After recording onto DVD+R discs I get the following error message when attempting to finalise the DVD: ___________________________ Recordring Error Can not record on this disc E 3 28031100 ___________________________ An alternative error code of "E 22" occassionally appears.
  • 4 Answers
SOURCE: Error code E 4 54040990
You need to go into the set up menu and select recording options. On the recording options menu, scroll down to dubbing options. On the dubbing options menu select either VCR to DVD or DVD to VCR.
Recording and Dubbing are not the exactly the same thing. You use the record buttons to record TV directly to VCR/DVD you use the dubbing buttons and set up to record DVD to VCR or VCR to DVD.
Hope this helps.
Dafid
Posted on Jul 19, 2008
  • 236 Answers
SOURCE: how to finalise dvd recording
Press the menu button on your remote - go to finalize disc - follow instructions. Note that VR discs can be played with many if not most DVD-players without finalizing. In fact I have had problems finalizing and unfinalizing discs back and forth. If the disc manager displays only unfinalize disc, the disc is already finalized.
Posted on Feb 09, 2009
SOURCE: Sony Handycam DCR-DVD 202E
i am getting a disk access error in sony camcorder..Not able to record any further..pl. help
Posted on Aug 16, 2009
SOURCE: Funai VCR/DVD recorder DVR 2737. My -R discs
I was advised to try another make of blank discs. I bought Sony discs & they worked ok. I had been using supermarket own brand.
Posted on Oct 18, 2009
rulds2008
  • 3866 Answers
SOURCE: Can't get rid of dirty disc error message at 1 min
Ok you might need to have it cleaned professionaly worse comes to worse have the lens replaced, something ether got on the lens or the laser is not reading or writing correctly. Can it be fixed? Sure depning on the problem inside I could not tall you 100 p[ercent as I have not looked at the unit.
You might want to take a gander inside and see if the lends is not dirty.
Thanks an please rember to leave postive ratings and feedback.
Posted on Apr 12, 2010
Comes up succesfully copied but wont let me finalise
This is almost always a laser problem within the recorder. The recorder can write the disc but needs to write the TOC (table of contents) and can't do it (That's finalising). On occasion, the make of the DVD-r or DVD+r (they are different!) can fail to work on some machines. Try a different make of disc.
Feb 21, 2012 | Televison & Video
I have dubbed vcr tape to a Sony DVD-RW disc and tried playing it back through a toshiba player and it keeps coming up Bad Disk. My PC won't even recognise it. When started dubbing the screen displayed 1hr...
Did you say you used a DVD-RW disc to transfer a videotape onto? The reason your PC won't recognise that disc is because the data format on it is a different language to what PCs understand - plus an unfinalised DVD-RW won't play in other DVD players - it is usually an incompatible format.
(DVD+RW discs with titles/top menus created in video mode CAN be played on a PC DVD drive or a normal DVD player as can finalised DVD-R discs (DVD-R discs MUST be recorded and finalised in the same recorder for compatible playback). DVD-RW discs can only be viewed on the unit they were written/recorded on.
The other reason for the 'remaining space' on the disc you describe showing less than 120 minutes is due to a title recently being recorded or erased - unless you format it - the 120 minute / 4.7GB DVD-RW will not show full available space. Erasing titles on re-writable DVDs does not increase space. The same rule applies to unfinalised +R / -R discs (you cannot re-format these to get the space back once recorded - they are 'once only' writables)
I recommend you invest in some DVD-R discs and re-copy your VHS tape to that - then if you are satisfied with the result, title etc., finalise the DVD-R - it will play on any DVD player or PC with DVD support (or it should). These discs are relatively inexpensive to buy just about anywhere.
Final note: do NOT finalise the DVD-RW you recorded (I hope you haven't already done this) - simply format/erase it - re-use it for something else or keep it until you need it.
You can use any brand of DVD, just take note of the format before recording/playing.
Mar 21, 2011 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Attempted to burn a DVD
The lens for reader is a common issue and causes those errors. Get inside the box, take off the two screws on the DVD drive cover and (delicately) remove dust from the lens and surroundings. You should use delicate brushes and air blast, but I got some soft tissue and gently wiped.
I hope this helps
May 29, 2010 | Televison & Video
Format error when i finalise the disk
If a FORMAT ERROR message is displayed, then the inserted disc is not formatted or it is recorded in a different format not useable by the camcorder. If using a DVD-RW or DVD+RW, format the disc prior to use. Otherwise, use a different disc.
Mar 21, 2010 | Sony Handycam DCR-DVD201 DVD Camcorder
Dvd does not show what was recorded from my sony camcorder error message C13:02 flashing
This is Disc Access Error, Disk Access Error, Check disc error, Check disk, C error unreadable, disc error code 13, disk error code c1302, c:13:O2 DISC ERROR, Disc Error C:13:02 message Sony mini dvd finalize error code C1302 DVD not finalised, Rec Disabled Record Disable after dropping the camera, DVD not finalized, DVD Disc not finalized, DVD Disk not finalized, DVD Disc not finalised, DVD Disk not finalised, Disc won't finalize, Disk won't finalise DVD Disc Error, DVD Disk Error, DVD Disc Format Error, DVD Disk Format Error, Rec. Disable, not correct disk, the disk in drive is not formatted do you want to format it now.
Nov 15, 2009 | Motorcycles
My DVD recorder doesn;t record. When I go to replay there is nothing on the Recorded list. (The message PSO is showing on the front of the recorder.Is this coneected?)
Ok recording is impossible.
1.this unit may not record programs that contain copy protection signal.
2.Check that there is nothing on the disc to start off with.
3.check that the disc is CPRM compatible.copy onc programmes can only be copied onto the disc which is CPRM compatible.
4.check if the the disc is protected or finalised.Undo the protection or the finalisation.
5.DVD-RW usually once formatted in another unit cannot be recorded in your unit unless formatted.
6.Check all connections are properly made.
Oct 18, 2009 | Televison & Video
How to finalise dvd recording
Feb 05, 2009 | Samsung DVDR120 DVD Recorder
Finalise disc
You need to put the disk back into the recorder, select the finalize function from the onscreen menu, and follow prompts. Do you have an owners manual for the unit?
Apr 22, 2008 | LG RH177 DVD Recorder/HDD Recorder
Canon DC210 Camera
The error message is because, either
1. the disc was initialised on another camcorder, or maybe a PC, or
2. The disc has a recording on it in a different TV system (PAL v SECAM).
From the above, it may be you're using the same disc in two camcorders. To be sure of seeing what's on your disc you need to keep it with the same camcorder from 'initialise' to 'finalise' .
To be able to see the disc on a PC you need to finalise it on the camcorder. There's no other way to get to see your work on a PC.
Unfortunately I think you've lost your recordings this time.
Feb 08, 2008 | Canon DC210 DVD Camcorder
Finalising
i bought a camcorder from currys model vp dc 172w back in october. i took it to las vegas to record my wedding. its recording fine but i cant finalize the disks. iam folowing the instructions from the book. on 1 disk its trying for about 30 seconds then is saying disk error. the other disks i cant even get them to start running. can you help me please.
Oct 30, 2007 | Samsung VP-DC161 DVD Camcorder
Televison & Video Logo
112 people viewed this question
Top Televison & Video Experts
Electro Med Services...
