Hotpoint model WMA 50 washing machine goes thru program but motor not turning Belt still on
    Genius:
  • 1,073 Answers
What is the full model number
Posted on May 11, 2008
The water wont drain out of machine Hotpoint Ultima WMA 74 on any cycle - have checked the outlet pipe, doesn't apperar to be blocked as water will come out when pipe laying on floor.
If your washer does not drain you need to check this parts.
  1. Inspect the drain hose for kinks
  2. Test the timer control
  3. Test the lid switch(some models)
  4. Inspect the water pump
  5. Inspect the drive belt(belt drive only)
  6. Inspect the motor coupler
Mar 28, 2010 | Washing Machines
Hi i have a WMA 50 and my little boy swung on the front loader door and it broke off at the hinge's the plastic part where the hinge goes, i have been told that hotpoint has a parts department that has all...
You can order the parts you require directly from Hotpoint.
Go to ;
WWW.Hotpoint4u.co.uk.
Click on washers, and follow the guide.
The part numbers are as below.
1603448 Hinge bearing.
1604434 Hinge assy.
This should solve your problem
Dec 17, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
REFITTING THE BELT ON HOTPOINT WMA 40
Place it on the motor pulley and then guide it around the drum pulley. It will have come off for a reason which if you do not correct will cause it to come off again. Lay it flat on a table - if it does not lay flat - replace it. Check the pulley on the drum does not move from side to side. (problem with pulley or drum bearings)
Sep 03, 2008 | Hotpoint WMA40 Front Load Washer
Hotpoint WMA 48, tripped house rcd, no lights on and water heating noise.
need to know a little more really but here goes, if you remove the top and the drive belt is still on then it will be as straight forward as the motor brushes at fault they will need replacing as this is a common fault on these machines. hope this helps
Mar 06, 2007 | Hotpoint WMA48 Front Load Washer
Hotpoint wma 34 front loader will not spin
Open the rear panel and check for a broken belt and whether the motor spins. In case both are OK it could be a bad capacitor issue as well. Good luck!
Nov 28, 2006 | Hotpoint WMA33 Front Load Washer
Goes straigt to spin
TRY CHECKING THE BOARD ON THIS MACHINE ESPECIALLY THE MOTOR CONNECTION. WHAT YOU WILL AHVE TO DO IS PUT THE DIAL IN TO THE OFF POSITION ( ONLY AS GUIDE ) THEN DISMATLE THE BOARD FROM THE FRONT FACIA. HAVE A GOOD LOOK AT THE MOTOR PLUG CONNECTION SECTION OF THE BOARD CHECK TO SEE IF THERE ARE ANY TRACKS THAT HAVE BLOWN. I RECONDTION WMA ALL DAY EVERYDAY AND I HAVE HAD THIS PROBLEM BEFORE ONCE AND AM THINKING YEH THAT WAS THE PROBLEM. OR IT COULD BE THE TACO ON THE END OF THE MOTOR BUT THIS IS VERY RARE FOR HOTPOINT WMA UNLIKE THE HOOVER MACHINES.
Aug 21, 2006 | Hotpoint Aquarius WMA42 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
