Question about Frigidaire FDL45P1 Dehumidifier
It has stopped extracting moisture. It still runs but there is no heat coming out of the vent.
  • Frigidaire Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
There can be many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Posted on Sep 09, 2010
It runs, but why doesn't it extract water?
The compressor has to run to extract moisture. You may be hearing just the fan running.
Nov 23, 2015 | Dehumidifiers
The unit just stopped extracting any moisture from the air. The fan runs and the compressor sounds like it turns on. I use the bucket to capture the moisture so do not have the pump on for the hose.
If the unit isnt extracting moisture in the air you have one of two problems a leak in the refrigeration system or the compressor is locked up. In my experience its probably a leak in the refrigeration system because they make the dehumidifiers very cheap and the coils are paper thin. Delonghi has a lot of issues with there dehumidifiers and any other appliance they make. Check to see if the compressor is running if it is then you have no freon in the system. You can access the compressor by the back panel and you will know if it is running. If it is a refrigeration leak buy a new unit it will be a whole lot cheaper and less stressful,.
If this helps please rate me.
Jun 27, 2011 | DeLonghi DE500P Dehumidifier
Haier model hdn455 serial number 05021110 it runs but has never taken a drop of water out of the air, so it just keeps running
The problem, may very well be, that the humidity extraction level is set too high. Lower it to 35% and see what happens. Keep in mind, the lower the percentage of the moisture/humidity setting, the more it extracts from the household air. The higher the setting, the less it extracts from the household air.
Also, remove and check the air intake filter to see if that needs to be cleaned. It should be cleaned at least twice a week during the operating season.
Hope this helped you troubleshoot and solve the problem. Please let me know. Thanks.
Jun 06, 2011 | Haier HDN455 Dehumidifier
My dehumidifier is not collecting water what can i do to fix it? the model #99701
There are several reasons this may be happening. The 2 primary reasons are the humidity extraction level is set to high. Lower it to 35% . The lower the setting, the more moisture/humidity is extracted from the air. The higher the setting, the less if any moisture/humidity will be extracted from the air.
On most humidifiers the fan runs almost constantly while in operation. The idea is to continually move the air around and when the unit senses a rise in humidity, above what you have it set on, the compressor will turn ON to extract that humidity.
The 2nd thing that causes the problem is a dirty of clogged intake air filter. Which is easily solved by removing and cleaning the filter. Which should be done at least every 2 weeks, while the dehumidifier is in operation.
I said there were 2 primary reasons. Actually, there is a 3rd. Not enough clear air space all around the dehumidifier. A minimum of 12" should be maintained during operation.
Hope this helped you to troubleshoot and solve the problem. Please let me know. Thanks.
Jun 02, 2011 | Kenmore 54501 Dehumidifier
My dehumidifer is not drawing any water, but the fan continues to run.
There are several reasons this may be happening. The 2 primary reasons are the humidity extraction level is set to high. Lower it to 35% . The lower the setting, the more moisture/humidity is extracted from the air. The higher the setting, the less if any moisture. humidity will be extracted from the air.
I said there were 2 reasons. Actually, there is a 3rd. Not enough clear air space all around the dehumidifier. A minimum of 12" should be maintained during operation.
Jun 02, 2011 | Haier 45-Pint Dehumidifier
Machine runs, but no water is coming out into the bucket
Jun 02, 2011 | LG LHD459EL Dehumidifier
What numbers do i set the digital screen on? on the amana dehumidifier D 965E-E
If you want to remove a lot of moisture/humidity, set extraction level on 35%. That's the arrow down button. If you want to remove less moisture/humidity raise the extraction percentage level.That's the arrow up button.
Hope this helped you. Please let me know. Thanks.
Jun 02, 2011 | Amana Dehumidifiers
No water is extracted into bucket. Motor is on - although don't feel any hot air coming out of unit
It may be just the fan motor running and not the compressor. Which, depending on what level you have the humidity extraction set on, may be the problem. If it's set to high, the fan is running to circulate the air. If the humidity sensor picks up a rise in the humidity level (higher than what you have it set on), the compressor will turn ON. Lower the setting to 32 or 35% and if the air intake filter is clean and not clogged, the compressor should turn on shortly thereafter. In addition, be sure to maintain at least 12" of clear air space around the entire unit.
Many times the higher settings are thought to be how much moisture will be extracted. When in fact, the opposite is the case.
May 30, 2011 | Whirlpool AD40USL Dehumidifier
Dehumidifier does not extract moisture - just runs and runs
There are many reasons why a dehumidifier will not work or collect water.
heatman101
Oct 11, 2010 | Frigidaire FDF50S Dehumidifier
(New Unit) Motor Runs, Does Not Extract Moisture
Try setting you temperature or fan speed lower this may help.
In order for the unit to remove moisture the coil has to be below the dewpoint.
Aug 02, 2009 | Haier HD451E Dehumidifier
Dehumidifiers Logo
169 people viewed this question
Top Frigidaire Dehumidifiers Experts
Lawrence Oravetz
mike cooper
Are you a Frigidaire Dehumidifier Expert? Answer questions, earn points and help others
