When making a copy on our Canon copier (super G3; image class MF4150) we are getting a vertical black line down the entire length of the paper. Is there something we can do to fix it? SG
  • 1,110 Answers
You can fix this yourself by cleaning the scanner glass. When you insert a document to make a copy it is pulled in and travels over a thin strip of glass. When something gets stuck on this glass it is read or scanned as a solid line. What you need to do is make a copy. Then put that copy in the feeder the same way you put the original document in. Now the line on the copy will "line up" with the area of the glass that has something stuck to it. Use this as a guide to pop open the feeder cover, locate the glass and clean it with a cloth dampened with a bit of glass cleaner. Once you have it cleaned just run a copy again and the line should be gone. Sometimes a small flashlight helps to locate the glass.
Good Luck and Thank You for using Fixya.
Posted on Sep 02, 2010
Testimonial: "Your solution was exactly right - thanks for your help."
Thin vertical line on copies
Tara, if the ink levels are ok, try clean and allignment functions from the tool menu. Use CLEAN UNUSED PAPER.
Mar 24, 2014 | Canon PC-940 Black and White Copier
When making copies, there's a line running through every copy-- along the entire length of the paper
If line appear on drum scratched change drum & cleaning blade.otherwise change only cleaning blade
Mar 24, 2013 | Canon PC-940 Black and White Copier
My computer when down Im trying to down load my printer to my other cpomputer but i dont have the disk. I went to the wizard but it wont down load my printer I have a cannon image class mf4150.can you tell...
go to the website www.canon.co.in click support & download Select "multy functional printers" in product category Select "Image class" in product series Choose "image class 4122/4150" in product model Choose "driver & software" in type of document. Then you will get a list of drivers, select the driver that is meant for your os.
May 14, 2011 | Canon imageCLASS MF4150 All-In-One Laser...
Single narrow black vertical line about 1 3/4 inches from right side of copy. Line runs the entire length of the copy. Happens only during copying color or black and white.
The line issue is caused by something on the image sensor. To get to it and clean it just pull the front up where you put the paper into it to scan. Inside you will find a glass strip, this is the image sensor. Use a paper towel dampened with window cleaner and gently scrubbing the glass strip, After cleaning the strip let it dry for a minute or teo before you close the cover and try a scan. It should be clear and should copy great again.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
Jun 18, 2010 | HP OfficeJet V40 All-In-One InkJet Printer
Canon Image Class D320 does not copy entire page. New toner has been installed.
Has anyone changed the paper size in the paper tray to another size by accident? Have you tried the manual feed tray? If that copies the whole image then the problem is with the paper size input of the paper tray.
Apr 15, 2009 | Canon imageCLASS D320 Digital Copier
Poor copy quality - lines on paper
Hello sir; The problem is caused by drum cleaning blade, you need to replace drum cartridge or drum blade if you can.
Jan 23, 2009 | Canon NP 6551 Black and White Copier
Black lines
There is a small strip of glass that the document feeder uses. Once you clean off the section, the lines will go away. Even a tiny speck will cause that to happen.
Aug 14, 2008 | Canon imageCLASS MF4150 All-In-One Laser...
Canon np7130 copier
Most likely when you make a copy you don't see the light scanning the paper, you can try this with the lid open to make sure. the Sacnning lamp is blown, need to replace
Jul 14, 2008 | Canon NP 7130 Black and White Copier
CANON SUPER G3 IMAGE CALL MF4150
your printer needs to be reset.
Mar 15, 2008 | Computers & Internet
165 people viewed this question
k24674
