Franco belge optima pack 59660 merville prob. with domestic hot water pressure - pressure valve keeps opening...
  • 143 Answers
SOURCE: The pressure release valve keeps
If this is a water heater, replace the valve. You can get them at Home Depot. If it is an air conditioner, don't worry about it. The water is supposed to run out.
Posted on Jul 27, 2008
SOURCE: Combi Boiler - Hot water pressure low
I have a 1 bed flat, above an old pub. I have a combi boiler but my water pressure is ridiculous. The shower water runns down the shower head. I'v been told that the cold water feed to the building is split to two boilers, one to the pub and one to me. Im thinking of installing a shower pump in between the boiler and the shower. will this work as my friend says he has done this and it sorted his problem out. I'v looked it up on the net and everything says this does not work. Help please.....
Posted on Dec 24, 2009
jeff_drakesr
  • 155 Answers
SOURCE: No cold water
Anti Scald Valves have an adjustment under the handle (remove handle) to allow so much hot water in no matter how far handle is turned. Its possible that the adjustment is set to allow only hot water in, this of course defeats the purpose of anti-scalding. Check to see if you can adjust this back. Good Luck have a Great Day. Please give a 4 THUMBS UP if this free answer was of any help.
Posted on Apr 01, 2010
heatman101
  • 43501 Answers
SOURCE: pump cut out. primed pump and restarted but keeps
Here is a tip that will help you..
Jet Well Pump Well Jet Water Pump
http://www.fixya.com/support/r3695577-jet_pump_jet_water_pump
Posted on May 26, 2010
heatman101
  • 43501 Answers
heatman101
50 gal. kenmore elite hot water heater model#153.332640 installed 05/01/2011 in February 0f 2017 it started blowing water out of relief valve. temp at faucet 145degrees . rplcd gas contr valve/therm
If the water coming out is really hot, you probably have a faulty thermostat, which allows water to overheat. If water is warm or cold, you probably have defective temp/pressure relief valve.
Jan 12, 2018 | Water Water Heaters
Tip
Valve Pressure Reducing or Pressure Reducing Valve
dfef4ee.jpgThe pressure reducing valve on a boiler is the way that the water pressure in the boiler is controlled. The standard pressure for many hot water boilers is considered to be 12 PSI. To keep the boiler pressure at or near the 12 PSI mark a small valve is used for pressure reducing. Most domestic water systems run between 20 and 60 PSI, so the pressure must be reduced for the boiler.
This pressure reducing valve is installed in the pipe that goes from the domestic cold water to somewhere in the piping on the heating system, usually at or near the expansion tank. The valve is mostly maintenance free but will create some problems at times. Some of the things that can go wrong are:
  1. The valve seat can get dirt stuck under it causing water to leak by and increase the pressure in the boiler, causing the relief valve to release water periodically.
  2. The valve can become plugged with dirt causing the boiler to not have enough water pressure, which will cause circulation problems with the boiler pumps.
  3. The valve can leak causing a mess around the boiler area.
Replacement of the pressure reducing valve is not difficult if the installer strategically placed manual valves so that the reducing valve can be isolated from the rest of the system for replacement.
If the water pressure reducing valve fails in any way, it is usually best to just replace the whole valve rather than trying to repair or fix it. I have tried a number of times with only temporary results. These valves are not a high dollar item and the time it takes to fix them is not worth it.
http://www.fixya.com/support/r3696173-expansion_water_tank_boiler_expansion
http://www.fixya.com/support/r3705970-heating_circulating_water_pump_problems
on Dec 23, 2009 | Heating & Cooling
Setting our machine on warm , but the water s hot , both hot & cold taps are fully turned on .
Check your hot/cold inlet valve and solenoid. It sounds like your cold water side of the valve is stuck shut. The valve is found by following the inlet hose right to it. Also, do you have a domestic well as water supply? Sometimes fine sand from a domestic well will plug the valve screen. It is also possible that other mineral would plug the screen. These things would happen gradually, though, not all at once.
Feb 02, 2017 | Simpson Washing Machines
My boler will heat the hot water & heating but not the hot water on its own
This is possibly because you have a zone valve that has stopped working, motor maybe burnt out or could be that it is permanently open . Some valves have a manual control that clicks into position, these valves are usually placed adjacent to your hot water cylinder
Hope this helps
Jun 22, 2015 | Heating & Cooling
Domestic hot water works but no hot water to baseboard heat
If its a one story house, the system pressure should be somewhere around 10 to 12 psi. There should be a PRV (pressure reducing valve) on the domestic water line supplying make up water to the boiler. The shut off valve in that line should be in the open position unless the prv leaks through and slowly overpressurizes your system to the point of tripping the pop-off valve. If so, then the manual shut off should be kept closed then opened only to boost the pressure up a bit in the system. It kinda sounds like you are suffering from low system pressure.
