Question about Apple MacBook Pro Notebook
MacBook Air. On start up, system tells me that the hard disk is full. Then hangs, with a blue screen. I get the shut down etc dialogue box, but that's all. Are there any start-up options to get around this? I need to get at finder to remove some files...
    Guru:
  • 206 Answers
Thank you for contacting Fixya Support.
Try these steps:
- - Reboot your Mac
- - Upon restarting your Mac, press the Shift key.
- - Hold the Shift key until you see a White Screen with Gray Apple icon and eventually a spinning gear.
- - When you see the Spinning gear, release the Shift key.
- - Allow the Mac to continue booting up. Also this may take a little while
(NOTE: this may take anywhere from 5 to 15 minutes to load to the Safe mode screen depending on the performance of your Mac, but if it exceeds this time, shutdown your Mac and try just once more. It may have just frozen up the first time around for you.)
- - You are going to enter the Safe Mode (which looks like your main desktop environment - the only difference is certain startup items are disabled.)
- - Once within the Desktop in Safe Mode
- - From the Finder Menu, click Go> Go to Folder
- - Type in this line: /System/Library/StartupItems
- - This path, is going to take you to the System Library folder which has all of your Mac OS X Startupitems.
- - Remove all of those folders to the Trash.
*Reboot your Mac normally and see if you can access your normal User desktop environment.
This should help.
Regards,
-Mactechtrainer
Posted on Sep 04, 2010
Why does apple laptop tell start up - disk is full
Your hard disk is full. Or full enough to cause problems.
Oct 14, 2015 | Apple MacBook Air
My macbook air start to show me a white screen white a blinking folder inside
Sound like you have an issue with either your hard drive or the operating system has lost the plot. Try this OS About OS Recovery
If you are able to access the recovery partition then use the disk utility to check the disk.
If this does not work then take the computer to an Apple repair centre, if it's still covered by warranty the disk might be replaced under warranty.
If it's not covered, you could try using DiskWarrior 4 The Disk Utility for Mac Disk Repair Mac Directory Repair... which has allowed me to recover disks that have not been able to be repaired with Apple's disk utility.
Dec 28, 2013 | Apple MacBook Air
Hi,\r\ni have a problem with my macbook air when
Try restarting your computer while holding down the X key. This may force the computer to start up using your Mac OS X system. If it does, release the X key, then open System Preferences and click Startup Disk. Make sure your Mac OS X system is selected. If you are unable to start up using the X key, restart your computer and immediately press and hold the Option key. Release the Option key when icons start to appear in the center of the screen. Select the Mac OS X system disk, then click the forward arrow to continue starting up.
If the above attempts to reselect your Mac OS X startup volume are unsuccessful, try resetting PRAM. Shut down your computer, then turn on the computer and immediately press and hold Command-Option-P-R until you hear the startup sound for the second time. Open System Preferences, click Startup Disk, and select your Mac OS X volume.
Hope this helps. If none of these options fix your problem, bring your computer to an Apple store, they are always very helpful and almost never fail to fix the problem!
Mar 11, 2011 | Apple MacBook Air
Mac book starts with blue screen startup disk full
your disk partition is having problem.if u have not taken backup then boot the system with FW mode with saperate Laptop and backup the data,then repartition the hdd and install freshly
Apr 17, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Hanging blue screen on 13-inch MacBook
The issue is with the software.Boot the system with installation media and go to disk utility and repair the file permission.This can solv the issue.If still the issue persist.Then go ahed and format the drive and re install the software
Mar 07, 2010 | Apple 13-inch MacBook - Intel 2.0GHz Intel...
Computer keeps shutting off without warning
If the PC doesnt show the shutting down dialogue, then hardware proble if it does then its a software problem. Try to replace the powersupply, abnormal voltage sometimes causes this problem, memory and motherboard errors can cause your PC hangs up or blue screen but will not shut off.
Oct 21, 2009 | Computers & Internet
When I start my macbook a blue screen appears with a folder with a ? mark in it flashing
That message means that it can't find the start up folder and or your hard drive has crashed.
If you insert your OS disk or a copy of Disk Warrior you can boot to the cd / dvd by holding down the "C" key and then powering up the Macbook.
Let me know if you have that OS cd and then we'll go from there.
Jun 13, 2009 | Apple MacBook PC Notebook
Macbook start-up
http://www.retrodata.co.uk/notice_apple_seagate_drives.php
May 11, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Software hangs
Tell Plustec this seems a common problem- perhaps there is a patch
Jun 22, 2007 | Plustek OpticFilm 7200i Film Scanner
Apple MacBook Pro Notebook Logo
362 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
