Question about Cavalry Storage Cavalry 500GB 3.5 7200RPM USB 2.0 External with One Touch Back-Up 500 GB Hard Drive
Installed CAUM 37500-B. Get a PATH NOT FOUND ERROR message when trying to copy from Hard Drive to Cavalry CAUM.
The_PhoeniX
  • 156 Answers
SOURCE: installation of linux on sata hard disk
RHEL3 does not support SATA disks...
If you want to stick with RHEL3 then no way you can use the SATA drive. only IDE drives will work.Also no seperate working drivers is available..
See this link
it says that only from RHEL4 update 1 that the SATA disk is supported, and that too involves some specifics to work properly
Posted on Apr 12, 2008
mosesclive
  • 191 Answers
SOURCE: no drives found
Tour full installation guide
http://www.windowsreinstall.com/
This will help you to get you hdd and windows running.
Posted on Aug 11, 2008
  • 909 Answers
SOURCE: dell inspiron 5150 primary hard drive disk 0 not found
You may find that either the cable is not connected properly or is faulty, or the worse case the mother board has problems (driver, chips, breakages)
May even be a power supply problem, as the power supply has many output points and different voltages that the HDD power out may have blown. If it has then the rest of the system will appear to be ok.
So first off, check the cables connections on the motherboard, and look for any breaks in the cables, and if you have a power meter of some sort check the power connection, or plug in another power connector, the ones with the same end are generally the same power outputs. The ribbon cable for the HDD should have 2 sockets for HDDs and you must connect your HDD to the end one.
Posted on May 14, 2009
SelfHelpComp
  • 146 Answers
SOURCE: I have data on my CAVALRY ext storage hard
sounds like it's time for a disk recovery exercise. Check the repair directory on fixya for your zip code. That's about all you can do at this point. Hope you had it backed up.
Posted on Dec 05, 2009
bob_computer
  • 3153 Answers
SOURCE: The front light changed from blue to red and now
http://www.fixya.com/support/r4247716-usb_device
Check ther for most of the simple and common fixes
Bob
Posted on Jul 18, 2010
Cavalry hard drive gets error message
click start control panel administrative tools computer management then select event viewer depending on what operating sytem you have this may vary
extend the events there you will ((see errors in red)) you will no what exactly what the error was and at what time it occured
you might be able work your way through the problem
if it's a program file you might uninstall the program restart your computer then reinstall some of these files/software
hope this helps
May 08, 2012 | Cavalry Storage Cavalry Computers &...
I have data on my CAVALRY ext storage hard drive(250GB). I power it up and try to access but the message comes up saying 'reformat the disk before use'. I cannot access any of my data. What do I do?
Dec 05, 2009 | Cavalry Storage CAUE37250 250 GB USB 2.0...
Cannot copy DSC02049: The path is too deep. Error message appears. The file is less than 1MB in size. This message appears even when copying from the root directories. It has 490MB available memory. The...
It seems all USB ports are not equal. Of the ports available, the ones on one side of the computer seem better than the ones on the other side. Changing to a different port solved the problem. There have been no data transfer issues since the change.
Oct 02, 2008 | Verbatim CORPORATION 94933 USB 2.1GB...
Transfer between 2 External Drives
the best program for this file transfer is Director Opus 9 this can transfer 100gig in under 1hr as with windows transfer takes 6hrs.
As I do alot of video capture and my filse range from 400mb to 4gig in size and having to transfer 700 gig about would take forever and with this program quick and easy you also can transfer over lan or wirless net.
happy transfering
Jul 08, 2008 | Cavalry Storage Computers & Internet
Exact Error
How important is the data on the drive exactly?
Jun 18, 2008 | ACP Cavalry (CAUE37500) 500 GB USB 2.0...
Open Questions:
Secure Your Data With Our Online Backup Services ' DataAlign In vanilla terms, a backup or the process of backing up, refers to the copying and archiving of computer data so it may be used to restore the original after a data loss event. Backups have two distinct purposes. The primary purpose is to recover data after its loss, be it by data deletion or corruption. The simplest definition of a computer backup is an exact copy. In the case of computer files, we are referring to copies of the original files that you have on your laptop, desktop, or external drive. Creating a backup of original content means having that data saved in two places, but it's also important to make sure that those two places aren't on the same type of device. For example, if you have 3 copies of a working document on your computer, if your computer crashes, you will still lose all three. This makes the backup method and medium, an important thing to consider for your backup strategy. With the kind of Online Cloud Backup technology being used these days, it is extremely important to back up your files. Ideally, we store data files, movies, music, photos and our official documents on the computer. With the ever-changing technology, desktops and laptops have reduced in cost, and the quantum of storage inside them has surged considerably over the last few years. Unfortunately, storing all your data in only one place is risky. Accidental deletion, theft, computer loss, natural disaster is just some of the reasons that could cost you heavily as you stand out the chance to lose the data you've spent so long generating and collecting. Having an excellent backup strategy Computer Data Backup is the only way to battle the unexpected loss of data. There is more than one way to back up your computers, and using multiple forms of backup will minimize the risk of losing your valuable files. This is where, the PC Backup solution from DataAlign stands out of the rest and gives a one stop solution for Business Server Data Backup up your computer's data on the secure cloud servers. Our innovative platform has been designed while keeping you in mind. To provide optimal user experience we focus on simplicity and this in turn ensures that you will be able to backup and access large data quickly and smoothly.
May 25, 2018 | Quantum Computers & Internet
See all Cavalry Storage Cavalry 500GB 3.5 7200RPM USB 2.0 Questions
Cavalry Storage Cavalry 500GB 3.5 7200RPM USB 2.0 External with One Touch Back-Up 500 GB Hard Drive Logo
Top Cavalry Storage Computers & Internet Experts
Arora Singh
Arora Singh
gary433
Glenn Smart
Glenn Smart
Are you a Cavalry Storage Computer and Internet Expert? Answer questions, earn points and help others