If there is a vent or vents in the system, try bleeding them into a coffee cup and you may find it sputtering air/water mixture. Bleed them until you have full water flow and make sure you keep approximately 10 psi in the system.
Oct 07, 2014 | Cadet Manufacturing Heating & Cooling
Wickes 102 combi boiler constantly loosing water pressure
It sounds like your thermostat could be the problem. Have you noticed the boiler cutting off at all, or does it run continuously until it goes out on low water?
You stated, "when boiler is on", so I am wondering how you get the boiler on. If your boiler is controlled by a thermostat, you need to check it for a cold draft possibly from behind the thermostat in the wall where the wires come through. The thermostat should never be on an outside wall. The thermostat could be defective.
An aquastat can also control your boiler. If you have an aquastat, check the setting, typically 175 - 180 degrees. You should also have a "high limit" which should be set at 210 - 220. Some people run that high side limit higher; not a good idea - defeats the purpose. If the aquastat is set too high, the boiler will operate too hot and the problem you have will occur.
"pressure rises and pressure relief valve opens" This could mean that your pressure switch is prematurely venting. Check boiler temperature to see exactly at what temperature the T&P valve purges. If it blows off below the high side setting, either adjust or replace. The T&P valves are usually not adjustable. That blow off temperature is stamped on the head of the valve. So, if it discharges too soon, replace it.
Have you actually seen evidence thgat the T&P valve is opening? You may have a bad bladder in your expansion tank and your system may have air in it. Your boiler should have 12 psi when cold and 20 - 22 psi when operating. Check your boiler pressure guage.
this eventually drops below the minimum operating pressure" Technically, there is set point for a NO MINIMUM OPERATING PRESSURE. That is a function of the amount of water in the boiler. If the T&P is blowing off, it will vent water from the boiler and the boiler pressure will go down. There is a minimum operating TEMPERATURE.
Your boiler could be low on water. You will have to manually fill the boiler. Be careful of thermal shock to the boiler. Feel the piping, and fill only when the circulator is running. Make sure the water is not going directly into the boiler. The supply water should go into the circulating supply side which feeds the radiators, radiant floor, or base board circuits.
All this will adversely affect your hot water. The heat exchanger for the potable hot water may have scale build up in it. Using the hot water keeps the boiler running, and a scaled heat exchanger will give you cooler hot water and the boiler keeps running. If this is a problem, you will need to replace the heat exchanger. A better idea is to not use the boiler for your domestic hot water. Why run the boiler in the summer?
Feb 02, 2013 | Water Heaters
Vokera combi boiler
there is a zoneing valve thats suppose to be in the line to keep this from happening, might even have a check valve either way which ever one you have is bad and should be changed with a new one
Feb 20, 2009 | Water Heaters
Tp valve opening and dumping water
Certain water heaters can only handle so much pressure from the main line. There is a pressure controller between your water meter and you house, it's called a pressure regulator. You need to call a plumber to check and see if it needs to be adjusted or even replaced.
Dec 22, 2008 | Bosch & Tankless LP Hot Water Heater
I have a ideal mini c24 cobi boiler and it isnt holding pressure the are no leaks inside the house it just seems to be releasing the water for the central heating from the blow off pipe outside so i keep...
So the boiler relief valve is leaking? What is the boiler pressure when the relief valve leaks? The relief valve will have a pressure rating on it. If the relief valve leaks when the pressure in the boiler is lower than the relief valve setting then its just a bad relief valve. If the relief valve is leaking when the boiler pressure gets above the relief valve pressure setting then the relief valve is doing its job and there is another problem. Several things can cause the boilers pressure to go higher than the relief valves setting. It could be a bad expansion tank or one that needs to be drained and re-charged. It could be a bad cold water fill valve that isn't shutting off and is over filling the system, rasing the pressure above the relief valve setting. If this boiler also does your domestic hot water, I have seen where the domestic hot waters heat exchanger has a hole in it and the domestic hot water is mixing with the boilers water and over pressuring the boiler.
Jan 13, 2018 | Heating & Cooling
Changed cold valve
What brand and model do you have, most domestic units have a combination hot/cold valve? You just need a meter too verify the valve is closing, if the valve solenoid is closing you may be having a water pressure issue, too much water pressure can cause leaks.
Jul 29, 2008 | Washing Machines
Heating & Cooling Logo
197 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
