Hi, I´m looking for manual of Encore Broadband Router ENAFN-RT514-PR-E
Because i need user and password default (among other things). I have looked for in the Web of encore, but i can´t see nothing about this model.
I try with the common users and passwords, but i can´t found it...
Please, can you say me where to look for it, is quite urgent.
Thanks
Fabian
Comments:
May 10, 2008
- Hello Jeff, thanks for your answer. Although that is not the model, the one that I look for is... PR-E and the one that you indicate to me is the PR (it is look different, it hasn't the same default IP address, and nor the same surroundings of the administrator of HTTP) but... has seen that the password that uses this model is "1234" and "works ok" to me with user "admin" inmy router.... It is to say partly already I am advancing. In fact really to finalize totally with my search, I will have left to find the manual of ENAFN-RT514-PR-E exactly. Of all ways, already I am advancing with your aid. If you know of this model ...PR with "-E" at end, (because both models are different) I will be thankful to you, in opposite, equal case I will describe to you well. I wait for your new answer.
Gracias
Fabian
May 13, 2008
- Hello, in fact external aspect is different, if you could see the photos of both models, are not different also in that sense. Another difference is that the surroundings Web are totally different, direction IP default is different, and that is not the manual that corresponds to the model. As all ways, it served the key to me that has that model that you say, with which advance. In spite of continuing looking for the manual of my model, FixYa will describe to you "FixYa!" then at least you helped me to enter when router. If you know something of the manual I will be thankful to you you indicate it. Thanks for your aid. Fabian
Hi Fabian. The link below should be what you're looking for. If this solves your problem PLEASE rate this as fixed. If not, or you need more help, DON'T RATE YET, just add a comment and I'll be glad to assist you further. Thanks Fabian. Have a good one.
- Hey Fabian - still trying - I don't give up! I have a question though - what is the difference between yours and the one I sent you? I mean, what further info do you need to get you going? If you can't get in to the router, I can get you in. Let me know. Oh, thanks for not rating yet and giving me a chance to fix your problem. Most people don't do that. Thanks. Wait to hear from ya.
Jeff
Was this helpful?
Yes
No
Solution #2
posted on Jul 01, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
ME AYUDAN TAMBIEN AMI CON EL ROUETR ENAFN-RT514-PR-E,YA QUE ENTRO EN EL,PERO NO PUEDO CONFIGURARLO PARA TENER INTERNET,AGRADESCO,CUALQUIER AYUDA,TENGO SPEEDY.
Popular Solutions for Encore ENAFN-RT514-PR Router
Purchased a Belkin (N150) router this morning along with a new laptop. Problem - I can't get the...
(More)
Purchased a Belkin (N150) router this morning along with a new laptop. Problem - I can't get the laptop to accept the router. Don Hood
Hi my dynamode BR 6004WG1 has stopped working! orginally the internet would not work on our main...
(More)
Hi my dynamode BR 6004WG1 has stopped working! orginally the internet would not work on our main wired computer NTL managed to get this working and said the fault lay with the router. All the lights on the router come on i wondered if there was any way we can check to see if its definatly broken before we buy another thanks julie
Hi I am using the SohoENAFN-RT514-PR router for 3 years without any problem but all of a sudden, I...
(More)
Hi I am using the SohoENAFN-RT514-PR router for 3 years without any problem but all of a sudden, I cannot access my own program http://www.alldownlineclub.com which is hosted by LowCost Webspace. Any program hosted by them, IP 72.55.137.164 is blocked. When I by-pass the router, everything is ok, it seems the router is blocking this IP, how can I correct this? I did reset the router with no result. Thanks in advance, Mike mjm2@videotron.ca
