Question about Hoover HTC243 Top Load Washer
Hi there, i have a hoover elite 1220 i think 7.5kgs i brought it second hand of ebay and it has been a good machine but it has started to play up lately. It washes all on the normal cycles and stuff i only use cold water but it gets to the final sray and spin cycle and wont spin the water is gone as in the machine is not full but the clothes are still drenched in water and not wrung out like ususal. do u have any suggestions? i only paid $41 so it is not worth my while getting sum1 out to fix it i was just wondering if you could help. thanks nicole
Have a look to see if the clothes are spinning around when the lid is lifted up in spin cycle as the same has happen to mine and doesn't spin around it is clutch or gearbox
Posted on Sep 13, 2010
    President:
  • 1,932 Answers
Following will be the causes for water not draining properly
1.There is a motor/Pump which operates to to drain the water check whether that motor is working.
2.Check filter and clean it
3.Check the drain pipeline whether it clear
4.Check the inlet valve of the machine Sometimes the drain works properly but the inlet solenoid valve will not hold and the water keeps coming in and fills the drum
Thank You
Posted on Sep 02, 2010
Why is the drum not spinning on my Hoover VisionTech VTS712D21 Washing Machine?
It could be the drum bearings are seizing or something is causing it to jam.
If this is the case the motor would work too hard and draw too much current and consequently would cut out for a time and then reset.
Removing the drivebelt and turning the drum by hand would show if this is probable.
Feb 20, 2017 | Hoover Washing Machines
Hoover 960 elite washing machine
contact manufacturer they should be able to help you
Aug 25, 2014 | Washing Machines
Hoover htc 243 not turning on
you main bord is faulty that will cost more then a second hand machine ok
Oct 17, 2012 | Hoover HTC243 Top Load Washer
My hoover elite belt comes off within 5 seconds of turning it on
Those machines sit in the box in transit across the world and waiting for purchase. In time the rubber stretches out from just sitting there. In the old days they packed the belt separate from the vacuum and you had to put in on yourself. Today's buyers aren't so handy so the manufacturers are forced to put the belts on before sale. 80% of returned vacuums are due to this! Find the local Hoover Warranty center on the hoover dealer locator at hoover.com and they'll set you up with a new belt at no charge. Good Luck!
Oct 03, 2012 | Hoover Elite Rewind Bagless Upright...
The air flow indicator on my hoover elite rewind bagless vacuum shows mostly yellow. we have followed all the directions in the manual - empty dirt cup, cleaned filter, checked two locations for blockage,...
Hi, sounds like you may have a small leak in the vacuum body. After changing the filter etc. turn machine on and run your hands alond vac. body. If there is a leak you will feel or hear it. If leak is found the light should change when you cover it. I hope this helps you./ Its hard to give advice without seeing it. Give it a try then let me know how you are doing. Chris
Feb 09, 2011 | Hoover U5507900 Elite Rewind Bagless...
Where can i order a hoover bag and filter for a nilfisk gsd 80 hoover and how much will these items cost me
First try online using Craiglist, Ebay, or look for local store near you. If you want to save really good. Some goodwill, Salvation Army, Value Village Stores do have new or second hand vacuum bags. Just write what you need, the Model Number, or the Type A or B Vacuum bags. Usually Hoover bags are popular. Except some new ones and also High End Vacuum like Kirby, and Vacuum from TV Informercials.
Sep 07, 2010 | Vacuums
Bad vibration during spin
Good morning! It's common to a washing machine to go out of balance everytime we exceeded the prescribed capacity load (as indicated in the enclosed manual upon purchase of the unit). the fitted new pump is not the source of such problem. Please try to review the manual of your machine and take note of the required capacity load which I think should not exceed 6kg. Best regards.
May 02, 2009 | Washing Machines
User guide for hoover performa eco 1200
http://service.hoover.co.uk/manuals/Manuals.aspx?Section=10
go to that website to get an online manual for any hoover machine. the performa eco is a WB120.
Mar 26, 2009 | Washing Machines
Hoover Elite 1205 washing machine
Does an Hoover elite 920 gearbox fit the hoover elite 1205 thanks
Sep 18, 2007 | Washing Machines
Hoover HTC243 Top Load Washer Logo
197 people viewed this question
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
