Question about Motorola Mobility RAZR V3
RAZR - Sploosh!
My razr went for a quick dip in a tub. i pulled it out immediately. I wz able to get it on briefly, then it turned off. I immediately took the battery and sim card out and dried them off. It still went on then off again. Then i plugged it in w/ charger and it came on for a bit, and then shut down again. I tried puffing air into in with a rubber bulb thingie, but that did not help. Then i disovered that i could still dial (the keys were lit up), make & receive calls. I must get the screen back though!!! I don't remember all the #'s in my phone book.
Take the phone apart like you did and put alittle paper clip in the screen part, drop your phone into a container of rice and seal it closed. IT should draw the mositure out. and then lay your phone on a heater vent for 24 hours. I dropped mine in the toilet, took it apart and now it works fine. It just has to dry out.
Hope it helps
Posted on May 12, 2008
  • 63 Answers
The main flex cable connector in the screen is most likely corruded... u need to open the cover and get it cleaned and replace it.this might be a bit difficult if u don't have a t6 or a t4 screwdriver, but if u do u need to remove the 4 screws located under the rubber stubs on the inner screen. pry off the cover and pop off the main connectore on the left hand top of the screen and clean it carefully with an old tooth brush and a little spirit. u need spirit because it evaporates quickly. you don't need anymore water in your phone.
If this doesn't work u need to get someone with another razr and go through the steps of copying your numbers onto your simcard. Each step u take on the working razr make sure u do the same on the damaged one.remember u can't see the screen on the damaged razr.when u are through u could always remove your sim card and try locating the numbers in another phone to see if u were successful.when you are doing the copy transfer on your phone if it was a lot of numbers make sure u give it at least 5 minutes to complete....try this:-
center button
left arrow
up arrow
center button
menu button (button above the four way toggle)
down button 10 times
center button
down button
center button
wait for five minutes...
try your simcard in another phone and confirm your numbers...
this should work.
sam !
Droid RAZR m losing charge quickly
Could be the battery is exhausted.
Mark
Motorola Support
Apr 14, 2014 | Motorola Mobility XT907 DROID RAZR M...
I have a motorola razr v3x phone, problem with water damage
I dropped my in the bath tub giving my little girl a bath. I pulled the back cover and battery out and sat it upside down, back faceing up, under a lap and turned it over every hour. The next morning put the battery in and closed it up, no problems - till the next time it went swimming and had to repete the process.
Sep 16, 2009 | Motorola Mobility RAZR V3x Cellular Phone
My Motorola Razr v3 cell phone's lcd is blank
unscrew it and change the flex to enable it view programms
Jul 17, 2009 | Motorola Mobility RAZR V3
Motorolla razr, black oldest edition
try another battery and if the lights just blink briefly....your main-board sounds like it is damaged so you may need a new one.
Jun 11, 2008 | Motorola Mobility RAZR V3
Razr won't turn on.
Open up the case and let it dry out.
May 15, 2008 | Motorola Mobility RAZR V3
Automatic signature?
the RAZRs wont add a signature, even if u put one in. i have the same problem on mine.  Ill c wat I can do, but idk if i can get it 2 work.  A nice fone 2 get wud b a samsung,  THANKS 4 RATING
Feb 09, 2008 | Motorola Mobility RAZR V3xx Cellular Phone
Dropped fone in toilet
Hi, You can purchase a spray called electric cleaner that cleans small electric components and dries very quickly. But you will have to open the phone and spray on the small circuit board inside. If it still doesn't come up after that then it might possibly be dead. Sorry and good luck Lolita
Jun 09, 2007 | Motorola Mobility RAZR V3
Razr help
Sounds like your phone's been through some rough treatment - try taking the battery & sim card off for a while - make sure there's no moisture & if you're still having problems, stop by your dealership shop & see what they can do.
May 30, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
42 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
