Question about Taylor 7532 Ultra Thin Glass Digital Scale
The scale wanders and goes to err. You may weight one weight one minute and weight another one the next time you get on. It could be a difference of 2 or 3 pounds. It has a clear glass top.
    President:
  • 2,047 Answers
Weights are such that the way you position the load on it makes the reading differ by a couple of pounds.
Although the scale coming up with an error repeatedly can also be as a result of the battery. Try to get the battery replaced this should work out the error issue.
Digital scales usually just give you a general idea of what the weight of the load is.
Also you can perform a reset on the device this can be done by:
- Open the battery compartment on the bottom of the scale. Push the tab on the door and lift the cover.
- Remove the battery from the compartment. Close the battery compartment door.
- Sit the scale right side up on a hard surface floor.
- Step on the scale and stand still on it for five to ten seconds. Step off the scale.
- Turn the scale over and open the battery compartment. Re-insert the battery. Close the battery compartment cover.
- Place the scale right side up on the hard surface floor.
- Press one foot on the scale until the display shows zeroes or dashes. Remove your foot.
- Wait for the scale to shut off by itself. When you step back onto the scale, it will be reset.
Hope this solution has been helpful?
Posted on Sep 02, 2010
How to reset my weight watchers scale I changed the battery and it goes to err
If your getting ERR on the screen than indicates that either one of the two weight sensors has gone bad or the PCB has failed. Bad it failing weight sensors are a known issue with these. Unfortunately more expensive to repair than replace.
Sep 02, 2017 | Weight Watchers Health & Beauty
I keep getting Err after replacing battery
my scale keeps reading err when I step on it
Jun 01, 2014 | Homedics Digital Scale
My Salter bathroom scales (model 929) are showing an ERR message. They seem to think everything weighs more than it does as if u press gently on them the weight goes up really quickly until limit reached...
The best day chessboard type is the traditional type of weight, in contrast, electronic weight scale error degreehighestelectronic
tems, affected by environments, bumps can make reading deviation.The use of electronic weight meter can more precisely?
Electronic scales are generally placed in the hard flat floor use, not on the carpet or other soft object surface by using.Each weight to body weight in the same place, the same time, wear the same clothes.
Hello, I just see a online stores
http://www.tmart.com/Digital-Scales/ sell digital scales. Some advice, for reference purposes only and finally I wish you luck!
Jul 25, 2011 | Salter Health & Beauty
I have a Taylor body fat analyzer and scale model #5563 that keeps showing Err 2. It won't read any weight whatsoever... it just goes stratight to the Error message. Do you know what that means and how I...
From the Taylor Site http://www.taylorusa.com/faq-scales
Here are the basic ERR messages and their meanings:
  • Error 0: Initialization
  • Error 1: Instability (scale is on an uneven surface ex: carpet)
  • Error 2: Unit may have been jarred or unit was overloaded (customer went over the maximum weight capacity)
  • Error 3: Contact error (Feet were not wet for Body fat reading, feet aren’t big enough to reach sensors)
  • Error 4: Body fat is out of range
  • Error 5: Water is out of range
I got an ERR2 message and now the scale doesn’t work. What should I do? The following reset procedure is used when the scale shows an err2, err, 0.0, inaccurate weight, or some other unusual error.
  1. Remove the battery from the scale.
  2. Sit the scale on a hard surface floor.
  3. Step up onto the scale, stand still for about 5 seconds and step off the scale.
  4. Re-install your battery.
  5. Place the scale back on a hard surface floor.
  6. With one foot only, place just enough weight on the scale for the display shows zero’s or dashes. Once you see zeros or dashes remove your foot.
  7. Wait for the scale to turn off again.
  8. Step up onto the scale for a weight.
If the reset is successful, you should receive a weight right away. If you continue to receive one of the error messages above please call our Customer Service department or contact us via email. You can also try the reset procedure a 2nd time. Sometimes the reset procedure will work the second time.
Jan 15, 2010 | Health & Beauty
Fluctuating weight on Digital Scale from one minute to the next..
i believe that, like most electronic scales, the first time you get on the scale you must step off to allow it to zero itself. Then step back on to get your correct weight.
Jul 28, 2009 | Conair Thinner Scale by TH304 Glass Body...
Err 1 message on Taylor Lithium Elec Scale model 7346
This is a reply I received from Taylor customer support. I have followed this procedure enough times to wear out the original battery and still get the Err 1 message. You may have better luck.
Thank you for your e-mail. The reboot below may clear the error from
your scale. You may need to do this several times to completely reboot
the system. Please let us know if you have any questions or continue to
display the Error.
2. Set the scale on the floor without the battery in place.
3. Stand on the scale for 10 seconds (still without the battery)
4. Carefully replace the battery without turning the scale on.
5. Using only one foot, tap the scale or apply just enough pressure to
turn on the display. (It should show dashes or zero's) IMMEDIATELY
REMOVE YOUR FOOT.
6. Let the scale turn off
7. Step on the scale for a weight reading
Regards,
Linda DLT
Consumer Relations
Taylor Precision Products
& Salter Housewares
2220 Entrada del Sol, Suite A
Las Cruces, NM 88001
Toll free - 800-289-0944
866-843-3905
Direct - 575-526-0944 ext 3172
Feb 11, 2009 | Taylor & Digital Scale Lithium Scale
Resetting the scale
You do not reset the scale. It only saves the last recorded weight of the user. So, if you weighed yesterday, it will put your recorded weight in memory. The next time you select your user number and step on the scale, it will compute the difference from your previous record and save your current weight.
Jan 24, 2009 | Health & Beauty
Taylor 7532 Ultra Thin Glass Digital Scale Logo
184 people viewed this question
Top Taylor Health & Beauty Experts
Ankit Chandel
Ankit Chandel
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Taylor Health and Beauty Expert? Answer questions, earn points and help others
