Question about Plantronics S11 Headset
I can hear patients and a dial tone if i pick up the phone but noone can hear me
    Prodigy:
    An expert who has answered 500 questions.
  • 537 Answers
Please pay special attention to where the handset cord is plugged in. Then, check where the cord is that comes from the S11, it should be plugged into where the handset cord was. Once that is done check the compatibility slide switch. Adjust the volume on the amplifier. The handset must remain off the of the cradle when making a call. If the cords are not in the correct place it will not work correctly.
Good luck from Headsets Direct!
Posted on Nov 10, 2011
I CAN BARELY HEAR MY DIALING TONE BECAUSE OF THE LOAD BUZZING THAT IS COMING FROM THE HANDSET ON MY CDW4901SE
contact phone line provider ask them to test your line for a corroded connection or water ingression.
Jun 15, 2016 | Lands Phones
Why has the phone reversed, dial tone works only when phone is hung up why?
If I understand you correctly, when you leave the handset in the cradle and press a line, you can hear the dial tone. But, if you lift the handset and then select a line you don't hear anything through the headset. If this is correct, I suspect the handset is damaged, the cord is damaged, or if you're lucky, the clips may not be plugged all the way in on both sides. If you have another phone that is the same, you can switch handsets to test this theory.
Oct 19, 2014 | NEC 22b Hf Aspirephone-bk Stock No....
How do i forward a call to a cell phone?
I believe your landline carrier just needs to have the capability of call forwarding (ie we utilize Verizon for our business). We also use the call forward feature by: picking up line, (hear dial tone) dial *72 [ then phone number you want calls to forward to, even a cell]. To discontinue: pick up line (hear dial tone) dial *73
Mar 02, 2010 | NEC Dterm DTP 16D-1 Corded Phone
I pick the phone up, no dial tone. Display says
We called the phone company.....There was a problem up on the telephone pole. They fixed it, no charge.
Jan 21, 2010 | Vtech Cordless 6041 Phone
Status 50 on a fax estudio 45
the number is busy. Try pressing the monitor button and listening for a dial tone. No dial tone means your phone line is not working. If you have dial tone, dial the number you wish to fax and listen to see if it picks up. If you get a busy signal, or hear someone answer, that is why it's not working. If you hear the fax tones, press start and send your document. This is a way to fax that allows you to hear the whole process.
Aug 10, 2009 | Toshiba E-STUDIO 450 Copier
No tones, just a click when dialing
Try setting it on pulse, then hear it click when you push the number, if it works switch it back and try agian
Mar 05, 2009 | Panasonic Lands Phones
Dial tone is active as I'm dialing, callers cannot hear me speak
Your phone is broken, the only solution is to replace it. Call Uniden Customer Service and they should be able to help you. 1-800-297-1023. ( I'm serious, there is no way you can fix this problem with out opening the base unit up and replacing a bad transistor)
Feb 24, 2009 | Uniden DECT 6.0 Cordless Telephone...
CHANGE RECORDED MESSAGE
To change the greeting you need to either pick up the phone or press speaker phone then dial *38 then 1 then you will hear a beep/call tone. When you hear that tone record your message/greeting. Once you are finished press the auto dial/store button. If your are satisfied with that message hang up or press speaker phone again to end the call. If you would like to clear the message, then right after you hit auto dial/store you will hear a beep/call tone press 0 to clear or 1 to rerecord.
Dec 08, 2008 | Panasonic KX-T7630 Corded Phone
Plantronics S11 Headset Logo
96 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
skiffy99
skiffy99
Level 1 Expert
shaun taylor
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
