Question about General Electric DHDSR46EGWW Dryer
Drier shuts down after several minutes, the fan and vent are free of lint. It will start right back up and run several minutes.
  • General Elec... Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 12, 2010
Dryer LG 1100 shuts off after a few minutes. If you set it for 54 minutes, you check if after 5 minutes it reads 14 minthen in 5 minutes it starts cooling down. The clothes are still wet.
Clean your lint filter, and clean the entire line vent from the dryer to the outside export port, also look inside the dryer vent hook up for obstructions and remove any lint. Keeping these parts lint free will save you energy and also drying time and maintenance repairs. My dryer is 18 years old.
Sep 29, 2015 | LG Dryers
Dryer turns on then stops in 5 seconds and flashes F40 code. shuts down
Check lint filter, check vent outlet at dryer, and continue on through vent checking for lint to the exit area of the vent. Keeping the vent lint free saves energy and reduces drying time.
Sep 06, 2015 | Kenmore Elite Oasis ST 7806 Dryer
Keeps shutting down and takes several trys to start again only to shut down later
If the computer is overheating it will shut down to save the hardware from heat damage, the temp is pre set. It may get hot, due to air flow in a minute or and hour. What does the "screen comes up says problem " say? Check the fan and vents for dust and clean, improve air flow around bottom vents and side vents. Perhaps a Laptop Cooler? When the computer shuts down unepectedly, the computer see it as a crash and will load in that option screen. Run a 'Check Disk" on the OS drive buy opening computer in start menu, right click the drive with the OS (C), open properties, Tools, Check now, choose all options, follow instructions, reboot.
Nov 18, 2012 | Computers & Internet
Dryer was running then stopped
Some driers turn off when overheated. Wait for your drier to cool down and try again. You may need to clear the vent tube which accumulates lint not caught by the drier's lint catch.
An old dryer may be drawing too much power and may have tripped the breaker. Go to your breaker box and look for a switch that is not facing the same way as the others. Push it back in position.
A digitally controlled dryer may freeze like a computer. Try unplugging the machine for 1 minute, plug back in and try again.
Apr 16, 2012 | Dryers
Dryer takes hours to dry a load. I must run it through several cycles. Not much air coming out of outside vent so repairman suggested it be cleaned out. My husband completely removed it and found no...
My only thought is to look at the back of the drier. Check the hose coming out the back to the out side vent, and then run the drier with out the hose for a few moments. See if you have air moving then, if you have no air moving with out the hose attached. Your driers fan blades are ether clogged with lint or they have broken off some how.
Aug 22, 2010 | Electrolux EIGD55H Dryer
GE Dryer shuts off w/ blinking and beeping
I just fixed that problem with mine. I tried many, many things. Final solution was vacumming out the holes in the rear of the drier. (Prior to that, I removed the lint filter and holder, checked all connections and vacummed out that area. I unplugged the vent hose to confirm there was no cluggs. I found resetting the breaker would work for about a half hour.) Just vacum out the rear of the dry. Not only will the beeping stop, but as an added bonus, you cloths will dry much faster!!!
Sep 01, 2009 | GE Spacemaker Washer and Dryer Electric...
I have an Estate / whirlpool drier model # TEDS680EQ0 that when we turn it on it will run for maybe 10 minutes and then stop. After about 10 minutes it will allow you to restart it after it cools down. I...
If wet link dries onto sensors over a period of time then the lint will trip sensors prematurely. Clean surface of all sensors. Check sensors in heater housing and in fan housing.
Apr 19, 2017 | Whirlpool Dryers
Electric dryer shutting off
most likely cause is the air duct is blocked with lint, some always gets past the screen and builts up in the exhaoust line. not enough air flow, the air gets hotter than normal and trips the over temperature cutout.
for most dryers
clear the fan, and exhaust ducting all the way to the wall, and the outside vent hood, of lint
Sep 22, 2008 | Whirlpool LER4634J Electric Dryer
Whirlpool Duet Dryer getting very hot, tripping breaker
what size is your breaker how many amps it should say on breaker are you cleaning the lint screen with it on top if the drier is getting too hot there is a device in it that's called a thermal limiter that would blow before the breaker would trip what kind or you in a house or apt. now on high heat can you hold your hand on the side of the drier.or cant touch it look at the vent under your house and tell me 1is it hanging down under the house then coming up to the hood 2whats its diameter3whats it made of we will go from there ok.there are three thermostats in that drier the first one runs at about 150 160 max second is a safety in case the first one fails it cycles at about 250 third is a safety if the drier exceeds 300 it will shut the heater down and wont rest it has to be replaced
Jan 10, 2008 | Dryers
This dryer STINKS
most of the time this problem is caused by a vent restiction or mashed vent behind the drier what i tell my customers is to run 4' pvc plastic pipe from the outside hood under the house then use a90 degree elbow to come up through the floor and a small piece of metal flex vent and clamp for the final connection you'll never have a vent problem again i know how you feel and im not saying your not right just giving tech advice so you don't have same promb with new drier im a real svc tech and im concerned with you also call lgs cust relations people not cust service cust relations be nice say you didn't think lg was like this and you don't know if you just got a bad drier or what tell the whole story fire and all don't mention pile up of lint they want you happy with there products and most of the time will help some times even give you a new drier you got nothing to lose by trying all appliance mfg are afraid of the fire word worth a try do it right might get a new drier but do your vent before inst any time it takes more than an hour to dry clothes ita a washer promblem clothes too wet or a vent promblem sorry for you promblem just trying to help
Nov 29, 2007 | LG DLE2532W Electric Dryer
General Electric DHDSR46EGWW Dryer Logo
71 people viewed this question
Top General Electric Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Donni Steen
Are you a General Electric Dryer Expert? Answer questions, earn points and help others
