Freezer /fridge leaking water/ice frozen in fridge and or freezer, or leaks on floor
Usually due to
CONDENSATION due to bad door seals or a plugged evaporator drain line? Can use a soft flexable tubing and very hot water to clean it out. Bad door seals usually need replacement, but u can use a blow dryer and something to pry it closer to the door wall while blowing hot air on to it. To create a seal, to test for bad door seals place a dollar bill in between the door and wall of fridge where it closes. Then slide out the dollar bill with door closed. It should offer some resistance and not be easy to pull out.
Fix any gaps in the door seal.Pack out the seal underneath the areas where the door seal has the gaps. This can be done with a small strip of weather stripping, as shown here, or a bit of tightly rolled up paper under the door seal. Alternatively, you can heat the door seal up with a hair dryer to fix the gaps. This softens the door seal and allows you to stretch it.
Most all fridges have a drain. Look inside your fridge for a "V" shaped channel with a small hole. This hole leads to a tube and a small pan which sits on top of your refrigerator's compressor. The defrost cycle causes water to run into the channel, down the tube, and then it generally evaporates with the heat of the hot condenser/compressor.
However, if that tube is clogged with food crumbs, particles , debris etc, you will have to clear it to get back to a normal mode of operation. A toothpick, pipecleaner, straw or a cotton bud can often do the trick. Another trick one can use is to connect a copper tube wire
with one end going into the drain hole then attach the other end to the heater wrap it around heater a few times. That will take care of the drain problem when it comes to ice build up but not food build up.
Even a frost free freezer will still ice up at times in the areas away from the heated defrost area and the drain line can freeze. This icing causes the pipe work to the compressor to ice over or sweat and cause a puddle. Or if the drainage has frozen over, it will need to be de-iced. ( usually the line is under the freezer bottom plate covering. Towards the back of the unit) And there is another inside the fridge area also.
Give the freezer a good overnight defrost until it's totally clear of ice in addition to making sure the drain is clear to the pan at the back and then restart the freezer.
God is so good: so this is why I give free advice so please thank him not me.
OTHER THINGS TO CHECK ARE THE DEFROST TERMINATOR AND THE HEATER ELEMENT FOR COBNTINUITY.
http://www.appliancerepair.net/refrigerator-repair-1.html
Refrigeration System Basics Chapter 1
