Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Whirlpool refrigerator getting hot on frame where doors close.
  • Whirlpool Master
  • 2,605 Answers
Welcome to FixYa.
I`ll start by letting you know first the heat between the doors is normal...to a degree, and done by design to help prevent moisture along the "breaker strip"/divider.
If all else appears fine, temp. Ok, fans running, no significant frost build up on freezer back wall, it's likely nothing to be concerned about.
**Just be sure the condensor fan isn't jammed and still turning.** The fan at the back next to the compressor.
The amount of heat can be determined by several factor's such as,
1) temperature setting - lower ( colder ) the temperature is set the more the run time the hotter the strip.
2) The ambient temperature - hotter the environment the more the unit runs to compensate, hence the hotter the strip.
3) The amount of "fresh" content added to the unit ( especially freezer section if unfrozen items added ) - new items add a lot of warmth thus demanding the unit to run more to remove this heat (btu`s or british thermal unit`s )causing the strip to be hotter.
4) Build up of dust & dirt on the condensor coils - this also causes the unit to run excessively which in turn makes for more heat on this strip.
These are all things which can and do determine the amount of heat between the doors.
Another factor to always consider is of course If it is hot where you live the unit may just be running more to compensate as with other factors I mentioned.
Hope this answer's your question and let me know if I can assist you further.
Thank's for coming to "fixya" and good luck moving forward.
Please take a second to rate the info provided here.
macmarkus :)
Posted on Sep 02, 2010
5 Suggested Answers
  • 531 Answers
SOURCE: GE profile side by side refrigerator door won't close
if you took out the door for the refrigerator to put in your house thats were your problem or gasket have to change
Posted on Apr 01, 2009
Sea Breeze
  • 4654 Answers
SOURCE: GC5SHEXNQ02 Whirlpool 2door ref - Panel gets hot
I am not going to say the problem is normal. Normal operation those strips are placed behind the metal and inside the walls around the door seals to prevent moisture or sweating around the doors. They are usually noticed to become hot when there is a change in the control boards operation. Some brands have the hot gas from the condenser circulating around the doors. If your model has an economy switch, switch it on. I would look for any abnormal operation of the refrigerator like compressor or condenser fan stopping or ice buildup or abnormal temperatures in the fresh food compartment. If this continues I would unplug the refrigerator and open the control panel inside the fresh food section and examine both sides of the control board for signs of heat or burn marks on both sides. May not be anything to be concerned about also because this may be the first time you noticed this. But it should not be too hot to touch. Sea Breeze
Posted on Jun 23, 2009
  • 93 Answers
SOURCE: The external metal frame is VERY HOT
Your condenser fan is probably not running. 99 percent of the time that you feel that hot spot it is from the condenser fan not running and the unit is not rejecting any heat
Posted on Sep 13, 2009
  • 119 Answers
SOURCE: I have a whirlpool gold refrigerator side by side
THIS IS A HEATER TO KEEP FROM CONDENSATION MAKE SURE COIL UNDER REF ARE CLEAN AND NO FROST ON THE BACK PANEL
Posted on Jan 31, 2010
Whirlpool double door fridge. Door wont stay closed. Have to push extra hard to keep it closed
Take out the shelves and drawers. check the rear is clear of ice before putting them back in place, and ensure they are not stopping the door closing. Next check the top and bottom of the door. Is it hitting the frame when closing? If so, straighten it up by tapping the hinge side of the door to make it square to the frame.
Jul 04, 2015 | Whirlpool Refrigerators
The center of refrigerator where doors close gets very hot
Here is a tip that I wrote about the reasons why the sides and/or seals couldbe getting hot on your refrigerator.
RefrigeratorTrouble The Outside of Refrigerator Hot
heatman101
Jul 07, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Door gets warm
Warm is normal hot is not. Too hot is an indication that the condenser coils are overheating due to being dirty or a bad fan motor. See the link below for details I put together on this. Let me know if it helps.
Hot Condenser
Jun 03, 2010 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
The middle part of the fridge frame where the side by side doors close onto is very hot to the touch. The fridge and the freezer portion themselves are working properly, but I just leaned on the frame in...
I had the same problem. I had just brush cleaned my coils and then it began. When I took the back off the fridge, I saw the fan was not spinning. I unplugged the fridge and then tried to spin the fan blades. I had inadvertantly bent a blade so it would not spin. I bent the blade back into shape and turned it on. The fan worked and very quickly the middle was no longer hot.
Apr 18, 2010 | Refrigerators
Sep 13, 2009 | Refrigerators
Whirlpool fbb36af20/2 fridge freezer frame of front fridge freezer getting hot, fan at bottom back stoped working replaced fan but when you plug in new fan it starts to work but when you fully push the fan...
Hot frame is mullion heaters. Keeps moisture from forming on door and causing rust. Sounds like the connector is defective, remove connectors and wire direct. If fan won't run then you need to call a qualified service tech.
Sep 09, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerator gets extra hot on top and side
The only thing that I can think of that would cause this is heat strips that are placed around the door frames to prevent moisture from forming around the doors. The way you have explain what is happening is an indication that the strips are out of control. If you can find the model number located on the bottom of the fresh food compartment door frame behind door get that for me. The problem is unsafe and should have your full attention until resolved. The parts cannot be replaced and can short out. If you have a local dealer or someone to talk to about the problem would be a good
idea. If you can find model number let me know. The model number above your post appears to be incorrect. Thank You Sea Breeze
May 24, 2009 | Whirlpool GD2SHGX Refrigerator
Heat strip is to hot on freezer door frame whirlpool frige sxs.....
Two things can cause this:
1. Dirty coils.
2. Bad condensor fan motor (this cools the coils). The fan motor can be accessed from the back by removing the lower panel.
Dec 03, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Loud Humming and Hot Front Panel
DONT TOUCH ANYTHING. IF IT IS COOLING CORRECTLY LEAVE IT. LOUD HUMMING IS COMMON ON SOME COMPRESSORS.(ANNOYING I KNOW).THE HEATING ON THE FRONT IS NORMAL AS IT IS THE MULLON HEATERS WHICH RUN THROUGH THE FRAME. IF THAT AREA WERE COLD, CONDENSATION WOULD OCCUR AND WOULD DRIP CONTINUOUSLY.
May 31, 2007 | Whirlpool 21.7 cu. ft. Side-by-Side...
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
592 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
