Question about Danby DDW1806BSL Stainless Steel Built-in Dishwasher
Error 4 displayed on a danby ddw1806bsl dishwasher
What does the E4 stand for? The dishwasher will not cycle beyond the draining process.
  • vanessa1202 Nov 09, 2008
    Same problem, can seem to see any difference in product that would cause this. It fills up, drains and then i get E4. Literally used this 4 times prior. I used it correctly each time. :( Someone Help! The Danby manual doesn't say what this is or why it occurs!
  • 3 Answers
E4 is overfilled condition.
There is a tank with an overflow sensor on the right side of the dishwasher. The tank needs to be drained of water to reset the sensor. If necessary remove the insulation on the lower front corner of the machine and drain into a cup or container by removing the black rubber plug at the bottom of the plastic tank.
Consult the manual for detailed procedure.
The error can occur from excessive foaming.
Posted on Dec 09, 2010
Water not draning
If kitchen side drains are clear then there might be some blockage in the pump system. Check the drain pump is working during drain cycle. If you can hear the pump but the water does not go away then you need to check filters at base of dishwasher. Beyond that you will have to open the pump assembly to look for debris.
see these instructions which might be helpful.
Apr 04, 2014 | Hotpoint 24 in. FDW60 Free-standing...
Logik dishwasher E4 error message
I am having difficulty with my logik slimline dishwasher. E4 message about 30 minutes into cycle. Where the salt goes is always full of water. Please can someone help me
Nov 17, 2012 | Dishwashers
E4 flashing and water not draining away
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
Mar 12, 2011 | Smeg 24 in. DWF614SS Stainless Steel...
Our dishwasher does not progress beyond the wach cycle to the rinse cycle. It will run for hours and still has soap in it.
I'm positive of this, but your dishwasher may qualify for a somewhat recent recall. Call bosch to see. If you can get it to drain manually and put into rinse and hold manually, but it won't progress on it's own, then it's the control board. Hope this helps.
Nov 28, 2009 | Bosch 24 in. SHE43C05UC Stainless Steel...
Kenwood dishwasher Comes up E3
I do not know the Kenwood dishwasher, hence I do not know what the E3 error is, but many dishwashers require a sustained pressure of at least 30 psi.
Can you please post the model number of your Kenwood dishwasher?
Apr 11, 2009 | Bosch 18 in. SRS45E02 / SRS45E08 Exxcel...
Kenwood dishwasher KDW12SL3A
Sounds as though the drain is blocked partially. E4 is the overfill code. Try cleaning out the drain.
Aug 07, 2008 | Dishwashers
Delonghi dishwasher won't drain.
I have the same machine with the same error message but my machine has drained it self but will not continue the cycle?
Mar 09, 2008 | Dishwashers
Kenwood dishwasher kdw8st2a
I had E4. Initially couldn't get it to clear.
In desperation, switched it off, turned it on it side and drained it onto the floor.
The E4 disappeared and the dishwasher is working normally.
Jan 22, 2008 | Smeg 24 in. DWF614SS Stainless Steel...
The E4 code means - Overfilled. To much inlet water. Remove water manually from the tank pan and try operating a new cleaning cycle. Good luck !
May 31, 2007 | Baumatic 23 in. BDW14 Built-in Dishwasher
Dishwashers Logo
667 people viewed this question
Top Danby Dishwashers Experts
Kevin Getz
Kevin Getz
Are you a Danby Dishwasher Expert? Answer questions, earn points and help others
