Question about Konica Minolta magicolor 2500W Laser Printer
Konica minolta 2500w doesn't recognize that toner cartridge is installed
Printer doesn't recognize that toner cartridge is installed. intermittent fault
  • 1 more comment
  • Anonymous Jun 30, 2008
    i have the same problem. Did you find a solution?
    Thanks
  • sjoeckel Jul 24, 2008
    Same Issue, printer says cyan cartridge is not installed, even with a brand new cartridge.
  • pbolek Aug 12, 2008
    changed Black toner (K) and error says I'm not using Konica toner even though I am
    Problem Solver:
  • 6 Answers
Sounds liKe the toner dust is bvlocking the sensors. see the following
http://www.zinetic.co.uk/toner_refill/magicolor-sensor-errors.aspx
Posted on Feb 26, 2010
Give me £9.99 and I'll tell you
Posted on May 11, 2008
Konica minolta bizhub c35 black toner being recognized as empty
sir/mam replace the cart then might have gotten a bad one from the store
Mar 11, 2014 | Konica Minolta bizhub C35 Black Toner...
Konica minolta 4690mf doesn't recognize yellow toner cartridge
ARE YOU USING GENERIC TONERS? IF YOU ARE THAN YOUR GONNA HAVE TO USE ALL GENERIC NO MIXED TONERS.
Mar 26, 2013 | Konica Minolta Magicolor 4690MF...
Konica Minolta 2490mf . Have just put in compatible toner catrdges and printer is telling me YMCK toner incorrect can you help many thanks Steve
Perhaps clean the connections between the toner-chips and the printer.
As the are lokated below the toner cartridges in your printer the tend to get dirty
and cleaning them can make the difference...
If this does not help, try the old cartridges and see what message you get.
If that is a different one your cartridges doesn't match your printer and you should get replace ones.
Greetz, Robert.
Sep 06, 2011 | Konica Minolta magicolor 2490MF Laser...
Knoica minolta 250W printer cartridge jamed lever and mechanism cam off I cannot move it now thw whole machine has jammed what can I do please?
OK... YOU HAVE TWO POSSIBILITIES... EITHER THE LEVER ON THE TOP COVER BROKE OR THE ONE ON THE PRINTER CARTRIDGE...
IF ITS THE ONE ON THE TOP COVER THEN YOU NEED TO REMOVE THE LEVER HANDLE COMPLETELY AND GET A PLYERS AND USE IT TO TURN THE METAL THE LEVER IS ATTACHED TO OR FIGURE OUT WHERE THE THE LEVER GETS THE MACHINE TO LATCH AND USE A FLAT HEAD SCREW DRIVER AND SLIP THE LATCH... THEN CONTACT KONICA MINOLTA AND PURCHASE A NEW LEVER...
IF ITS THE TONER LEVER THATS BROKEN... YOU ARE GOING TO HAVE TO GET A PLYERS... TAKE A FIRM GRIP ON THE TONER AND REMOVE THE TONER IN THE SAME WAY THAT YOU WOULD IF THE LATCH WAS THERE... IF ITS BEEN PUT IN ODD THEN IT MIGHT BE STUCK... YOU MIGHT NEED TO USE A FLATHEAD SCREWDRIVER ON THE ENDS TO HELP THE PROCESS ALONG...
USER MANUAL
Feb 12, 2011 | Konica Minolta magicolor 2500W Laser...
My Minolta Magicolor 2500W printer indicates that it is out of black toner. I have never changed the toner cartridge before and cannot find the instruction manual. (bought it almost 3 years ago...) Do I...
Firstly buy a black toner refill and a "CHIP". The chip is a small printed circuit carrying a chip, mounted on the top right hand corner of the toner cartridge held in by a small cross point screw. Remove the cartridge and looking at the right end you will see a round (About 3/4 inch dia) plastic bung. Lift this bung out and carefully refill the cartridge (The refill supplier will probably clarify this I am saying). Replace the bung, clean up all the messy dust and remove the old chip replacing it with the new one. Make sure you dont lose the little screw and insert it fully without over turning it. Thereafter all should be OK.
Dec 05, 2009 | Konica Minolta magicolor 2500W Laser...
Replcing the black toner on the Minolta Magic color 2300w
You can press the 'rotate toner' button which is the blue one next to the toner indicators on the top panel or you can open it up and with two hands on either side of the entire cartridge, turn it manually. You will hear clicking sounds as you turn it. I've done this safely replacing all four toners twice over now.
Mar 25, 2009 | Konica Minolta magicolor 2500W Laser...
Konica magicolour 2500W doesn't recognize cartridges fitted
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 06, 2009 | Konica Minolta magicolor 2500W Laser...
Printer won't recognize ink cartridge change
changed black K cartridge with new one but still shows black toner empty! Could toner cartridge be faulty?
Dec 05, 2008 | Konica Minolta magicolor 5430 DL Laser...
How to change cartridge in magicolor 2500W?
If one of the cartridges needs to be changed, the printer will recognize this and it will automatically rotate that cartridge to the front of the printer.
Open the panel and follow the instructions that are shown on a sticker on the inside of the access panel. Removing the cartridges is not difficult. They do have a slight groove near the top that acts as a handle. You may have to rotate the cartridge up as you lift it in order to get it to come out. DO NOT FORCE IT. Once again, please consult the sticker on the inside of the access panel for details on cartridge replacement.
If you need to replace more than one cartridge, press the rotate button to rotate the cartridges to the one that needs replacing and repeat the process.
DO NOT FORGET TO TAKE THE SEALING STRIP OUT OF THE NEW TONER CARTRIDGE BEFORE PUTTING IT IN AS THIS TAB CAN AND MOST LIKELY WILL DAMAGE THE PRINTER. (I've seen it happen.)
After you have replaced the toner cartridges properly, the printer should rotate the drum a few times to prime the cartridges. This is normal. You should see a readout on the LCD screen of the toner levels. (You may have to press a few buttons to see the status on them.)
If you need toner cartridges, head to your nearest office supply store such as Staples or Office Depot for replacements. (Staples will price match other stores if you give them proof of the other store's price.) When I last worked with this machine, the cartridges were still kind of expensive...but worth it for the quality that this machine gives you.
Good luck. :)
Cyryl
Nov 09, 2007 | Konica Minolta magicolor 2500W Laser...
Open Questions:
Konica Minolta magicolor  2500W Laser Printer Logo
586 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
