your wireless router and configuration. Please click on this link and follow my instructions to determine the problem/s and possible fix :-
http://www.fixya.com/support/r3559120-wireless_router_disconnecting
Posted on Sep 02, 2010
I use my net gear router wireless,but every now and then i loose the wireless conection,i try to log into the router but it takes me to web sites with the same numbers,why does it drop out and i carnt get...
I understand that your Netgear wireless connection drops every few minutes. This could be due to the RF channel conflict. Try changing the wireless channel to 1 on your router.
Thanks,
Shiva
Dec 18, 2010 | NetGear DG834G Router
Netgear DG834G router dropping internet connection
You could try a firmware update, if this is no better it may be time to ask your ISP for new router.
Aug 01, 2010 | NetGear DG834G Router
Hi i have a netgear DG834G router. My daughter has a pc in her room, and we have a wireless dongle. But i cant seem to unlock the router. Any ideas??
Check what is the wireless security set on the router by going to 192.168.0.1 on your browser. Check it under wireless settings.
Jan 28, 2010 | NetGear DG834G Router
Had my netgear router for months now and not had a
Solution to intermittent wireless connection is change the wireless channel of the router. Usually the default channel is 6 which is prone to interference. You may try channels 11 and 1. They are the next strongest channel of the router. Try to reset the router first.
Jun 06, 2009 | NetGear DG834G Router
Netgear DG834G with xbox360
Connect to the Router,
Under the Security tab, select Services, then add, give it the name XBOX TCP/UDP, set start port as 3074 and end port as 3074, set type as TCP/UDP, click apply/ok. Do this again, giving it the name XBOX UDP, start port 88, end port 88, type UDP, then apply settings.
Now go to Firewall under the Configuration tab, under incoming click add, now select the service XBOX UDP/TCP from the drop down menu. select forward to specific IP address or similar and type in your Xbox's IP address e.g. 192.168.1.5, click log never, then apply ok. Do the same for XBOX UDP and your again click apply. That's it! you've successfully opened the necessary ports on your Router and told your Router that any incoming info on those ports should be sent to your Xbox.
Mar 02, 2009 | NetGear DG834G Router
Have lost/can't remember the security code to wirelessly connect to my netgear DG 834G
Paul.
Can you connect to the router via ethernet?
If so assuming you havent changed the routers address connecting to 192.168.0.1 from your web browser should get you into your routers admin page.
Once you have entered the user name and password click the Wireless link from teh main menu where you will be able to see the relevent key and or change it if required.
If you need the manuals you can download from here.
http://kbserver.netgear.com/products/DG834G.asp
Regards
Nick
Oct 28, 2008 | NetGear DG834G Router
Connecting to an existing wireless LAN
Hi there you can find the instructions for connecting your netgear DG8345G wireless router to your existing wireless router by configuring first your netgear router and click to help so that you can see the instructions by configuring it into your pc or you will go to the netgear support website so that you can find that model and look for instructions for your netgear router..
Jun 25, 2008 | NetGear DG834G 802.11G Wireless ADSL...
Netgear DG834G Setup
Hi Tradeboy,
This link should walk you though it, step by step!
http://www.geekgirls.com/windowsxp_home_network.htm
If you are using Vista, you will probley want this link, too. Click on Network icon.
http://windowshelp.microsoft.com/Windows/en-US/default.mspx
In the past I have found the biggest issue with networking is firewalls, so I suggest you disable them just for testing and setting up your network.
Good Luck
Jan 11, 2008 | NetGear DG834G Router
Are you getting any internet?
Are you using Windows Vista?
Oct 19, 2007 | NetGear DG834G 54 Mbps 802.11g Wireless...
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
