Question about Ge Medical Systems Ge Healthcare Mac 1200 Resting Ecg System 1200 Battery
Need replacement parts - plastic clips that attach to leads.
  • 71 Answers
They usually sell these by the pack but we have a lot in stock and I can separate them for you. I just need to know what style you have so that I can provide the right one. Send a pic if you can and I will help you with this issue.
wats@mesasales.com or 800-989-4909. www.overstockme.com
Posted on Sep 04, 2010
Bought window regulator for 2000 Olds Alero but plastic clip that is attached to bracket and glues to window is broken . So can't connect regulator to clip . Can clip be replaced ? How can old clip that's...
Replacement clips are available through specialty auto parts stores...there are many tricks or solvents that will loosen the glue on the broken clip...if you damage the glass, you can find a popular window replacement, inspect the clip too, at your nearby salvage yard or online...Hope this helps.
Nov 06, 2013 | 2000 Oldsmobile Alero
Replace door handle
You must be talking about the door handle itself. The rod connects the door handle to the door latch. The plastic clip when snapped onto the rod will keep the rod from coming out of the hole in the door handle where it attaches. Is it the handle that is broke or the clip?
May 23, 2013 | Chrysler 300M Cars & Trucks
How do you replace the grill on a 2003 Mercury Sable, what is the part name/number for the clips?
Retaining clips for the grill. Dealer only. Are the plastic tabs still on the grill? If not, forget the clips. Silicone it in place. Use tape to hold it and let it set for a day.
Jun 20, 2012 | 2003 Mercury Sable
How do you replace a headlight on a 2006 lincoln town car (low beam - left side)
Open the hood. Remove the black plastic grill assssembly ( Laying horizontal between the radiator and front bumper). There will be a couple of plastic screws (or some other fastening system) for this part remove and set aside. There is another black plastic grill assembly standing vertical. Remove similar fastening devices and set aside. IF DURING THIS ENTIRE PROCESS there is ANY part that does not come off freely after removing a fastening device (plastic screw, metal screws, hex bolts, bolts) LOOK FOR A PLASTIC CLIP - unclip that as a final step in each of these processes. To continue, Each headlight is attached by three hex or phillips screws.- Remove them and set asside. There is a major clip attaching the headlight at the top. Unattach this and gently remove the entire light housing. The housing will be the unit containing all parts high beam, low beams, side lights, and blinkers. It is a nice tidy unit. To continue, look for a black plastic removable panel on the back allowing access to the back of the bulbs. Remove the 5 screws and set asside. You now have access to the bulbs. The bulbs are attached by a solid plastic clip. Grab the back of the plastic bulb housing and turn about a half of an inch to remove the bulb. Unattach the clip from the wirering harness and you will have the bulb removed. CAREFULLY remove the new bulb making sure not to touch the glass portion of the bulb with hands directly. Skin oils or other debris is not recommended to get on the bulb. Deliberately refasten the bulb wiring harness and replace to the back of the reflection housing. Reassemble all devices. Rinse wash repeat for the other side :)
This seems complex for the task at hand and it is. But from the perspective of repairing a front end after a minor collision is is wonderful. Enjoy...
Jul 23, 2010 | 2006 Lincoln Town Car
Maytag mce8000 ayw. Want to remove plastic cover
The font panel must be removed. This may be done by removing the control console (open upper cabinet doors to find screws behind the console). After you remove the control console, the screws along the top of the lower front panel are easily accessible. Disconnect the two interlock switches, remove the grounding clip attached to the bulkhead & lift the panel off the two lower clips. Inside the panel is the housing that leads to the exhaust blower. Just clean out the mess & reverse the process to replace the parts.
Feb 14, 2010 | Maytag Dryers
I need to replace the cam agit for this sear kenmore washer. is it a serviceable piece and if so, what tools do i need?
Assuming that you know how to remove the cabinet, agitator (you don't need to remove the tub), pump, motor and transmission the agitator cam and follower use the same whirlpool part number 62580/01. This is a plastic set used to raise the agitate gear on the shaft.
I had the same problem with gear grinding and this solved it.
Pull the transmission.
remove the clutch (the spring holding the clutch to the spin pinion is a bear to replace.
Remove the 8 transmission screws carefully, the transmission is full (16 oz.) of 80-90 weight oil.
Remove the transmission cover.
Pull off the spin pinion.
Push down on the agitate spring and remove the spring clip. Note where is attaches to the main shaft.
The two plastic agitate cam parts pull right off. Don't lose the washer on top of the cams.
Replace the cams, washer, spring and clip, pinion, oil (assuming you drained the oil first), cover and clutch parts.
Line up the transmission so that the release cam on the brake drum will snap onto the clutch spring retaining clip and put all parts back in the washer.
The basic tools are screwdriver, small socket set with up to a 1/2" socket, vice grips or good pliers (to remove and replace clips)
Sep 15, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
1991 corolla door rod handle plastic clip broken
You can get inside door handle either new or used from sellers on ebay. It should be just a few dollars plus shipping. Just search ebay for "Inside door handle 1991 Toyota Corolla."
Frank
Frank's Friendly Cars Maui Car Rental
www.MauiCarRental.biz
Aug 01, 2009 | 1996 Toyota Corolla
Searching for a clip
Iwould asssume your lookin for number 32 on the door nd latch breakdown, you can call hyour local part distributer for ordering info
#32 8181929 Clip, Trim
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208180440.pdf
Jan 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Ge Medical Systems Ge Healthcare Mac 1200 Resting Ecg System 1200 Battery Logo
102 people viewed this question
Top Ge Medical Systems Medical Experts
Electro Med Services...
Steven Clarke
Steven Clarke
ka4iup
ka4iup
Are you a Ge Medical Systems Medical Expert? Answer questions, earn points and help others
