Question about Nakamichi DVD-10S
Can't access the region code setting menu on my Nakamichi DVD10. When I press dimmer rev chap power on, I get "No Disc" message. Never the - - - - that I need to enter the code... Any ideas?
  • 10,421 Answers
UNLOCK CODE
Try this
1. Power on with no disk
2. Wait for the NO DISC message
3. Enter: 9, 7, 3 and 5
4. The following menu will allow you to alter the region status
Dec 12, 2007 | Televison & Video
Tip
Regional code change for MDP-1770 Portable DVD Player
1 Before powering on, open the lids, remove any media and leave it open so you can actually see the compartment where you place a disc.(this is how you get access to the preferences menu)
2 switch on unit from the side of the drive
Now on the remote control
3 Press set-up
4 Select preferences menu
5 Press play
6 Input 251131
7 Press "Left" then "Down" button
Should show region code menu
8 Select region free by hitting the 10/0 button, this will change the region to region free (ie 0)
9 Press set-up to confirm and exit.
on May 29, 2009 | Mintek MDP-1770 Portable DVD Player
I would like to change regions on my portable Durabrand DVD player model PDV-722
Alright, just follow these steps and let me know if you have any problems or questions
  1. Power and switch on the Durabrand DVD player.
  2. Open the DVD disc tray tray or lid.
  3. Press Stop.
  4. Press 3 - 5 - 9 - 7 (3597 in sequence). Can be done on remote control.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control
  6. Press OK.
  7. Close the disc tray and press Standby on the DVD player front
Dec 19, 2008 | Televison & Video
Wrong region.on screenhelp please
try to make it region free by using the steps below
1 Press power on
2 Press set-up
3 Select preferences menu
4 Press play
5 Input 251131
6 Press "Left" then "Down" button
7 Select region
8 Press set-up to confirm and exit.
or
3 Press set-up
5 Press play
6 Input 251131
or
3 Press set-up
5 Press play
6 Input 251131
Nov 27, 2008 | Mintek MDP-1770 Portable DVD Player
DVDV809-04
You need to convert your machine to an all-region player. The following hack works for Diamond Vision models 803 and 807 - there's a good chance it will work for the 809 provided they've used the same firmware for this model.
The region-free hack works as follows:
1.) Turn on the power and wait until the 'NO DISC' message appears, then press OPEN/CLOSE on the unit itself to open the door of the DVD player
2.) On the remote control, press SETUP. A menu will appear onscreen.
3.) Enter the following number sequence via remote: 1 3 8 9
4.) A different menu will appear. Your cursor should now be sitting in a box with the current region displayed. Use the UP and DOWN arrow keys on the remote control to display a specific region's numerical code, or select '0' (this is the number zero - not the letter o ... this is the region-free setting).
5.) Press ENTER and then SETUP to exit.
6.) Your DVD player will now play DVDs from all other regions. The code only has to be entered once. Powering down will not cause the Diamond Vision to lose its region-free setting. An added plus: it automatically senses PAL/NTSC signals but it will output to an NTSC tv set.
Sep 02, 2008 | Yahoo Diamond Vision DVDC803-04 DVD Player
Need code for durabrand portable dvd player
  3. Press Stop.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control.
  6. Press OK.
The above unlock DVD player region code trick should works on models including Durabrand DVD-1000, Durabrand DVD-1005, Durabrand DVM1418c, Durabrand LCDTV *** DVD player model PVS 21175S1 and others DVD players from Durabrand.
If the above unlock region code hack doesn’t work, or if you’re using Durabrand Car DVD Player model PVS1966, Durabrand PVS1960, Durabrand PVS1680, Durabrand PVS1970, Durabrand PVS223, Durabrand STS75E, Durabrand Dual-7B or Durabrand Dual-7BL, try the following unlock code instead.
  1. Power on the DVD player.
  2. Open the DVD disc tray or lid.
  3. Press 8 - 1 - 3 - 2 - 8 (81328 in sequence) on remote control.
  4. In DVD region code menu, press Enter until come to region 9 (or 0)
  5. Press Play.
  6. Close the DVD tray or lid.
For Durabrand Dual-900, try the following DVD multi-region or region free unblock sequence instead.
  1. Press Open to open disc tray.
  2. Press Clear.
  3. Press 1 - 3 - 6 - 9 - 0 (13690 in sequence).
  4. Press Standby button. After pressing, the DVD disc tray will close and DVD player will switch off).
  5. Press Standby button again to power up the DVD player.
Note: To set back the DVD player to region 1 if you’re using above unlock hack, simply press 13691 in sequence. The 0 or 1, the last digit in the key sequence is actually the digit to determine which region code you’re going to set on the DVD player. You can set to other region code by changing the last digit to 2, 3, 9 or other valid region code number.
For Durabrand DP305, try the following DVD region code unlock hack instead.
  1. Turn on the DVD player.
  2. Press Open/Close button to open the disc tray.
  3. Press Setup.
  4. Press 8 - 8 - 8 - 8 (8888 continuously).
  5. Press Next.
  6. Go to “Version and select a region code. Select 0 for all region or 9 for region free.
  7. Press Play.
The below trick should be able to unlock the region restriction on Durabrand DUR1700 DVD player.
  2. Press Setup.
  3. Go to “Preferences”.
  4. Press Play.
  5. Enter 2 - 5 - 1 - 5 - 3 - 5 (251535 in continuous sequence of keys).
  6. Press Left, Down.
  7. The current region code will be displayed.
  8. Press 0 for region free.
Note that if you select “Region 0′ which allows DVD players to plays all DVD-Video discs from Regions 1-6, some DVDs which are incorporated with “Regional Coding Enhancement” or RCE protection system will refuse to play in such machine.
Jun 05, 2008 | Jensen JR400 Remote Control
7" LG Portable DVD Player DP271
Hi
I have tried to unlock the DVD DP271 player using following methods, But it is not unlocking. If any body knows any other code. Please help me to un lock my DVD DP271 player.
Thanks
Sekahr
1. Power up and press setup
2 Scroll down to LOCK
3 Press '0' (zero) seven times
4. A message may now appear with saying that the player is region free.
5. Power down then power up.
or
1. Remove any discs and power up the DVD
2. Press PAUSE
3. Enter 314159
4. The hidden region code menu may now appear.
5. Set code you want- 0 for multiregion, 1 for region 1 and so on
6. Press PAUSE
7. Power down then power up
Nov 02, 2007 | Insignia NS-PDVD8 Portable DVD Player
E-disc message
Hello ... my name is Gabriel Acu?a and I live in Mexico and I believe to be an expert on Nakamichi.
The answer to your question is simple:
Cuende your e-soundspace said disc means that the DVD is not compatible with the region sounspace.
Nakamichi regularly are region 1.
introduscas when a girl Nakamichi DVD to your region in the back.
I hope this resolved your question ...
My email is tocher_gaa@hotmail.
Jun 18, 2007 | Nakamichi SoundSpace 11 System
Nakamichi DVD-10S Logo
102 people viewed this question
Top Nakamichi Televison & Video Experts
Henry  Thomas
Henry Thomas
Josh Whitehead
Josh Whitehead
Jim Goldsmith
Jim Goldsmith
Are you a Nakamichi Televison and Video Expert? Answer questions, earn points and help others
