Question about Dometic Rooftop RV Air Conditioner
I have a model 600315321 roof a/c unit it is a due therm 5 years old. The unit was cooling fine when I went to bed. The next morning I noticed that the compressor was short cycling, the fan runs fine, I removed the cover and found no ice on anything.I cleaned the condenser but got very little dirt out. I think the start capicator or run capicator are bad. What due you think.
    Top Expert:
  • Dometic Master
  • 5,673 Answers
Bad compressor
Posted on Sep 15, 2017
  • 49 Answers
SOURCE: duo therm roof top a/c
Sounds like 1 of 3. Blower motor capacitor, relay or thermostat. Try to run fan only if that is an option and see.
Posted on Jun 01, 2008
koolbreezes
  • 540 Answers
SOURCE: duo-therm 13500 roof a c
Sounds like a bad thermostat switch, (stuck close--or in run position).
Posted on Sep 04, 2008
  • 659 Answers
SOURCE: Duo Therm compressor tries to start and kicks out
I don't think these little units have a start capacitor but what I would do is check that the on/off switch wires to make sure they aren't loose. Also check the wires to the compressor for loose wires as well. It is possible that these are the first signs that the compressor is about to fail. They also can act up some when they haven't been used for awhile and then you try and start them up. Try running the unit for a few hours without asking it to cycle. It might just be a sticky valve.
Posted on Apr 13, 2009
  • 10 Answers
SOURCE: I have a Duo Therm Roof top Camper air conditioner
how old is unit and does it have refrigerant in it
Posted on May 31, 2009
motor1258
  • 6674 Answers
SOURCE: Dometec Briskair Duo-Therm Compressor won't quit running
Have you taken return air filter grille down at ceiling assy, & cleaned filter with dish soap & warm water? Check & see if you see little probe sticking out in behind there, and wipe it carefully as well, and make sure it's lined up to sense air flowing through there. Take a flashlight & look up into coils at front for lots of dust on them as well. Perhaps a thorough cleaning of all coils is in order if you say there's lots of dust, as choking airflow off with dust & dirt, will only shorten life of unit & use more hydro than necessary.
Posted on Jul 11, 2009
Duo Therm 3109228.001
sounds like thermostat issue not communicating with relay modeule
Aug 01, 2014 | Dometic 3109228.001 Duo Therm Comfort...
I have a 2006 Gulfstream Cavalier 8'x 32' Fema Travel Trailer with a Dometic Duo Therm AC unit which I have recently replaced the fan motor on. Had the dealership bench test motor prior to lea
There is ice forming on the evaporator coils. This is either from a low freon charge or a leak in the seals or windows and doors. Could also be that the drains are not working and water is building up and freezing
Oct 10, 2012 | Dometic Heating & Cooling
AC compressor will not engage
It could be the capacitor, it could be a loose wire connection, it could be a delay switch or a contactor/relay.
Mar 30, 2010 | Dometic Rooftop RV Air Conditioner
AC roof unit stops cooling after rain
No, the units are sealed and the rain should not have affected the system at all. I would remove the outer cover of the unit and access the capacitors. Your start capacitor may be bad. You can visually inspect this and tell if there is a problem. Small black relay on top of capacitor often burns out, if so, replace capacitor and relay. If this looks fine, then we need to start at the thermostat and work our way forward.
Thanks,
Jeff
Jul 05, 2009 | Dometic Rooftop RV Air Conditioner
May 30, 2009 | Dometic Rooftop RV Air Conditioner
Duo therm penquin 630215 went out, replace with what??
Actually thats a, Great Idea. And far Less Expensive.
1: The only thing i suggest is, Remember that a "Thermostats" Job is to Sense when the Temperature in the room is satisfied it Kicks off the Compressor, That is its Job.
2: The Front is Desinged to Cool Just the Front Area.
3: You Have 2 options
1: Close the Rear door when just Using the "Front Unit"
2; If you choose to Leave the "Rear Door" Open, Just make sure the "Rear Unit" is on Making the "Front Unit" Work far less.
You will be fine
Please Rate me, Thanks George
Apr 27, 2009 | Dometic Rooftop RV Air Conditioner
GE JVM 1650BB does not heat...
My magnatron went out on my 2003 model ge replaced the part but I had to pay the labor.Mine had a ten year warranty on parts.
Oct 17, 2008 | GE JVM1650 1000 Watts Microwave Oven
Duo therm air conditioner
my duo therm air works beautifuly all day but at night when we go to bed it seams to turn on and shut off rapidly. what could be wrong?
Jul 06, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
100 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
